PPTP Traffic in CRS-1 CGN with PAT
gustavoa.guerra
Hello
PPTP traffic is not working in CRS-1 CGN using PAT, Is it possible?, Does somebody have a configuration example?, Is there an alg for pptp traffic?
Thank you for your comments
Gustavo
Alexei Kiritchenko
Hello Gustavo,
CGN PPTP support is planned for 4.3 release.
/A
5 Replies 5
Alexei Kiritchenko
Hello Gustavo,
/A
Hello Alexei,
We are facing a similar issue as well.
Do you have a list of supported protocols on the CGN that can do PAT?
Thanks for your support.
Best Regards,
Michel.
Hello Michel,
Currently supported Application Level Gateways are Active FTP and RTSP.
http://www.cisco.com/en/US/docs/routers/crs/software/crs_r4.2/cg_nat/configuration/guide/cgc42book.pdf
/A
Hello Alexei
Thank you for your comment, Do you know when the 4.3 release will be available at Cisco.com???
Kind regards
Gustavo
Hello Gustavo,
it is planned for the end 2012.
/A
