02-23-2012 07:26 PM
Hello
PPTP traffic is not working in CRS-1 CGN using PAT, Is it possible?, Does somebody have a configuration example?, Is there an alg for pptp traffic?
Thank you for your comments
Gustavo
Solved! Go to Solution.
02-24-2012 01:18 AM
02-24-2012 01:18 AM
Hello Gustavo,
CGN PPTP support is planned for 4.3 release.
/A
02-24-2012 05:29 AM
Hello Alexei,
We are facing a similar issue as well.
Do you have a list of supported protocols on the CGN that can do PAT?
Thanks for your support.
Best Regards,
Michel.
02-24-2012 06:43 AM
Hello Michel,
Currently supported Application Level Gateways are Active FTP and RTSP.
/A
02-24-2012 09:13 AM
Hello Alexei
Thank you for your comment, Do you know when the 4.3 release will be available at Cisco.com???
Kind regards
Gustavo
02-24-2012 12:35 PM
Hello Gustavo,
it is planned for the end 2012.
/A
