Problems with Precedence
We configured a input QoS policy on particular interface, where we are
forcing precendence, however noticed that the same is not being made​​.
In summary we have the following configuration:
RP/0/RP0/CPU0:CRS# sh run int hundredGigE 0/3/0/0
Mon May 14 16:19:54.009 DST
interface HundredGigE0/3/0/0
service-policy input XPTO
ipv4 bgp policy propagation input qos-group source
ipv4 address 10.10.10.1 255.255.255.252
ipv6 nd suppress-ra
carrier-delay up 5000 down 0
load-interval 30
RP/0/RP0/CPU0:CRS#sh run policy-map XPTO
Mon May 14 16:20:16.558 DST
policy-map XPTO
class class-qos10
  set precedence 1
class class-qos20
  set precedence 0
class class-default
end-policy-map
RP/0/RP0/CPU0:CRS#sh run class-map class-qos10
Mon May 14 16:20:23.409 DST
class-map match-any class-qos10
match qos-group 10
end-class-map
RP/0/RP0/CPU0:CRS#sh run class-map class-qos20
Mon May 14 16:20:26.210 DST
class-map match-any class-qos20
match qos-group 20
end-class-map
RP/0/RP0/CPU0:CRS#sh policy-map interface HundredGigE0/3/0/0
Mon May 14 16:20:05.718 DST
HundredGigE0/3/0/0 input: XPTO
Class class-qos10
  Classification statistics          (packets/bytes)     (rate - kbps)
    Matched             :       6793713014812/5788911678523417     13070576
    Transmitted         :       6793713014812/5788911678523417     13070576
    Total Dropped       :                   0/0                    0
  Queueing statistics
    Queue ID                             : 49120
    Taildropped(packets/bytes)           : 0/0
Class class-qos20
    Matched             :         59306695626/56107446620469       32982
    Transmitted         :         59306695626/56107446620469       32982
  Queueing statistics
    Queue ID                             : 49120
Class class-default
    Matched             :            54537026/4385234548           7
    Transmitted         :            54537026/4385234548           7
  Queueing statistics
    Queue ID                             : 49120
    High watermark  (bytes)/(ms)         : 6552/0
    Inst-queue-len  (bytes)/(ms)         : 0/0
    Avg-queue-len   (bytes)/(ms)         : 2/0
HundredGigE0/3/0/0 direction output: Service Policy not installed
RP/0/RP0/CPU0:CRS#sh cef 8.8.8.8
Mon May 14 16:20:33.329 DST
8.8.8.0/24, version 22, internal 0x4000001 (ptr 0x9e453b00) [1], 0x0 (0x0), 0x0 (0x0)
Updated May  8 08:20:04.329
Prefix Len 24, traffic index 0, precedence routine (0)
QoS Group: 10
   via 10.10.10.2, 3 dependencies, recursive, bgp-ext [flags 0x20]
    path-idx 0
    next hop 10.10.10.2 via 10.10.10.0/30
As you can see here this prefix makes match on qos-group 10, so should be marked with a
precedence 1, but is marked with 0.
can help?
dpothier
hi Luis,
Can you also supply the CEF hardware output, so we can check the precedence their as well. Use the CLI
"show cef 8.8.8.8 hardware ingress location 0/3/cpu0" and we'll look at the qos_precedence: value to see if it is also set to 0.
thx,
David
