Qos minimun values in IOS XR
darshakpp
Im using ASR9001 running IOS XR 4.2.3. I was trying to apply the following QOS configurations.
policy-map output-test
class match-5
  priority level 1
  police rate 32 kbps
class match-3
  bandwidth  64 kbps
class match-1
  bandwidth  32 kbps
class class-default
end-policy-map
policy-map output-parent
class class-default
  service-policy output-test
  shape average 128 kbps
end-policy-map
While applying the above hierarchial QOS on the interface, the system is generating the following error.
"Minimum value for bandwidth configuration is 64 kbps"
Then I tried the bandwidth remaining percent for  the classess match-3 and match-5.
class match-5
  priority level 1
  police rate 32 kbps
class match-3
  bandwidth remaining percent 66
class match-1
bandwidth remaining percent 34
class class-default
end-policy-map
The configurations are accepted this time, but while observing the statistics, LLQ class (match-5) is allowed up to 66 kbps, but the configured value is 32 kbps. I reduced the police rate value to 8kbps (minimum configurable value in XR), but still the traffic is policed at 66 kbps.
Have anyone noticed this behavior on IOS XR?
Darshak
Ahmed Moshref
What is the interface type, it will differ from one  to another ?
• Ingress Queueing Only
The smallest step size supported is 32 kbps for groups and 32/3 kbps (10.67 kbps) for queues. Step size
increases with the rate value. Rounding error does not exceed 0.4 per cent or 8 kbps, whichever is higher.
• Egress Queueing Only
The smallest step size supported is 8 kbps for 10 gigabit interfaces and 64 kbps for 100 gigabit interfaces
for queues and groups. Step size increases with the rate value. Rounding error does not exceed 0.4 per
Im using one Gig interface (A9K-MPA-20X1GE)
interface GigabitEthernet0/0/0/1.200
mtu 1518
  service-policy output output-parent
vrf test
ipv4 address 192.168.200.1 255.255.255.252
encapsulation dot1q 200
Is there any limitation on one Gig as well?
