"mpls traffic eng passive-interface" mapping on XR
amr mubarak
Dears,
ON IOS for TE-InterAS ,the command "mpls traffic-eng passive-interface" is used on InterAS link which isn't running IGP so i am seeking for the equivlent command on XR but i can't find it so please advise what is the equivlent command on XR
Hello Amr,
There is no equivalent command on IOS-XR. Are you trying to set up Inter-AS MPLS TE on XR? In IOS-XR, inter-AS tunnels are supported only by using verbatim path-options. Verbatim path-options are supported on both IOS and IOS-XR.
HTH,
Rivalino
amr mubarak
Anyone can help here for this question as i am searching since a long time for an answer but i can't find through web searching
Hello Amr,
HTH,
Rivalino
Thanks it works
