Re-marking PPP LCP packets to CoS 0
ALEXANDR LYKOV
Hello all,
We need to remark all outbound traffic to upstream service provider with CoS 0 from BNG PPPoE interface especially control PPP packets e.g. LCP requests.
According to the documentation we don't need to worry about it but what we can do if we must?
Control Packet Handling
BNG provides priority treatment in handling PPP Link Control Protocol (LCP) packets. The control packets are handled in high priority without the need of user configuration, and these packets are not subjected to QoS policies that are applied on both ingress and egress of the interface. In the case of LAC upstream direction, if user wants a trusted COS value, then a PPP command is provided to impose the core-side header based on the set trusted-COS. Thus, this ensures the priority treatment of these control packets in the network.
PPP LCP packets:
My configuration:
interface GigabitEthernet0/0/0/1
 description "SW06 Gig0/18"
 mtu 9208
 transceiver permit pid all
interface GigabitEthernet0/0/0/1.1
 service-policy output EUBA-SVLAN-COS1 subscriber-parent
 service-policy type control subscriber PPPoE_policy1
 pppoe enable bba-group PPPoE
 encapsulation ambiguous dot1q any second-dot1q any
policy-map EUBA-SVLAN-COS1
 class class-default
  set cos 0
  set cos inner 0
  shape average 900 mbps
 end-policy-map
pppoe bba-group PPPoE
 mtu 2000
 service selection disable
 sessions mac limit 5
 sessions vlan limit 1000
 sessions circuit-id limit 50
 control-packets priority 0
policy-map type control subscriber PPPoE_policy1
 event session-activate match-first
  class type control subscriber PTA_CLASS do-until-failure
   10 authenticate aaa list default
   20 activate dynamic-template TTP-2000-1
 event session-start match-first
   1 activate dynamic-template PPP_TPL1
 end-policy-map
dynamic-template
 type ppp PPP_TPL1
  ppp authentication pap chap
 type ppp TTP-2000-1
  vrf Jail-999
  accounting aaa list default type session periodic-interval 30
  ipv4 verify unicast source reachable-via rx
  ipv4 unnumbered Loopback999
  ipv6 nd other-config-flag
  ipv6 verify unicast source reachable-via rx
  ipv6 enable
0 Replies 0
