redundancy (Node Not Ready, NSR: Not Configured) [A9K]
hello , i have router A9K with IOS XR 6.6.3,
when making change on configrurion , and trying to commit it, it takes more than 20 min to apply,
RP/0/RSP1/CPU0:ASR9006-NOOR-XR#EDit prefix-set DENY-OUT-ANY inline remove 185.228.249.0/24
Sun Sep 25 13:36:11.999 GMT
[OK]
 removing:   185.228.249.0/24
Proceed with commmit (yes/no)? [yes]: yes
Parsing...................................................................................................................................................................................................................................................................................................................................
98 bytes parsed in 323 sec (0)bytes/sec
Committing.
Prepared commit in 0 sec
1 items committed in 3 sec (0)items/sec
Updating..........................................................................................................................................................................................................................................
so look on logging
RP/0/RSP1/CPU0:Sep 25 13:41:37.499 GMT: rmf_svr[409]: %HA-REDCON-1-STANDBY_READY : standby card is ready
RP/0/RSP0/CPU0:Sep 25 13:41:37.499 GMT: rmf_svr[409]: %HA-REDCON-6-STBY_STANDBY_READY : This card is standby and is ready
RP/0/RSP1/CPU0:Sep 25 13:41:40.516 GMT: rmf_svr[409]: %HA-REDCON-1-STANDBY_NOT_READY : standby card is NOT ready
RP/0/RSP0/CPU0:Sep 25 13:41:40.516 GMT: rmf_svr[409]: %HA-REDCON-1-STANDBY_NOT_READY : standby card is NOT ready
RP/0/RSP1/CPU0:Sep 25 13:41:50.517 GMT: rmf_svr[409]: %HA-REDCON-1-STANDBY_NOT_READY : standby card is NOT ready
also, i check the redundancy
Redundancy information for node 0/RSP1/CPU0:
Node 0/RSP1/CPU0 is in ACTIVE role
Node Redundancy Partner (0/RSP0/CPU0) is in STANDBY role
Standby node in 0/RSP0/CPU0 is not ready
Standby node in 0/RSP0/CPU0 is NSR-not-configured
Node 0/RSP1/CPU0 is in process group PRIMARY role
Process Redundancy Partner (0/RSP0/CPU0) is in BACKUP role
Backup node in 0/RSP0/CPU0 is ready
Backup node in 0/RSP0/CPU0 is NSR-ready
so why commit  take a long time to applied, the redundancy issues or what ?
10 Replies 10
smailmilak
Level 4
Level 4
Do you have NSR configured?
no
Since you have two RSPs I would advise to enable it. It helps a lot in case of active RSP failure.
If the problem persists you can always reboot the standby RSP.
How to reboot RSP
admin, then hw-location 0/RSP0 reload
smilstea
Does this only happen with the edit rpl/prefix-set command or if you go into config mode and commit something as well? Seen once or more than once?
Was this done before the router had finished booting up fully or was another user issuing a commit at the same time?
We will probably need a tac case logged to review show tech routing rpl, show tech cfgmgr, show tech rdsfs.
Sam
Hello , any commit after any config, take a long time
So did you a reboot of the standby RSP?
During the reboot you can try to commit something and check if commit is faster without the standby RSP.
hello
after reboot RSP
RP/0/RSP0/CPU0:ASR9006-NOOR-XR#show platform
Sat Dec 24 15:19:58.007 GMT
Node Type State Config State
0/RSP0/CPU0 A9K-RSP440-SE(Active) IOS XR RUN PWR,NSHUT,MON
0/RSP1/CPU0 A9K-RSP440-SE(Standby) MBI-RUNNING PWR,NSHUT,MON
RP/0/RSP0/CPU0:ASR9006-NOOR-XR#show redundancy summary
Sat Dec 24 15:24:42.583 GMT
Active/Primary Standby/Backup
0/RSP0/CPU0(A) 0/RSP1/CPU0(S) (Node Not Ready, NSR: Not Configured)
0/RSP0/CPU0(P) 0/RSP1/CPU0(B) (Proc Group Ready, NSR: Ready)
