Redundant Firewalls to Cisco ASR Connectivity
ammartalal
I need to connect two redundant firewalls working as Active/Standby to a single ASR router. The ASR router is having 2 line cards and each firewall is connected to both line cards as per the diagram.
What is the best way to ensure high availability during firewall fail-overs in this case? Is FHRP a feasible option? or are there any suggestions!!
You need to but SW between ASR and both FW' this SW can unmanage SW
Your topolgy will not work without SW
MHM
