06-05-2025 05:40 PM - edited 06-05-2025 05:46 PM
I've set up this policu but got this error when applying it to by BGP neighbor :
route-policy RP-TRACK-T5-LP-200
if track track-T5 is up then
set local-preference 200
pass
endif
end-policy
router bgp 65532
neighbor 172.31.255.5
use neighbor-group RR-CLIENT
address-family vpnv4 unicast
route-policy RP-TRACK-T5-LP-200 in
show conf failed gives :
Thu Jun 5 21:33:19.486 UTC
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
router bgp 65532
!!% Could not find entry in list: Policy [RP-TRACK-T5-LP-200] uses the 'track' attribute. There is no 'track' attribute at the bgp neighbor-in-dflt attach point.
end
Any idea ??
I have a similar config with IOS XE that works fine.
Cheers.
06-05-2025 07:25 PM
Hey,
This issue occurs because IOS XR does not support using track conditions inside BGP route-policies. Unlike IOS XE, IOS XR has stricter enforcement rules, and track is not a valid condition when applied under the BGP address-family using a route-policy.
Example code that caused error:
pass
endif
end-policy
router bgp 65532
This gives the error output:
What I would do:
Remove the track condition and simplify the policy:
route-policy RP-LP-200
pass
end-policy
Use EEM or external automation (Python, Ansible, etc.) to monitor the status of track-T5 and apply/remove the policy dynamically.
Because the Logic behind:
If track-T5 is up, apply the policy to the neighbor:
router bgp 65532
route-policy RP-LP-200 in
router bgp 65532
no route-policy RP-LP-200 in
Since track cannot be used directly in the route-policy in IOS XR, this logic must be handled externally.
Hope this helps you understand!
06-05-2025 08:03 PM
Hey Mate,
thank you for your reply,
do you have some example to configure EEM directly under IOS XR to monitor the status of track-T5 and apply/remove the policy dynamically ?
Cheers !
06-05-2025 09:34 PM
Hey,
Glad the explanation helped! Regarding your follow-up—yes, while IOS XR doesn't support the classic EEM applets like IOS XE, you can still achieve similar functionality using Embedded Event Manager (EEM) scripts written in Tcl, or better yet, use external automation tools like Python with NETCONF/gNMI or even CLI-based scripting over SSH. Here’s the concept:
You create a periodic script (whether it's an EEM policy or an external Python script) that checks the state of your tracked object (e.g., track-T5). Based on whether it's up or down, the script would log into the router and dynamically apply or remove the route-policy from the BGP neighbor config.
For example, if track-T5 is up, the script pushes:
router bgp 65532
If it's down, it pushes:
router bgp 65532
If you want to do this on-box, you’d typically use XR’s support for Tcl scripts via EEM, but it requires enabling the appropriate infrastructure and writing a script that can parse CLI command output, which can be quite complex and limited compared to off-box automation.
So for production or clean design, I highly recommend using Python with ncclient or paramiko to run CLI commands remotely. You can poll the show track brief or show track name track-T5 output every X seconds, and trigger config changes accordingly.
Cheers!
07-05-2025 06:26 AM
Check
Bgp next-hop resolution trigger
MHM
