Router OSPF enable is not showing // ASR9901
Tech Support
Hello
A new ASR 9901 and trying to activate ospf under global or interface mode, the ospf commands are not showing !!
RP/0/RSP0/CPU0:AGG-01(config)#router ?
bgp BGP configuration subcommands
hsrp HSRP configuration subcommands
lisp LISP configuration subcommands
rib RIB configuration subcommands
rip RIP configuration subcommands
rpl IPv6 Routing Protocol for Low-Power and Lossy Networks (RPL)
static Static route configuration subcommands
vrrp VRRP configuration subcommands
RP/0/RSP0/CPU0:AGG-01#show license usage
Sun May 17 10:45:02.167 UTC
License Authorization:
Status: No Licenses in Use
RP/0/RSP0/CPU0:AGG-01(config-ospf-area)#?
#-remark Remark beginning with '#'
<0-4294967295> 32-bit decimal number
A.B.C.D Specify an IPv4 address / Specify an IPv4 ACL
abort Discard RPL definition and return to top level config
end-set End of set definition
exit Exit from this submode
show Show partial RPL configuration
Is there any license or L3 package need to be active ?
smilstea
Do you have the ospf package installed? (show install active summary)
After installing the base iso you also need to install the optional packages.
Sam
Solved , show install inactive showing the OSPF , MPLS , MPLS TE packages not active.
Thanks for advice
