RTBH telemetry
ehaparna
RTBH usecase advocates collecting telemetry on dropped sessions by cause.
 Rfc5635#section-3.2  refers to this practice as collecting telemetry
 Cisco blackhole Whitepaper @page=25  referees to this practice as "Regionalized" RTBH
The above references advocate using multiple blackhole addresses.
ip route 192.0.2.1 255.255.255.255 null 0
ip route 192.0.2.2 255.255.255.255 null 0
etc.
And setting in the blocking device for each trigger community a different next hop
e.g.
match tag 66
set ip next-hop 192.0.2.1
set local-preference 200
match tag 67
set ip next-hop 192.0.2.2
etc.
The counting on the null0 interface seems to be a single counter.
So what is the recommended way to collect telemetry for each cause?
Please advise.
fcuiller
On IOS XR based systems, null0 drops are reported in 'show cef drops' command:
RP/0/RP0/CPU0:8201-32FH#sh cef drops
Tue Aug  8 15:27:42.851 UTC
CEF Drop Statistics
Node: 0/RP0/CPU0
  Unresolved drops     packets :               0
  Unsupported drops    packets :               0
  Null0 drops          packets :               1337 <<<<<<<
  No route drops       packets :             192
  No Adjacency drops   packets :               0
  Checksum error drops packets :               0
  RPF drops            packets :               0
  RPF suppressed drops packets :               0
  RP destined drops    packets :               0
  Discard drops        packets :               0
  GRE lookup drops     packets :               0
  GRE processing drops packets :               0
  LISP punt drops      packets :               0
  LISP encap err drops packets :               0
  LISP decap err drops packets :               0
 These counters can be retrieved through Modern Driven Telemetry through following YANG models: Cisco-IOS-XR-fib-common-oper
Fred
Thank you,
I the question is more geared toward how to count per cause. There are different recursive paths resolved into null0. There is some expectation to be able to count per cause - i.e.
Path resolved through 192.0.2.1 counted seperatarly
and count resolved through 192.0.2.2 etc.
So I wonder how this can be done.
I see in SEF that it doesn't flatten the FIB - and the fact that a route is recursively resolved is shown in the FIB. So I wonder if that could be resolved by multiple instances of null0 or what is an alternative approach that addresses counting per cause - i.e. per traffic resolved through each of the BH addresses.
