Running configuration backup
Marks Maslovs
As I understand for running config backup I should use such command:
configuration commit auto-save filename ftp://asrbck:asrbck@11.11.11.11/ASR9k-1
Yes, it works indeed, the running configuration is copied to the ftp server, but the problem is that old configuration file on the ftp is overwritten.
I am wondering is it possible to configure asr such way, that it would create config backup files with different names? For example, adding current date and time to name of the file. (ASR9k-1_05_09_2012_09_34_20)
Thank You in advance!
2 Accepted Solutions
Alexei Kiritchenko
Hi Marks,
Unfortunately ASR won’t do auto naming.
As a possible workaround you may have a script on a server renaming such files when they arrive.
If the goal is to know what got changed, you can use “show configuration rollback changes….” and if needed to go back in time use “rollback configuration…” without a need to safe full config every time.
/A
yes, it is persistent through reloads.
/A
Alexei Kiritchenko
Hi Marks,
/A
Hi Alexei,
Thank You very much for Your response!
I believe that we will use script to rename files.
By the way, in case of asr restart will history of config. changes be available for show configuration rollback changes... and
rollback configuration… commands?
/A
That's great! Thank You!
