smartlicense on XR devices - certificate issue
I have an on prem server up and running
It appears that the only way I can get a successful registration is to disable crl revocation check - this sounds wrong, even if it appears to be documented in some cisco guides.
So I need some help with some questions:
  • Is it indeed correct approach (on both IOS-XE and IOS-XR) to disable crl revocation check, and if so, is this not a security issue/breach ?
  • I can disable crl check in IOS-XE under the SLA-trustpoint in global config, but cant seem to find a way to do it on XR - assuming it is correct to disable crl check
My config as follows
call-home
service active
contact smart-licensing
profile CiscoTAC-1
active
destination address http https://onprem-fqdn/Transportgateway/services/RouterRequestHandler
destination transport-method email disable
destination transport-method http
http client source-interface ipv4 Loopback0
license smart flexible-consumption enable
thanks for your help
Mark
balaji.bandi
the config seems to be correct, what is the issue? does the device not able to get License from CSSM ?
BB
thanks for the response - the issue should be fairly clear in my original post but let me know if you need further detail
Mark
