Storm Control Drops on VFI Pseudowires
jmoody
I'm having trouble understanding why I would be seeing Storm Control drops on a VFI pseudowire under a l2vpn bridge domain. This is an ASR 9010 router running IOS XR version 5.3.3. From everything that I've read, Storm Control is unsupported for VFI pseudowires, as there is no option to configure it. Despite that, there are counters for it when looking at the bridge domain details. I know you're able to configure it globally within the bridge domain (which should encompass everything in it), but this particular bridge domain doesn't have storm control enabled (although it is setup on one of the AC's within it).
If you look at the output below, you will see that Storm control is clearly disabled for the bridge domain, so how is this possible?
Bridge group: 16951, bridge-domain: 16951, id: 250, state: up, ShgId: 0, MSTi: 0
Coupled state: disabled
MAC learning: enabled
MAC withdraw: enabled
MAC withdraw for Access PW: enabled
MAC withdraw sent on: bridge port down (legacy)
MAC withdraw relaying (access to access): disabled
Flooding:
Broadcast & Multicast: enabled
Unknown unicast: enabled
MAC aging time: 300 s, Type: inactivity
MAC limit: 5000, Action: limit, no-flood, Notification: syslog
MAC limit reached: no
MAC port down flush: enabled
MAC Secure: enabled, Logging: enabled, Action: none
Split Horizon Group: none
Dynamic ARP Inspection: disabled, Logging: disabled
IP Source Guard: disabled, Logging: disabled
DHCPv4 snooping: disabled
IGMP Snooping: enabled
IGMP Snooping profile: none
MLD Snooping profile: none
Storm Control: disabled
Bridge MTU: 9000
MIB cvplsConfigIndex: 251
Filter MAC addresses:
P2MP PW: disabled
Create time: 05/03/2019 10:22:45 (2w6d ago)
No status change since creation
ACs: 1 (1 up), VFIs: 1, PWs: 4 (3 up), PBBs: 0 (0 up)
PW: neighbor [Omitted-1], PW ID 16952, state is up ( established )
PW class EoMPLS, XC ID 0xc000045e
Encapsulation MPLS, protocol LDP
Source address [Omitted-1]
PW type Ethernet, control word enabled, interworking none
Sequencing not set
PW Status TLV in use
MPLS Local Remote
Label 289924 158
Group ID 0xfa 0x0
Interface 16951 unknown
MTU 9000 9000
Control word enabled enabled
PW type Ethernet Ethernet
VCCV CV type 0x2 0x2
(LSP ping verification) (LSP ping verification)
VCCV CC type 0x7 0x3
(control word) (control word)
(router alert label) (router alert label)
(TTL expiry)
Incoming Status (PW Status TLV):
Status code: 0x0 (Up) in Notification message
MIB cpwVcIndex: 3221226590
Last time status changed: 05/03/2019 10:22:45 (2w6d ago)
MAC withdraw messages: sent 0, received 6
Static MAC addresses:
Statistics:
packets: received 4082631 (unicast 4082608), sent 5587326
bytes: received 4138600097 (unicast 4138598429), sent 1136882733
MAC move: 2
Storm control drop counters:
packets: broadcast 0, multicast 114, unknown unicast 0
bytes: broadcast 0, multicast 12885, unknown unicast 0
l2vpn
bridge group 16951
bridge-domain 16951
mac
aging
time 300
withdraw state-down
limit
maximum 5000
action no-flood
secure
action none
logging
mtu 9000
interface Bundle-Ether901.223
storm-control unknown-unicast pps 6000
storm-control multicast pps 6000
storm-control broadcast pps 200
vfi 16951
vpn-id 16951
autodiscovery bgp
rd auto
route-target 26554:16951
control-word
neighbor [Ommited-1] pw-id 16952
pw-class EoMPLS
neighbor [Ommited-2] pw-id 16952
pw-class EoMPLS
0 Replies 0
