ASR 920 Subinterface dot1.q
I cannot add a subinterface on a port-channel on a asr920
I want to double tag vlan on an interface for my connection to my client. The LACP works fine but now i need double vlans on this interface.
How does this work on ASR???
interface Port-channel1.1
encapsulation dot1q 10 second-dot1q 8
ip address 10.7.7.2 255.255.255.0
description *****  A1 ******
no ip address
no negotiation auto
interface GigabitEthernet0/0/0
no ip address
no negotiation auto
channel-group 1 mode active
interface GigabitEthernet0/0/1
no ip address
no negotiation auto
Hello Raimund,
In ASR920 the keywork for L3 bridge domain interface is "BDI". So try this please :
no ip address
no negotiation auto
service instance 1 ethernet
rewrite ingress tag pop 2 symmetric
bridge-domain 1
interface BDI 1
end
Best Regards,
Michalis
6 Replies 6
The ASR 920 uses the EVC framework for this kind of termination. Please have a look at https://www.cisco.com/c/en/us/td/docs/routers/asr920/configuration/guide/ce/b_ce_xe-313s-asr920-book/b_ce_xe-313s-asr920-book_chapter_01.html
For this specific scenario, something like this would work:
no ip address
no negotiation auto
bridge-domain 1
interface BVI 1
end
I cannto add the bvI interface. i got this message
Bridge group 1 is not configured
I think there is something missing?
best regards
Deepak Kumar
The sub-interface behavior shall be achieved by creating service instances/BDIs under the physical interfaces as below.
rewrite ingress tag pop 1 symmetric
bridge-domain 10
end
interface BDI 10
end
https://www.cisco.com/c/en/us/td/docs/routers/asr920/configuration/guide/ce/b_ce_xe-313s-asr920-book/b_ce_xe-313s-asr920-book_chapter_01100.html
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
i cannot add a subinterface on port-channel
interface port-channel1.1
% Invalid input detected at '^' marker.
best regards
Hello Raimund,
no ip address
no negotiation auto
bridge-domain 1
interface BDI 1
end
Best Regards,
Michalis
Thanks it works fine
Best regards
