12-01-2020 10:56 AM - edited 12-01-2020 11:11 AM
Im facing the below issue with event manager and script execution.
RP/0/RSP0/CPU0:Dec 1 14:32:43.051 UTC: eem_server[262]: %HA-HA_EM-6-FMS_POLICY_TIMEOUT : Policy 'LINK_DOWN_20249725.tcl' has hit its maximum execution time of 80.000000000 seconds, and so has been halted
Im using the event manager in order to shutdown a subinterface when a track is down. The script is working properly working on a cisco ASR-9001 Version 6.7.1 whilst is not working on a Cisco ASR-9901 (asr9k-x64) Version 7.0.2. Please find below the script and the router configuration:
Router config:
event manager environment _syslog_pattern .*(syslog reading)
event manager directory user policy disk0:scripts
no event manager policy LINK_UP_.tcl username eem persist-time 3600
no event manager policy LINK_DOWN_.tcl username eem persist-time 3600
aaa authorization eventmanager default local
username eem
group root-system (group root-lr on ASR-9901)
group cisco-support
Scripts Attached
12-02-2020 08:03 AM
Here is an example of a script that searches the logs for a match.
you can use this as a template. it was created by one of our TAC engineers @vyashin
This TCL script should be scheduled for execution on IOS XR router. It will automatically collect a few "show" commands outputs and save them into a text file for offline analysis. The script is triggered by a syslog message matching the following expression: LINK-3-UPDOWN.*TenGigE0/1/0/0.*Down Outputs being collected by the script: terminal length 0 admin show install active summary admin show platform admin show inventory dir harddisk:/dumper sh proc cpu loc 0/0/cpu0 | ex " 0% " show run show log Here is how to install the script: - Check whether you already have a script directory to store the event manager scripts: dir harddisk:/scripts location 0/RSP0/CPU0 dir harddisk:/scripts location 0/RSP1/CPU0 If the directories do not exist, create them: mkdir harddisk:/scripts location 0/RSP0/CPU0 mkdir harddisk:/scripts location 0/RSP1/CPU0 - Copy the script from your tftp or ftp server into this directory (or the one which was already configured) on each RSP: copy tftp://server/path/script.tcl harddisk:/scripts location 0/RSP0/CPU0 copy tftp://server/path/script.tcl harddisk:/scripts location 0/RSP1/CPU0 - Verify that the script directory is already configured: show run | i event manager directory If it's not configured yet: config t event manager directory user policy harddisk:/scripts commit end - Set all environment variables (if any are used by the script and instructed by Cisco) conf t event manager environment _cron_entry 0-59/2 0-23/1 * * 0-7 commit end - Configure authentication for EEM config t username event_manager_user group root-system group cisco-support aaa authorization eventmanager default local aaa authorization commands eem-method none vty-pool eem 100 105 line-template eem-template line template eem-template authorization commands eem-method ! commit - Enable the script: conf t event manager policy script.tcl username event_manager_user commit - Once the scripts are enabled, you should monitor your syslog for strings like: RP/0/RSP0/CPU0:Dec 15 10:01:25.863 : tclsh[65894]: %HA-HA_EEM-6-ACTION_SYSLOG_LOG_INFO : script.tcl: EEM script was triggered RP/0/RSP0/CPU0:Dec 15 10:01:26.984 : tclsh[65894]: %HA-HA_EEM-6-ACTION_SYSLOG_LOG_INFO : script.tcl: Opened /harddisk:/script-log-2014121526.txt RP/0/RSP0/CPU0:Dec 15 10:01:26.985 : tclsh[65894]: %HA-HA_EEM-6-ACTION_SYSLOG_LOG_INFO : script.tcl: Executing: terminal length 0 RP/0/RSP0/CPU0:Dec 15 10:01:27.551 : tclsh[65894]: %HA-HA_EEM-6-ACTION_SYSLOG_LOG_INFO : script.tcl: Executing: admin show install active summary RP/0/RSP0/CPU0:Dec 15 10:01:31.560 : tclsh[65894]: %HA-HA_EEM-6-ACTION_SYSLOG_LOG_INFO : script.tcl: Executing: admin show platform RP/0/RSP0/CPU0:Dec 15 10:01:32.091 : tclsh[65894]: %HA-HA_EEM-6-ACTION_SYSLOG_LOG_INFO : script.tcl: Executing: admin show inventory RP/0/RSP0/CPU0:Dec 15 10:01:34.838 : tclsh[65894]: %HA-HA_EEM-6-ACTION_SYSLOG_LOG_INFO : script.tcl: Executing: dir harddisk:/dumper RP/0/RSP0/CPU0:Dec 15 10:01:35.239 : tclsh[65894]: %HA-HA_EEM-6-ACTION_SYSLOG_LOG_INFO : script.tcl: Executing: show run RP/0/RSP0/CPU0:Dec 15 10:01:37.343 : tclsh[65894]: %HA-HA_EEM-6-ACTION_SYSLOG_LOG_INFO : script.tcl: Executing: show log RP/0/RSP0/CPU0:Dec 15 10:03:52.053 : tclsh[65894]: %HA-HA_EEM-6-ACTION_SYSLOG_LOG_INFO : script.tcl: File closed, script execution has finished. The script should be shown as registered in the system with corresponding trigger: RP/0/RSP0/CPU0:kasos#show event manager policy registered Mon Dec 15 10:10:05.828 UTC No. Class Type Event Type Trap Time Registered Name 1 script user syslog Off Mon Dec 15 10:01:22 2014 script.tcl pattern {%MGBL-CONFIG-6-DB_COMMIT} nice 0 queue-priority normal maxrun 600.000 scheduler rp_primary Secu none persist_time: 3600 seconds, username: event_manager_user - Each time the script is called, there will be a new debug file under the harddisk: RP/0/RSP0/CPU0:lan-9000-2#dir harddisk: | i script-log 179299 -rw- 38220 Tue Jan 10 18:12:22 2012 script-log-2012011022.txt 179300 -rw- 38221 Tue Jan 10 18:15:56 2012 script-log-2012011056.txt 179301 -rw- 39178 Tue Jan 10 18:23:20 2012 script-log-2012011020.txt RP/0/RSP0/CPU0:lan-9000-2# - Please refer to a configuration guide for EEM if you need more information: http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r5-2/system_monitoring/configuration/guide/b_sysmon_cg52xasr9k/b_sysmon_cg52xasr9k_chapter_011.html ==== File script.tcl: ==== ::cisco::eem::event_register_syslog pattern "LINK-3-UPDOWN.*TenGigE0/1/0/0.*Down" maxrun_sec 600 namespace import ::cisco::eem::* namespace import ::cisco::lib::* set commands [ list \ "terminal length 0" \ "admin show install active summary" \ "admin show platform" \ "admin show inventory" \ "dir harddisk:/dumper" \ "sh proc cpu loc 0/0/cpu0 | ex \" 0% \"" \ "show run" \ "show log" \ ] # Script body # tkarnani@cisco.com # # errorInf gets set by namespace if any of the auto_path directories do not # contain a valid tclIndex file. It is not an error just left over stuff. # So we set the errorInfo value to null so that we don't have left # over errors in it. # set errorInfo "" action_syslog priority info msg "EEM script was triggered" # Open CLI # if [catch {cli_open} result] { error $result $errorInfo } else { array set cli $result } #Run cmds set tdate [clock format [clock seconds] -format %Y%m%d%H%M%S] set filename [format "/harddisk:/script-log-%s.txt" $tdate] set outfile [open $filename w] action_syslog priority info msg "Opened $filename" foreach cmd $commands { action_syslog priority info msg "Executing: $cmd" puts $outfile " +===============================================+ " puts $outfile [ cli_exec $cli(fd) $cmd ] } # Close the CLI connection cli_close $cli(fd) $cli(tty_id) close $outfile action_syslog priority info msg "File closed, script execution has finished."
12-02-2020 11:06 AM
Hi @tkarnani ,
Thanks for your reply. As i mentioned i have successfully tested the script on an ASR-9001 Version 6.7.1. The issue is appearing on the Cisco ASR-9901 (asr9k-x64) Version 7.0.2 which is newer version and 64 bit architecture. Also note that there is no option for group root-system but group root-lr on ASR-9901. After some tests i noticed that the script stops at the commit command. Seems that the event manager is somehow has no permissions to execute the commit command. Also after some reading of the event manager logs i also found the below error:
eem/pd/evt 0/RSP0/CPU0 t30233 jobid:95769, fh_c_main_iox.c-610, Got reply for msg:, FH_MSG_EVENT_REGISTER_CHKPT, 'Embedded Event Manager' detected the 'fatal' condition 'could not find key' (err:-1345057280)
