05-25-2022 04:44 PM
i configure unified mpls in core network , trace & ping mpls is fine for ipv4 but not for ipv6
in BGP i receive bgp ipv6 label unicast update normal trace for ipv6 is fine it show label in path
but when used traceroute mpls ipv6 , its not fine & output is Q letter as result of trace
I used IOS-XR
Solved! Go to Solution.
05-26-2022 10:09 AM
Hi @saif ,
MPLS oam is used to test the MPLS data plane. MPLS oam using IPv6 will not work unless you configure LDPv6 or SR MPLS in the core.
RP/0/0/CPU0:PE2#traceroute mpls ipv6 2001:db8:12ff::1/128
Thu May 26 16:26:05.026 UTC
Tracing MPLS Label Switched Path to 2001:db8:12ff::1/128, timeout is 2 seconds
Codes: '!' - success, 'Q' - request not sent, '.' - timeout,
'L' - labeled output interface, 'B' - unlabeled output interface,
'D' - DS Map mismatch, 'F' - no FEC mapping, 'f' - FEC mismatch,
'M' - malformed request, 'm' - unsupported tlvs, 'N' - no rx label,
'P' - no rx intf label prot, 'p' - premature termination of LSP,
'R' - transit router, 'I' - unknown upstream index,
'X' - unknown return code, 'x' - return code 0
0 2001:db8:12ff:34::4 MRU 1500 [Labels: 24004 Exp: 0]
L 1 2001:db8:12ff:34::3 MRU 1500 [Labels: 24004 Exp: 0] 20 ms
L 2 2001:db8:12ff:23::2 MRU 1500 [Labels: implicit-null Exp: 0] 20 ms
! 3 2001:db8:12ff:12::1 30 ms
RP/0/0/CPU0:PE2#
05-26-2022 10:09 AM
Hi @saif ,
RP/0/0/CPU0:PE2#
05-26-2022 10:19 AM
Hi sir
kindly you do mean we need to activate ipv6 address family
in mpls ldp
as below
mpls ldp
address- family ipv6
05-26-2022 10:57 AM
Hi @saif ,
Yes, that is correct.
mpls ldp
address-family ipv6
interface GigabitEthernet0/0/0/0
address-family ipv6
