trust dscp
cisco_lad2004
Level 5
Level 5
dear all,
What is the default behaviour on CRS nodes when it comes to incoming packets,  is packets marking trusted or maked down ?
I tested trusting via policy map, but option was not available to trust. Is there a similar command to IOS to explicitly trust dscp or cos ?
TIA
Samir
Alexei Kiritchenko
Hello Samir,
That should be CRS default behavior.
Transition               Behavior
COS > L2VPN         .1p bits are copied into EXP
L2VPN > COS         No copy by default. Default value of 0 is imposed in .1p field
IP to MPLS          IP Precedence value copied to MPLS EXP
MPLS to IP          No copy down behavior
PHP                 EXP bit not copied to bottom label
You can follow “DiffServ Tunneling Modes for MPLS Networks” document for more details on DiffServ in MPLS implementation.  It is written for IOS, but the approach is the same.
http://www.cisco.com/en/US/tech/tk436/tk428/technologies_tech_note09186a008022ad7e.shtml
/A
Alexei Kiritchenko
Hello Samir,
Transition               Behavior
/A
Many thanks for the confirmation !
Samir
