Two A9Ks directly connected cannot communicate with each other
Yang Li
Model: A9K-9010-RSP-440SE  LINE CARD  A9K-24x10GE-TR (IGW-02)
Model: A9K-9010-RSP-440SE  LINE CARD  A9K-24x10GE-SE (BNG-01)
P/0/RSP0/CPU0:IGW-02#sho controllers tenGigE 0/4/0/16 phy
Wed Dec 14 16:57:09.889 YGN
PHY data for interface: TenGigE0/4/0/16
SFP EEPROM port: 16
Xcvr Type: SFP
Xcvr Code: SFP-10G-LR
Encoding: 64B66B
Bit Rate: 10300 Mbps
Link Reach 9u fiber (Km): 10000 meter
Link Reach 9u fiber (100m): 10000 meter
Vendor Name: OEM
Vendor OUI: 00.00.00
Vendor Part Number: SFP+-LR (rev.: A )
Laser wavelength: 1310 nm (fraction: 0.00 nm)
Optional SFP Signal: Tx_Disable, Tx_Fault, LOS
Vendor Serial Number: 2204060222
Date Code (yy/mm/dd): 22/04/06 lot code:
Diagnostic Monitoring: DOM, Int. Cal.,
Enhanced Options: SW RX LOS Mon., SW TX Fault Mon, SW TX Disable, Alarm/Warning Flags
MSA Data
0x0000: 03 04 07 20 00 00 00 00 : 00 00 00 06 67 00 0a 64
0x0010: 00 00 00 00 4f 45 4d 20 : 20 20 20 20 20 20 20 20
0x0020: 20 20 20 20 00 00 00 00 : 53 46 50 2b 2d 4c 52 20
0x0030: 20 20 20 20 20 20 20 20 : 41 20 20 20 05 1e 00 4d
0x0040: 00 1a 00 00 32 32 30 34 : 30 36 30 32 32 32 20 20
0x0050: 20 20 20 20 32 32 30 34 : 30 36 20 20 68 f0 03 97
0x0060: 00 00 11 32 f0 03 6e d5 : cb 16 2e e6 7b e0 5c 68
0x0070: b1 73 f1 00 00 00 00 00 : 00 00 00 00 fe 88 77 cf
Thresholds: Alarm High Warning High Warning Low Alarm Low
Temperature: +95.000 C +85.000 C -40.000 C -50.000 C
Voltage: 3.600 Volt 3.500 Volt 3.100 Volt 3.000 Volt
Bias: 80.000 mAmps 75.000 mAmps 15.000 mAmps 10.000 mAmps
Transmit Power: 1.77830 mW (2.50005 dBm) 1.12200 mW (0.49993 dBm) 0.15140 mW (-8.19874 dBm) 0.09550 mW (-10.19997 dBm)
Receive Power: 1.77830 mW (2.50005 dBm) 1.12200 mW (0.49993 dBm) 0.03630 mW (-14.40093 dBm) 0.02290 mW (-16.40165 dBm)
Temperature: 26.000
Voltage: 3.233 Volt
Tx Bias: 42.780 mAmps
Tx Power: 0.69770 mW (-1.56331 dBm)
Rx Power: 0.16080 mW (-7.93714 dBm)
Oper. Status/Control: Soft Rx Rate Select,
EEPROM Memory (A2 lower)
0x0100: 5f 00 ce 00 55 00 d8 00 : 8c a0 75 30 88 b8 79 18
0x0110: 9c 40 13 88 92 7c 1d 4c : 45 77 03 bb 2b d4 05 ea
0x0120: 45 77 00 e5 2b d4 01 6b : 00 00 00 00 00 00 00 00
0x0130: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
0x0140: 00 00 00 00 3f 80 00 00 : 00 00 00 00 01 00 00 00
0x0150: 01 00 00 00 01 00 00 00 : 01 00 00 00 00 00 00 21
0x0160: 1a 00 7e 4e 53 8e 1b 41 : 06 48 00 00 00 00 08 00
0x0170: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 01
CLEI Code: COUIAR5CAA
Part Number: 10-2457-03 (ver.: V03 )
Temp/Alarm/Power Flags: COM, commercial 0C to 70C
Minimum Temperature: 0
Maximum Temperature: 70
Calibration Constants:
Product Id: SFP-10G-LR
EEPROM Memory (A2 upper)
0x0180: 43 4f 55 49 41 52 35 43 : 41 41 31 30 2d 32 34 35
0x0190: 37 2d 30 33 56 30 33 20 : 01 00 46 00 00 00 00 cd
0x01a0: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
0x01b0: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 aa aa
0x01c0: 53 46 50 2d 31 30 47 2d : 4c 52 20 20 20 20 20 20
0x01d0: 20 20 20 20 31 30 00 00 : 00 00 00 00 00 00 00 2a
0x01e0: 15 1a 20 24 2a 30 20 30 : 00 00 00 00 00 00 00 00
0x01f0: 00 00 00 00 00 1d 00 00 : 00 00 00 00 00 00 00 00
RP/0/RSP0/CPU0:IGW-02# sho controllers tenGigE 0/4/0/16 stats
Wed Dec 14 16:57:18.119 YGN
Statistics for interface TenGigE0/4/0/16 (cached values):
Ingress:
Input total bytes = 0
Input good bytes = 0
Input total packets = 0
Input 802.1Q frames = 0
Input pause frames = 0
Input pkts 64 bytes = 0
Input pkts 65-127 bytes = 0
Input pkts 128-255 bytes = 0
Input pkts 256-511 bytes = 0
Input pkts 512-1023 bytes = 0
Input pkts 1024-1518 bytes = 0
Input pkts 1519-Max bytes = 0
Input good pkts = 0
Input unicast pkts = 0
Input multicast pkts = 0
Input broadcast pkts = 0
Input drop overrun = 0
Input drop abort = 0
Input drop invalid VLAN = 0
Input drop invalid DMAC = 0
Input drop invalid encap = 0
Input drop other = 0
Input error giant = 0
Input error runt = 0
Input error jabbers = 0
Input error fragments = 0
Input error CRC = 0
Input error collisions = 0
Input error symbol = 0
Input error other = 0
Input MIB giant = 0
Input MIB jabber = 0
Input MIB CRC = 0
Egress:
Output total bytes = 1860
Output good bytes = 1860
Output total packets = 31
Output 802.1Q frames = 0
Output pause frames = 0
Output pkts 64 bytes = 31
Output pkts 65-127 bytes = 0
Output pkts 128-255 bytes = 0
Output pkts 256-511 bytes = 0
Output pkts 512-1023 bytes = 0
Output pkts 1024-1518 bytes = 0
Output pkts 1519-Max bytes = 0
Output good pkts = 31
Output unicast pkts = 0
Output multicast pkts = 0
Output broadcast pkts = 31
Output drop underrun = 0
Output drop abort = 0
Output drop other = 0
Output error other = 0
RP/0/RSP0/CPU0:IGW-02# sh int tenGigE 0/4/0/16
Wed Dec 14 16:57:28.588 YGN
TenGigE0/4/0/16 is up, line protocol is up
Interface state transitions: 3
Hardware is TenGigE, address is a80c.0d71.e920 (bia a80c.0d71.e920)
Layer 1 Transport Mode is LAN
Internet address is 2.2.2.2/30
MTU 1500 bytes, BW 10000000 Kbit (Max: 10000000 Kbit)
reliability 255/255, txload 0/255, rxload 0/255
Encapsulation ARPA,
Full-duplex, 10000Mb/s, link type is force-up
output flow control is off, input flow control is off
Carrier delay (up) is 10 msec
loopback not set,
Last link flapped 00:31:18
ARP type ARPA, ARP timeout 04:00:00
Last input never, output 00:10:28
0 packets input, 0 bytes, 0 total input drops
0 drops for unrecognized upper-level protocol
Received 0 broadcast packets, 0 multicast packets
0 runts, 0 giants, 0 throttles, 0 parity
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
31 packets output, 1860 bytes, 0 total output drops
Output 31 broadcast packets, 0 multicast packets
0 output errors, 0 underruns, 0 applique, 0 resets
5 carrier transitions
RP/0/RSP0/CPU0:IGW-02#ping 2.2.2.1
Wed Dec 14 16:57:42.308 YGN
Sending 5, 100-byte ICMP Echos to 2.2.2.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
RP/0/RSP0/CPU0:IGW-02#sh arp
Wed Dec 14 16:58:01.683
0/4/CPU0
Address Age Hardware Addr State Type Interface
2.2.2.2 - a80c.0d71.e920 Interface ARPA TenGigE0/4/0/16
0/0/CPU0
10.0.0.1 00:00:22 10f3.114b.ec33 Dynamic ARPA Bundle-Ether1
10.0.0.2 - 10f3.114b.b9e3 Interface ARPA Bundle-Ether1
10.0.0.9 - 10f3.114b.b9e2 Interface ARPA Bundle-Ether2
10.0.0.10 03:03:45 0896.ad2d.9dd2 Dynamic ARPA Bundle-Ether2
--------------------------------PEER-----------------------------------------
RP/0/RSP1/CPU0:BNG-01#show controllers tenGigE 0/0/0/15 phy
Wed Dec 14 16:59:04.687 YGN
PHY data for interface: TenGigE0/0/0/15
SFP EEPROM port: 15
Xcvr Type: SFP
Encoding: 64B66B
Vendor Name: XYT
Vendor OUI: 00.0b.40
Vendor Part Number: XYT-SFP+LR (rev.: V02 )
Vendor Serial Number: FOR2007020004
Date Code (yy/mm/dd): 20/07/02 lot code:
MSA Data
0x0010: 00 00 00 00 58 59 54 20 : 20 20 20 20 20 20 20 20
0x0020: 20 20 20 20 00 00 0b 40 : 58 59 54 2d 53 46 50 2b
0x0030: 4c 52 20 20 20 20 20 20 : 56 30 32 20 05 1e 00 98
0x0040: 00 1a 00 00 46 4f 52 32 : 30 30 37 30 32 30 30 30
0x0050: 34 20 20 20 32 30 30 37 : 30 32 20 20 68 f0 03 16
0x0060: 00 00 08 aa 3e 01 f2 ec : 87 ec 3e cf 31 24 bc c7
0x0070: a7 98 20 00 e6 00 00 00 : 00 00 da c2 95 2a 4d 64
Temperature: +95.000 C +85.000 C -40.000 C -45.000 C
Voltage: 3.600 Volt 3.500 Volt 2.800 Volt 2.700 Volt
Bias: 100.000 mAmps 95.000 mAmps 2.000 mAmps 1.000 mAmps
Transmit Power: 1.58490 mW (2.00002 dBm) 1.25890 mW (0.99991 dBm) 0.15140 mW (-8.19874 dBm) 0.12020 mW (-9.20096 dBm)
Receive Power: 1.25890 mW (0.99991 dBm) 1.00000 mW (0.00000 dBm) 0.00790 mW (-21.02373 dBm) 0.00500 mW (-23.01030 dBm)
Temperature: 35.496
Voltage: 3.355 Volt
Tx Bias: 19.312 mAmps
Tx Power: 0.64020 mW (-1.93684 dBm)
Rx Power: 0.11820 mW (-9.27383 dBm)
0x0100: 5f 00 d3 00 55 00 d8 00 : 8c a0 69 78 88 b8 6d 60
0x0110: c3 50 01 f4 b9 8c 03 e8 : 3d e9 04 b2 31 2d 05 ea
0x0120: 31 2d 00 32 27 10 00 4f : ff ff ff ff ff ff ff ff
0x0130: ff ff ff ff ff ff ff ff : 00 00 00 00 00 00 00 00
0x0150: 01 00 00 00 01 00 00 00 : 01 00 00 00 ff ff ff a0
0x0160: 23 7f 83 0a 25 b8 19 02 : 04 9e ff ff ff ff 08 ff
0x0170: 00 00 00 20 00 00 ff ff : ff ff ff ff ff ff ff 01
CLEI Code: d
Part Number: m`ˆ¸qHÖØ^Aô (ver.: )
Minimum Temperature: -23
Maximum Temperature: 6
Product Id:
0x0180: 64 00 d8 00 5f 00 dd 00 : 8c a0 6d 60 88 b8 71 48
0x0190: d6 d8 01 f4 c3 50 03 e8 : 3d e9 06 31 31 2d 07 cb
0x01a0: 4d f1 00 73 27 10 00 e5 : 00 00 00 00 00 00 00 00
0x01b0: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
0x01c0: 00 00 00 00 3f 80 00 00 : 00 00 00 00 01 00 00 00
0x01d0: 01 00 00 00 01 00 00 00 : 01 00 00 00 00 00 00 28
0x01e0: 0e e8 6e d0 38 7c 17 8c : 00 01 00 00 00 00 02 00
0x01f0: 00 40 00 00 10 40 00 00 : 00 00 00 ff ff ff ff 00
RP/0/RSP1/CPU0:BNG-01#show controllers tenGigE 0/0/0/15 stats
Wed Dec 14 16:59:10.402 YGN
Statistics for interface TenGigE0/0/0/15 (cached values):
Ingress:
Input total bytes = 737153
Input good bytes = 737153
Input total packets = 5786
Input pkts 64 bytes = 1745
Input pkts 65-127 bytes = 3372
Input pkts 128-255 bytes = 182
Input pkts 256-511 bytes = 487
Input good pkts = 5786
Input unicast pkts = 105
Input multicast pkts = 4212
Input broadcast pkts = 1469
Input error CRC = 0
Input MIB giant = 0
Input MIB CRC = 0
Egress:
Output total bytes = 30716
Output good bytes = 30716
Output total packets = 300
Output pkts 64 bytes = 66
Output pkts 65-127 bytes = 234
Output good pkts = 300
Output unicast pkts = 40
Output multicast pkts = 194
Output broadcast pkts = 66
RP/0/RSP1/CPU0:BNG-01#sh int te 0/0/0/15
Wed Dec 14 16:59:21.115 YGN
TenGigE0/0/0/15 is up, line protocol is up
Interface state transitions: 99
Hardware is TenGigE, address is 00c1.6440.b97f (bia 00c1.6440.b97f)
Internet address is 2.2.2.1/30
Encapsulation ARPA,
loopback not set,
Last link flapped 00:33:10
Last input 00:01:28, output 5d11h
Last clearing of "show interface" counters 5d13h
5786 packets input, 737153 bytes, 0 total input drops
Received 1469 broadcast packets, 4212 multicast packets
300 packets output, 30716 bytes, 0 total output drops
Output 66 broadcast packets, 194 multicast packets
58 carrier transitions
RP/0/RSP1/CPU0:BNG-01#ping vrf port_test 2.2.2.2
Wed Dec 14 16:59:33.580 YGN
Sending 5, 100-byte ICMP Echos to 2.2.2.2, timeout is 2 seconds:
RP/0/RSP1/CPU0:BNG-01#sh arp
Wed Dec 14 16:59:51.849 YGN
0/0/CPU0
10.0.0.5 01:19:36 10f3.114b.ec32 Dynamic ARPA Bundle-Ether2
10.0.0.6 - 40ce.2423.515b Interface ARPA Bundle-Ether2
10.0.0.13 - 40ce.2423.515a Interface ARPA Bundle-Ether1
10.0.0.14 01:36:18 0896.ad2d.9dd3 Dynamic ARPA Bundle-Ether1
.ılı..ılı.
Cisco System
Pyhton
U got a dream, U gotta protect it
philclemens1835
Looks like you're using non-Cisco SFP's. Try adding this line to your interface configs:
transceiver permit pid all
hello transceiver permit pid all this command  ? Is it configured under the interface?
.ılı..ılı.
Cisco System
Pyhton
config it also same
.ılı..ılı.
Cisco System
Pyhton
