Understand STM-1interface on ASR 1006 IOS 15
hey ,i configured a chanalized STM-1 on 7609-s router with no problem,the think is when i configured on ASR 1006 it's not the same result of interfaces maybe because 1006 run IOS 15,i try to un derstand how it work
Router#show version
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version
15.0(1)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 28-Jul-10 21:34 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2010 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 22 minutes
Uptime for this control processor is 24 minutes
System returned to ROM by reload
--More--
*Apr  8 06:10:09.812: %SYS-5-CONFIG_I: Configured from console System image file
is "bootflash:/asr1000rp1-adventerprisek9.03.01.00.S.150-1.S.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR1006 (RP1) processor with 1717513K/6147K bytes of memory.
5 Gigabit Ethernet interfaces
5 Serial interfaces
1 Channelized STM-1 port
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
937983K bytes of eUSB flash at bootflash:.
39004543K bytes of SATA hard disk at harddisk:.
Router#
this is the STM-1 example config
controller SONET 0/0/0
framing sdh
clock source line
aug mapping au-4
au-4 1 tug-3 1
  mode c-12
  tug-2 1 e1 1 channel-group 0 timeslots 1-16
  tug-2 1 e1 1 channel-group 1 timeslots 17-31
  tug-2 1 e1 2 unframed
  tug-2 1 e1 3 unframed
  tug-2 2 e1 1 unframed
au-4 1 tug-3 2
  mode c-12
au-4 1 tug-3 3
  mode c-12
and the result :
interface Serial0/0/0.1/1/1/1:0
no ip address
interface Serial0/0/0.1/1/1/1:1
no ip address
interface Serial0/0/0.1/1/2/1:0
no ip address
interface Serial0/0/0.1/1/1/2:0
no ip address
interface Serial0/0/0.1/1/1/3:0
no ip address
whey the third unframed interface show 2 and the fourth show 1,what that mean ?
this is how it show me in 7609-s with 12.3 IOS
interface Serial1/0/0.1/1/1/1:0
interface Serial1/0/0.1/1/1/1:1
interface Serial1/0/0.1/1/1/2:0
interface Serial1/0/0.1/1/1/3:0
interface Serial1/0/0.1/1/2/1:0
After a long analyse ,i remarque that the 1006 IOS work fine,but only in the running config it sort the result in difirent way then IOS 12.4 , i don't know if it's a bug or something else.have a nice day.
