Upgrade ASR9010 from 4.3.2 to 5.3.0
Aaziz AMHAOUCH
Hi all,
We need to upgrade an ASR9010 from 4.3.2 to 5.3.0 in order to install VSM cards. We did an upgrade in a test environment and we had the same problem as in this Cisco Bug: CSCuv20072 - Software upgrade causes reboot loop: https://tools.cisco.com/quickview/bug/CSCuv20072
In order to fix this issue, we used Turboboot and we accessed CLI but when we restart the chassis it goes to reboot loop again !!
Is there any solution for this solution ?
Many thanks!
Best Regards,
Aaziz
14 Replies 14
xthuijs
Hi Aaziz, did you use the turboboot with the format option?
One thing would be the clean the bootflash and disk from all unused packages.
xander
Hi Alexander,
We used turboboot with format option and it comes up but when we restart the node the problem appears again. (router goes in reboot loop).
Thanks!
Aaziz
can you verify if there is a (wrong) image on the bootflash?
and also the boot loop, could you paste a cycle of that to see what it is going through, just to see if this is the same or different issue.
cheers
xander
oh btw, are you willing/able to run 532? 530 is the first release of 53 which then has received 2 rebuilds already to 532, it may be best use of time and investigation to be on the right release if that is possible.
xander
Hi Xander,
We tried 5.3.2 and it gives the same problem: reboot loop
BR,
Aaziz
Hi Aaziz,
I would need some logging and details to see what is going on and help identify the root cause.
xander
Hi Xander,
Thank you for your help. You can find attached logging from upgrading to 5.3.2
BR,
Aaziz
I dont think the format option worked, it seems that there are 2 boot vars and images available.
it seems to load bootloader 53 and xr image 43 that indeed will result in bad stuff.
try this first:
from rommon unset boot:
BOOT=disk0:asr9k-os-mbi-4.3.2/0x100305/mbiasr9k-rsp3.vm,1;disk0:asr9k-os-mbi-5.3.2/0x100305/mbiasr9k-rsp3.vm,2;
and reset it to BOOT=disk0:asr9k-os-mbi-5.3.2/0x100305/mbiasr9k-rsp3.vm
if no dice.
unset BOOT
TURBOBOOT=on,disk0,format
sync
and boot the vm then. that should fix your issue.
cheers
xander
Thanks Alexander, I will do it tomorrow and will get back to you.
BR,
Aaziz
Hi Alexander,
We have proceed with the steps thats you have decribes and failed to brings up the system. Kindly find bellow logs :
rommon 2 > unset BOOT
unset: "BOOT" does not exist
rommon 3 > TURBOBOOT=on,disk0,format
rommon 4 > sync
rommon 5 > mediaboot usb:\asr9k-mini-px.vm-5.3.2
boot_disk2 - Launching image.
Program load complete, Entry point: 0x40d9d8, size: 0x1e8d781d
ًَض{£I¾t…+ڑ
           éaژمَCPU reset reason = 8 (CPU_RESET_WDOG_POR)
########## Environment Variables ##########
PS1=rommon ! >
?=0
IOX_ADMIN_CONFIG_FILE=
ACTIVE_FCD=1
CLUSTER_RACK_ID=0
CLUSTER_NO_BOOT=
BOOT_DEV_SEQ_CONF=
BOOT_DEV_SEQ_OPER=
BSI=0
Total DRAM Memory: 6144 MB
MAC Address from cookie: d8:67:d9:66:d1:30
Board type: 0x00100306
Chassis type: 0x00ef02fe
Slot number: 05
Chassis serial: FOX1544GTKV
System Bootstrap, Version 0.71 [ASR9K x86 ROMMON],
Copyright (c) 1994-2012 by Cisco Systems, Inc.
Compiled on Tue 06/18/2013 22:50:54.15 by myekkar
Rommon       : 0.71
Ibex Peak    : 6
Jasper Forest: 1.0
Zen-JF       : 0.7.92
CBC0         : Part 1=16.115, Part 2=16.115, Act Part=2
Laguna       : 0.10.0 (primary)
Dao          : 1.6.0 (primary)
UTI          : 4.9   (primary)
Timex        : 0.1.1 (primary)
Board        : 4
Sending Boot Image validation request.
HIT CTRL-C to abort
----------- [CTRL-C] Boot Image validation: Premature termination
Boot Image validation aborted.
rommon 1 > priv
You now have access to the full set of monitor commands.
Warning: some commands will allow you to destroy your
configuration and/or system images and could render
the machine unbootable.
rommon 2 > diswd
Watchdog Disabled
rommon 3 >
rommon 3 >
rommon 3 >
rommon 3 > mediaboot usb:\asr9k-mini-px.vm-5.3.2
ënˆçC[د
Many thanks for your support
Best Regards
It looks like it doesn't want to turboboot.
in rommon use the command "dev" to see the mounted disk devices.
depending on where your usb is it may be:
disk1, disk2, or usb
we need to use either:
mediaboot usb:/xxx
boot usb:/xxx
boot disk2:/xxx
apologies for this hassle, it should be easier, but we'll get through it once this turboboot succeeds.
worse case, we'll do a tftp boot if the USB can't be read/used.
cheers
xander
Many Thanks for your quick feedback, usb device is recognized. Kindly refer to below logs:
rommon 1 > dir usb:
usb:\Directory of: usb:\
  10/13/15  05:11p10/13/15  05:11p <DIR>          4,096  ASR9K-iosxr-px-k9-5.3.0
  10/13/15  05:11p10/13/15  05:11p <DIR>          4,096  ASR9K-iosxr-px-5.3.2-turboboot
  10/13/15  05:14p10/13/15  05:14p          259,481,600  asr9k-vsm-cgv6-5.3.2.00.ova
  10/12/15  02:02p10/12/15  02:02p          259,420,160  asr9k-vsm-cgv6-5.3.0.00.ova
  10/13/15  05:16p10/13/15  05:16p <DIR>          4,096  ASR9K-iosxr-px-5.3.0-turboboot
  10/13/15  01:03a10/13/15  01:03a <DIR>          4,096  LOST.DIR
  09/01/15  10:29a09/01/15  10:29a          538,177,949  asr9k-mini-px.vm-5.3.2
  07/27/15  09:44a07/27/15  09:44a <DIR>         20,480  OBS DOC
  05/31/15  11:13p05/31/15  11:13p <DIR>          4,096  Visio 2003
  06/04/15  10:04p06/04/15  10:04p <DIR>          4,096  Next Wave Systems tools
  10/07/15  11:54a10/07/15  11:54a                    0  PS_Toolkits_V100R001C02SPC563.zip
  10/13/15  04:58p10/13/15  04:58p <DIR>          4,096  5.3.2
          4 File(s) 1,057,079,709 bytes
          8 Dir(s)
Best Regrads
Hi Alexander,
We used Turboboot 4.3.2 instead of 5.3.2 and it works: The node comes UP with 4.3.2 version and after that we tried again upgrade to 5.3.2 and this time it works !!
- Is there a problem on Turboboot of 5.3.0 and 5.3.2 ?
- Is it recommended to upgrade from 4.3.2 to 5.X.X directly ?
Also we will upgrade a CRS3 from 4.3.2 to 5.1.3, what is the best practice to proceed this upgrade ? the cards that exist in CRS are:
Node          Type              PLIM               State           Config State
0/0/CPU0      FP-140G           14-10GbE           IOS XR RUN      PWR,NSHUT,MON
0/1/CPU0      FP40              42-1GbE            IOS XR RUN      PWR,NSHUT,MON
0/1/0         FP40(SPA)         8X1GE              OK              PWR,NSHUT,MON
0/1/1         FP40(SPA)         5X1GE              OK              PWR,NSHUT,MON
0/1/2         FP40(SPA)         8X1GE              OK              PWR,NSHUT,MON
0/1/3         FP40(SPA)         8X1GE              OK              PWR,NSHUT,MON
0/1/4         FP40(SPA)         5X1GE              OK              PWR,NSHUT,MON
0/1/5         FP40(SPA)         8X1GE              OK              PWR,NSHUT,MON
0/2/CPU0      FP40              4-10GbE            IOS XR RUN      PWR,NSHUT,MON
0/6/CPU0      FP40              4-10GbE            IOS XR RUN      PWR,NSHUT,MON
0/7/CPU0      FP-140G           14-10GbE           IOS XR RUN      PWR,NSHUT,MON
0/RP0/CPU0    RP(Standby)       N/A                IOS XR RUN      PWR,NSHUT,MON
0/RP1/CPU0    RP(Active)        N/A                IOS XR RUN      PWR,NSHUT,MON
Best Regards,
Aaziz
One possible explanation is this. Your current rommon ver is pretty old in terms of revision. long time ago we identified an issue with tftp and all that in rommon that were related to file sizes. it could be the filesize difference between 43 and 53 that was acting up on us.
so would be good to uprev your rommon right away to the fpd levels from 53.
the easiest upgrade path is always to use the mini-pie to apply and activate that on the existing release. single reboot, that's it.
there a very few reasons to do a turboboot, which is like taking the windows install CD and upgrading from XP to 7 as instead of running XP and using the upgrade installation to get to the new ver. So turboboot is kind of like fresh installing, which sometimes is needed, but we try to prevent that as much as possible.
The upgrade guides for the platform explains which from releases we validated this new rls to and reports any gotcha's, if any.
cheers!
xander
