upgrade using install add source ftp error
MariaSousa48787
i'm trying to downgrade from 6.6.2, ios-xr(64bits- ASR9910) to 6.5.3 and it seems that the transfer it is impossible!
I've tried from ios vm and i could transfer from ftp to disk1:, so it is not problem of FTP!
Should be configured some extra commands?
here you can see the printouts:
1 -Success on IOS-XR VM:
RP/0/RSP1/CPU0:lab01-cr1#copy ftp: disk0:
Tue Feb 15 09:10:22.093 UTC
Address or name of remote host [x.x.x.x]?x.x.x.x
Source username: [anonymous]?ciscoaib
Source password:
Source filename [/ftp:]?IOSXR_6_5_3_x64_ASR9910.tar
Destination filename [/disk0:/IOSXR_6_5_3_x64_ASR9910.tar]?
Accessing ftp://ciscoaib:*@x.x.x.x/IOSXR_6_5_3_x64_ASR9910.tar
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
2. not success on xm vm
sysadmin-vm:0_RSP1# install add source ftp://ciscoaib@x.x.x.x:/ IOSXR_6_5_3_x64_ASR9910.tar
Tue Feb 15 09:17:05.767 UTC+00:00
Password:
result Tue Feb 15 09:17:16 2022 Install operation 32 (install add) started by user 'ciscoaib' will continue asynchronously.
sysadmin-vm:0_RSP1# Tue Feb 15 09:17:16 2022 Install operation 32 failed (Package download failed on node 0/RSP1 ).
3. configs on ios-xr vm
RP/0/RSP1/CPU0:lab01-cr1#sh run | in ftp
Tue Feb 15 10:24:57.615 UTC
Building configuration...
tftp vrf default ipv4 server homedir /misc/disk1
ftp client source-interface MgmtEth0/RSP1/CPU0/0
tftp client source-interface Loopback1
Thanks for all you help
Maria
smilstea
You don't need to copy to sysadmin, you can install/upgrade/downgrade from the XR vm. If you really want to copy to sysadmin it is possible but you have to specify the location as the RP and VM1, that way the system knows you are copying from XR VM to sysadmin VM. The XR and sysadmin VMs have their own partitions, both called disk0 and harddisk.
Sam
smilstea
Sam
It works!
Thank you so much!
Maria
