Want to set it up Virtual router lab with cisco vrouter
js726u
Hi Team ,
i want to set it up virtual router lab with cisco vrouter , please provide me inputs for licensing details(Inlcude costs) and iso download procedure in KVM or virtual environment.
Jayachandran S
Check the Devnet sandbox you can use this for free and it has XR labs https://devnetsandbox.cisco.com/
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
7 Replies 7
smilstea
CML has some free options of various Cisco (and other) platforms and paid tiers.
That is going to be the best supported for lab use.
There are other companies with products like gns3, containerlab, eve-ng, etc but I cannot comment or recommend those. CML is the evolution of VIRL and a Cisco product.
Sam
Hi Team ,
Thanks for the response , i need cisco eve-ng virtual router cost and licensing details to setup lab environment .
Please support !
EVE-NG is not a Cisco product, I suggest visiting their website for pricing if that is the tool you wish you use.
Sam
Hi ,
Thank You for your response . Kindly let me know virtual cisco router details which I can set it in my lab environment .
Also , provide me licensing and cost details or contact mail id .
Jay
Hi @bigevilbeard
Thanks for sharing the information, but I’m unable to open the link you provided. Could you please check it?
@rkthapa9 try using a private browser or incognito session.
