Showing results forĀ
Search instead forĀ
Did you mean:Ā
What is a difference between Predefined NAT and Bulk port allocation ?
Yanes ABDELLI
In order to track subscribers, I need to know the difference between the BPA (Bulk port allocation) and the Predefined NAT in IOS XR.
The BPA is not available in a Predifined NAT, so how can I set a range of ports for each subscriber with the corresponding Public IP address.
Thank you.
Nitin Pabbi
BPA is used for reducing logs generation by providing single predefined port for a range of ports in a sequences.
ex: 1-10 contiguous ports  will be assigned with single per-allocated port from 1-10 range of ports.
this logic help in reduce logging.
on the other hand Pr-defined NAT is a feature which maps private address to port/s and inturn to satellite public IP addresses. feature BPA cant be use with pr-defined NAT.
<<<<<< BPA is not available in a Predifined NAT, so how can I set a range of ports for each subscriber with the corresponding Public IP address.
You can;t set such port range because port range is picked randomly based on inherited algorithm in pre-defined NAT feature.
You can use below CLI to know the mapping details :-
show cgn nat44 nat1 mapping inside-address inside-vrf Inside_1 start-addr <> end-addr <>
Nitin Pabbi
Thank you very much for your reply :D
