Why "Not v4 endpoint" on SRv6 Flex-Algo?
Jbr002
Hi all,
Please give some advise!
I am trying Flex-Algo on SRv6.
But the Flex-Algo policy state is "Operational: down".
And I get "No v4 endpoint" debug log.
What is the reason? And how can I fix the issue?
Does IPv4 have relation this issue?
Status is as below.
RP/0/RP0/CPU0:xr9kv-4#show segment-routing traffic-eng policy color 101
Fri Jun 28 19:44:06.814 UTC
SR-TE policy database
Color: 101, End-point: 2001:10:129::1
  Status:
    Admin: up  Operational: down for 00:33:48 (since Jun 28 19:10:18.269)
  Candidate-paths:
    Preference: 105 (configuration) (inactive)
      Last error: SRv6 SIDs failed verification
      Requested BSID: dynamic
      Constraints:
        Prefix-SID Algorithm: 128
        Protection Type: protected-preferred
        Maximum SID Depth: 13
      Dynamic (inactive)
      Last error: Unsupported  endpoint
        Metric Type: IGP,   Path Accumulated Metric: 0
      SRv6 Information:
        Locator: algo128
        Binding SID requested: Dynamic
        Binding SID behavior: uB6 (Insert.Red)
  Attributes:
    Forward Class: 0
    Steering labeled-services disabled: no
    Steering BGP disabled: no
    IPv6 caps enable: yes
    Invalidation drop enabled: no
    Max Install Standby Candidate Paths: 0
RP/0/RP0/CPU0:xr9kv-4#debug segment-routing traffic-eng error
Fri Jun 28 19:48:36.340 UTC
RP/0/RP0/CPU0:xr9kv-4#RP/0/RP0/CPU0:Jun 28 19:48:38.482 UTC: xtc_agent[1288]: DBG-Error:xtc_policy_dynamic_flex_alg:2560 (Policy: srte_c_101_ep_2001:10:129::1 #7)  Not v4 endpoint
RP/0/RP0/CPU0:Jun 28 19:48:38.482 UTC: xtc_agent[1288]: DBG-Error:xtc_policy_dynamic_flex_alg:2680 (Policy: srte_c_101_ep_2001:10:129::1 #7)  Path computation failed
RP/0/RP0/CPU0:Jun 28 19:48:38.482 UTC: xtc_agent[1288]: DBG-Error:xtc_policy_verify_cpath:918  No valid SLs found
The node recognizes the SRv6 locators successfully.
RP/0/RP0/CPU0:xr9kv-4#show route ipv6 2001:10:1:: | include locator
  Known via "isis core", distance 115, metric 11, SRv6-locator, type level-1
RP/0/RP0/CPU0:xr9kv-4#show route ipv6 2001:10:2:: | include locator
RP/0/RP0/CPU0:xr9kv-4#show route ipv6 2001:10:3:: | include locator
RP/0/RP0/CPU0:xr9kv-4#show route ipv6 2001:10:129:: | include locator
  Known via "isis core", distance 115, metric 31, SRv6-locator (algo 128), type level-1
RP/0/RP0/CPU0:xr9kv-4#show route ipv6 2001:10:130:: | include locator
  Known via "isis core", distance 115, metric 11, SRv6-locator (algo 128), type level-1
RP/0/RP0/CPU0:xr9kv-4#show route ipv6 2001:10:131:: | include locator
  Known via "isis core", distance 115, metric 21, SRv6-locator (algo 128), type level-1
I tried explicit path too, this was no problem and packets were forwarded as I intended.
RP/0/RP0/CPU0:xr9kv-4#show segment-routing traffic-eng policy color 100
Fri Jun 28 19:51:56.020 UTC
Color: 100, End-point: 2001:10:1::1
  Status:
    Admin: up  Operational: up for 00:43:47 (since Jun 28 19:08:08.919)
  Candidate-paths:
    Preference: 100 (configuration) (active)
      Constraints:
      Explicit: segment-list 4-to-1A (valid)
        Weight: 1, Metric Type: TE
          SID[0]: 2001:10:2::/48
                  Format: f3216
                  LBL:32 LNL:16 FL:0 AL:80
          SID[1]: 2001:10:3::/48
                  Format: f3216
          SID[2]: 2001:10:1::/48
                  Format: f3216
      SRv6 Information:
        Locator: xr9kv4
    Preference: 90 (configuration) (inactive)
      Constraints:
      Explicit: segment-list 4-to-1B (inactive)
      Last error: unresolved first SID (2001:10:2::)
          SID[1]: 2001:10:1::/48
      SRv6 Information:
        Locator: xr9kv4
  Attributes:
    Binding SID: 2001:10:4:e004::
    Forward Class: Not Configured
RP/0/RP0/CPU0:xr9kv-4#show segment-routing traffic-eng forwarding policy color 100
Fri Jun 28 19:51:28.450 UTC
SR-TE Policy Forwarding database
  Active LSP:
    Candidate path:
    Segment lists:
      SL[0]:
        SL ID: 0xa000001
        Switched Packets/Bytes: ?/?
        Paths:
          Path[0]:
            Outgoing Interfaces: GigabitEthernet0/0/0/0
            Next Hop: fe80::5054:ff:fe03:0
            FRR Pure Backup: No
            ECMP/LFA Backup: No
            SID stack (Top -> Bottom): {2001:10:2::/48, 2001:10:3::/48}
  Policy Packets/Bytes Switched: ?/?
I am using XRv9000 on CML.
Configuration is below.
Fri Jun 28 20:01:49.106 UTC
!! Building configuration...
!! IOS XR Configuration 7.11.1
!! Last configuration change at Fri Jun 28 20:01:48 2024 by root123
hostname xr9kv-4
logging console disable
(snip)
vrf L3VPN
 rd 10.255.0.4:20
 address-family ipv4 unicast
  import route-target
   10.255.0.1:20
  export route-target
   10.255.0.4:20
 address-family ipv6 unicast
  import route-target
   10.255.0.1:20
  export route-target
   10.255.0.4:20
line console
 exec-timeout 0 0
 absolute-timeout 0
 session-timeout 0
line default
 exec-timeout 0 0
 absolute-timeout 0
 session-timeout 0
call-home
 service active
 contact smart-licensing
 profile CiscoTAC-1
  active
  destination transport-method email disable
  destination transport-method http
interface Loopback0
 ipv4 address 10.255.0.4 255.255.255.255
 ipv6 address 2001:10:4::4/128
interface Loopback1
 ipv4 address 10.255.0.132 255.255.255.255
 ipv6 address 2001:10:132::4/128
interface MgmtEth0/RP0/CPU0/0
 shutdown
interface GigabitEthernet0/0/0/0
 ipv6 address 2001:2:4::4/64
interface GigabitEthernet0/0/0/1
 ipv6 address 2001:3:4::4/64
interface GigabitEthernet0/0/0/2
 shutdown
interface GigabitEthernet0/0/0/3
 vrf L3VPN
 ipv4 address 192.168.1.254 255.255.255.0
 ipv6 address 2001:192:168:1::254/64
interface GigabitEthernet0/0/0/4
 ipv6 address 2001:1:4::4/64
interface GigabitEthernet0/0/0/5
 shutdown
interface GigabitEthernet0/0/0/6
 shutdown
interface GigabitEthernet0/0/0/7
 shutdown
interface GigabitEthernet0/0/0/8
 shutdown
extcommunity-set opaque COLOR_EXT_COMMUNITY_SET
  100
end-set
route-policy BGP_ROUTE_POLICY_v4
  if destination longer-than (0.0.0.0/0) then
    set extcommunity color COLOR_EXT_COMMUNITY_SET
  endif
  pass
end-policy
route-policy BGP_ROUTE_POLICY_v6
  if destination longer-than (::/0) then
  endif
  pass
end-policy
router isis core
 is-type level-1
 net 49.0000.0000.0004.00
 distribute link-state
 affinity-map BLUE bit-position 1
  metric-style wide
  advertise link attributes
  router-id Loopback0
  segment-routing srv6
   locator xr9kv4
   locator algo128
 flex-algo 128
  priority 250
  advertise-definition
  prefix-metric
  affinity exclude-any BLUE
 interface Loopback0
  passive
 interface Loopback1
  passive
  affinity flex-algo BLUE
  point-to-point
  point-to-point
  point-to-point
router bgp 100
  locator xr9kv4
   alloc mode per-vrf
 address-family vpnv4 unicast
  vrf all
    alloc mode per-vrf
   locator xr9kv4
   alloc mode per-vrf
 address-family vpnv6 unicast
  vrf all
    alloc mode per-vrf
 neighbor 2001:10:1::1
  remote-as 100
  update-source Loopback0
   encapsulation-type srv6
   route-policy BGP_ROUTE_POLICY_v4 out
   route-policy BGP_ROUTE_POLICY_v6 out
 vrf L3VPN
  rd 10.255.0.4:20
   redistribute connected
segment-routing
 traffic-eng
  srv6
   locator xr9kv4 binding-sid dynamic behavior ub6-insert-reduced
  segment-lists
   srv6
    sid-format usid-f3216
    srv6
     index 10 sid 2001:10:2::
     index 20 sid 2001:10:3::
     index 30 sid 2001:10:1::
    srv6
     index 20 sid 2001:10:1::
  policy 4-to-1
   srv6
   color 100 end-point ipv6 2001:10:1::1
   candidate-paths
    preference 90
     explicit segment-list 4-to-1B
    preference 100
     explicit segment-list 4-to-1A
  policy flex-algo
   srv6
    locator algo128 binding-sid dynamic behavior ub6-insert-reduced
   source-address ipv6 2001:10:132::4
   color 101 end-point ipv6 2001:10:129::1
   candidate-paths
    preference 105
     dynamic
      metric
       type igp
     constraints
      segments
       sid-algorithm 128
 srv6
  logging locator status
  encapsulation
   source-address 2001:10:4::4
  locators
   locator xr9kv4
    micro-segment behavior unode psp-usd
    prefix 2001:10:4::/48
   locator algo128
    prefix 2001:10:132::/48
    algorithm 128
end
Harold Ritter
Hi @Jbr002 ,
Dynamic path computation is not supported on the headend router for an SRv6 policy. You would need to either configure an explicit path or configure a PCE that would perform the computation on behalf of the headend router.
Harold Ritter
Hi @Jbr002 ,
Jbr002
Hi Ritter,
Thank you for your great advise.
I will try the way to use PCE!
You are very welcome @Jbr002 and thanks for the feedback
