Xconnect issue on BNG PW-Ether interface
WonderBoy1990
I have encountered an issue which is for me is unusual. As seen on the diagram below (example only), I have router with sub-interface Gi0/0/0/0.30 which is connected to BNG1 and BNG2 via pseudo-wire. The problem is even if I have already configured BNG2 as backup neighbor, status of xconnect is down instead of standby. What could be the possible issue?
See sample config:
R
l2vpn
xconnect group VLAN30
p2p neighbor 192.168.2.1 pw-id 30
backup neighbor 192.168.2.2 pw-id 30
BNG1
l2vpn
interface PE30
p2p neighbor 192.168.1.1 pw-id 30
BNG2
l2vpn
interface PE30
Appreciate your help.
tkarnani
we can check "show l2vpn xconnect detail" it will usually tell us a reason why the psuedowire is down.
I tried the command but there was no error message. Usually an error message appears like for example if there is an MTU mismatch.
