XR route-policy match interface
seek_1992
Hi all
I wonder if IOS XR route-policy has match statement for interfaces like route-map in regular IOS.
route-map TEST permit 10
match interface loopback0
IOS XR:
route-policy TEST
 if interface LOOPBACK0
pass
I know that we can match based on the IP address, however, I want to match based on the interface in order to keep RPL integrity when the interface IP address has changed.
 Seek
smilstea
What does match interface do? Match the next-hop or source or destination?
We do not have the ability to match interface in XR, you would need to match the next-hop, source, or destination IP address or subnet.
Sam
smilstea
Sam
Elvin Arias
I would say that doing matching based on the interface is only useful with NAT applications using route-maps, for routing-based policies, is better to be explicit by using references of prefix-lists, for example.
The Route Policy Language (RPL) in IOS-XR doesn't allow this, and you must always use other type of references. This doc can help as an intro to RPL, https://community.cisco.com/t5/service-providers-documents/asr9000-xr-understanding-and-using-rpl-route-policy-language/ta-p/3117050.
HTH,
Elvin
Hi All -
Exactly for the scenario mentioned by @Elvin Arias, I need to enable NAT from multiple "inside" interfaces to multiple "outside" interfaces on IOS-XR/ASR9K.  With IOS/ASR1K I use "match interface" within route-maps applied to the NAT statements to successfully achieve this.
Does anyone happen to know the IOS-XR equivalent to this IOS example?
route-map NAT_TEN0/0/0_MAP permit 10
 match ip address NAT_ACL
 match interface TenGigabitEthernet0/0/0
route-map NAT_TEN0/0/1_MAP permit 10
 match interface TenGigabitEthernet0/0/1
ip nat inside source route-map NAT_TEN0/0/0_MAP pool POOL_TEN0/0/0 overload
ip nat inside source route-map NAT_TEN0/0/1_MAP pool POOL_TEN0/0/1 overload
int te0/0/0
 ip nat outside
int te0/0/1
 ip nat outside
int te0/1/0
 ip nat inside
I tried to lab this in ViRL / Cisco Modeling Labs, but XRv does not seem to support NAT, presumably due to the lack of ISM/VSM module.  Although I'd love for someone to tell me I'm wrong here!
Mark Walters
Hi Mark,
on the ASR9k we will need a VSM/ISM card to process the nat translations it will not work without it.
on the newer line cards there is a feature called map-t that can be used if you have the 3rd generation tomahawk or higher
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k-r6-2/cg-nat/configuration/guide/b-cgnat-cg-asr9000-62x/b-cgnat-cg-asr9000-62x_chapter_0101.html
thanks
