xrv9k pnetlab
segooo290
hello
i have problem with ios xrv9k that can not start in pnetlab, can anyone help me to solve this problem?
5 Replies 5
taoza
xrv9k in pnetlab.
xrv9k can be startup, but the Gi0/0/0/0 interface of the router is not functioning properly and cannot connect to the external network.
Harold Ritter
Hi @taoza ,
How much ressource did you configure for each instances?
According to the PnetLab website, you need the following:
  • Cisco XRvK9 6.x.x (require source of 4xCPU and 16G RAM for single node)
Can you please do a "show platform vm" on one of the two instances and provide the output.
@Harold Ritter Thank you so much for your help.  I used the VMplayer to run the Pnetlab VM in a windows 10 Laptop PC.
I gave 24G RAM and 12 cpu cores, is it a right configuration for pnetlab to run Cisco xrvk9 7.11.1? My ios xr software version is 7.11.1.
Here is the "show platform vm" command running output:
RP/0/RP0/CPU0:r1-pnet#sh platform vm
Sun Feb 16 21:28:42.618 UTC
Node name       Node type       Partner name    SW status       IP address
0/RP0/CPU0      RP (ACTIVE)     NONE            FINAL Band      192.0.0.4
0/0/CPU0        LC (ACTIVE)     NONE            FINAL Band      192.0.0.6
The mgmt interface is working very well, but the GigabitEthernet0/0/0/0 and Gi0/0/0/1 can't communicate to other Cisco Routers, can't ping and can't get the MAC address of other interfaces.
Thanks again and best regards.
I have same problems,
Don't find the solution yet
