New APIC-M4 (C225 M6 chassis) not showing a VIC / adapter 1 in CIMC
vv0bbLeS
Hello all,
I have a new APIC-M4 (C225-M6 chassis) that I'm installing, and I wanted to upgrade the software on it to the new 6.0.5(M) version, but before doing that I went to upgrade the CIMC version to the recommended version for 6.0.5(M). Per the Cisco Application Policy Infrastructure Controller Release Notes, Release 6.0(5) - Cisco , the CIMC version depends on whether you have a certain SFP connector on your Adapter 1:
 4.3.2.230207 CIMC HUU ISO (recommended*) for UCS C220/C240 M5 (APIC-L3/M3) and UCS C225 M6 (APIC-L4/M4)
* We do not recommend this CIMC release if you have the SFP-10G-T-X connector type on the Cisco APIC data link ports (eth2-1 and eth2-2). To see which connector type you have, enter commands as shown in the following example:
C220-WMP2704001H /chassis # scope adapter 1
C220-WMP2704001H /chassis/adapter # show ext-eth-if detail
So I went into my APIC-M4 CIMC to run those commands, and I discovered I don't have an adapter 1 :
apic2-cimc# scope chassis
apic2-cimc /chassis #
apic2-cimc /chassis # scope adapter 1
Error: Managed object does not exist, use show command to list valid targets
apic2-cimc /chassis # show ad
adapter            adapter-ie-status
apic2-cimc /chassis # show adapter
Is this a problem to not show an "adapter 1" in my chassis ?
0xD2A6762E
Robert Burns
Pro-tip - Next time drop the output into a txt file and attach that, so it doesn't blow out the thread
So your adapter is the Intel 10/25G SFP adapter, so you can ignore the HUU warning and proceed.  Let the Host Update Utility update everything it can.
UCSC-P-I8D25GF
 Robert
Robert Burns
Provide the output of:
scope chassis
inventory-all
Robert
Thanks Robert, please see output below:
apic2-cimc#
apic2-cimc /chassis # inventory-all
sysProductName: APIC-SERVER-M4
sysProductID: APIC-SERVER-M4
sysSerialNum: WZP272700PZ
localTime: Thu Mar 28 21:03:36 2024 UTC +0000 (Local)
CPU
  SocketDesignation: CPU1
  ProcessorManufacturer: Advanced Micro Devices, Inc.
  ProcessorFamily: Zen
  ThreadCount: 32
  SerialNumber: Unknown
  ProcessorVersion: AMD EPYC 7313P 16-Core Processor
  CurrentSpeed: 3000
  CoreCount: 16
  CoreEnabled: 16
  Status: Enabled
  MaxSpeed: 3725
  Signature: Family 19h, Model 1, Stepping 1
  SocketDesignation: CPU2
  ProcessorManufacturer: N/A
  ProcessorFamily: N/A
  ThreadCount: N/A
  SerialNumber: N/A
  ProcessorVersion: N/A
  CurrentSpeed: N/A
  CoreCount: N/A
  CoreEnabled: N/A
  Status: Unpopulated
  MaxSpeed: N/A
  Signature: N/A
Memory
DIMMList:
  Capacity: Not Installed
  Speed: NA
  MemoryType: NA
  MemoryTypeDetail: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Capacity: 16384 MB
  Speed: 3200
  MemoryType: DDR4
  MemoryTypeDetail: Synchronous Registered (Buffered)
  BankLocator: NODE 0 CHANNEL 0 DIMM 1
  Manufacturer: 0xAD00
  SerialNumber: E057CCD1
  AssetTag: Not Specified
  PartNumber: HMA82GR7DJR4N-XN
  Visibility: Yes
  Operability: Operable
  DataWidth: 64 bits
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Capacity: 16384 MB
  Speed: 3200
  MemoryType: DDR4
  BankLocator: NODE 0 CHANNEL 2 DIMM 1
  SerialNumber: E057CC6C
  Visibility: Yes
  DataWidth: 64 bits
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Capacity: 16384 MB
  Speed: 3200
  MemoryType: DDR4
  BankLocator: NODE 0 CHANNEL 3 DIMM 1
  SerialNumber: E057CCD2
  Visibility: Yes
  DataWidth: 64 bits
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Capacity: 16384 MB
  Speed: 3200
  MemoryType: DDR4
  BankLocator: NODE 0 CHANNEL 4 DIMM 1
  SerialNumber: E057CC96
  Visibility: Yes
  DataWidth: 64 bits
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Capacity: 16384 MB
  Speed: 3200
  MemoryType: DDR4
  BankLocator: NODE 0 CHANNEL 6 DIMM 1
  SerialNumber: E057CCE6
  Visibility: Yes
  DataWidth: 64 bits
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Capacity: 16384 MB
  Speed: 3200
  MemoryType: DDR4
  BankLocator: NODE 0 CHANNEL 7 DIMM 1
  SerialNumber: E057CCAE
  Visibility: Yes
  DataWidth: 64 bits
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
HDD
LocalHardDiskList:
  Disk: 5
  Controller: MRAID
  Description: 480GB 2.5in Enterprise performance 6G SATA SSD (3X endurance)
  PID: UCS-SD480GM3X-EP
  Vendor: ATA
  Model: Micron_5300_MTFDDAK480TDT
  SerialNumber: 22453E681638
  powMin: 6
  powMax: 6
  Disk: 6
  Controller: MRAID
  Description: 960GB 2.5in Enterprise performance 6G SATA SSD (3X endurance)
  PID: UCS-SD960G63X-EP
  Vendor: ATA
  Model: INTEL SSDSC2KG960GZK
  SerialNumber: BTYJ244601LM960BGN
  powMin: 0
  powMax: 0
  Disk: 253
  Controller: MSTOR-RAID
  Description: 240GB SATA M.2
  PID: UCS-M2-240GB
  Vendor: ATA
  Model: Micron_5300_MTFDDAV240TDS
  SerialNumber: MSY26171HXD
  powMin: 6
  powMax: 6
PCI
  Slot: 1
  PID: UCSC-P-I8D25GF
  VendorID: 0x8086
  DeviceID: 0x159b
  SubVendorID: 0x1137
  SubDeviceID: 0x02be
  OptionROMLoaded: 0
  ProductName: Cisco - Intel E810XXVDA2 2x25/10 GbE SFP PCIe NIC
  fwVersion: 0x8000AA76-1.826.0
  Slot: MRAID
  PID: UCSC-RAID-M6T
  VendorID: 0x1000
  DeviceID: 0x10e2
  SubVendorID: 0x1137
  SubDeviceID: 0x02a4
  OptionROMLoaded: 0
  ProductName: Cisco 12G SAS RAID Controller with 4GB FBWC (16 Drives)
  fwVersion: 52.20.0-4523
  Slot: MLOM
  PID: UCSC-O-ID10GC
  VendorID: 0x8086
  DeviceID: 0x15ff
  SubVendorID: 0x1137
  SubDeviceID: 0x02d9
  OptionROMLoaded: 0
  ProductName: Cisco(R) X710T2LG 2x10 GbE RJ45 OCP 3.0 NIC
  fwVersion: 0x8000B906-1.826.0
  Slot: MSTOR-RAID
  PID: UCS-M2-HWRAID
  VendorID: 0x1b4b
  DeviceID: 0x9230
  SubVendorID: 0x1137
  SubDeviceID: 0x0251
  OptionROMLoaded: 0
  ProductName: Cisco Boot optimized M.2 Raid controller
  fwVersion: 2.3.17.1014
Power Supplies
  deviceID: PSU1
  Status: Present
  Status2: equipped
  InputWatt: 70
  Power: on
  OutputMaxWatt: N/A
  OutputWatt: 54
  fwVersion: 10252046
  Model: 700-014550-0000
  MfgRev: CT
  ProductID: UCSC-PSU1-1050W
  deviceID: PSU2
  Status: Present
  Status2: equipped
  InputWatt: 66
  Power: on
  OutputMaxWatt: N/A
  OutputWatt: 52
  fwVersion: 10252046
  MfgRev: CT
Fan status
  sensorStatus: Unavailable
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
tpm:
 tpmPresence: equipped
 enabledStatus: enabled
 tpmFirmareVersion: 7.85
 tpmRevision: 1
 model: UCSX-TPM2-002B-C
 vendor: Cisco Systems Inc
 serial: FCH272870A6
 version: 2.0
 activeStatus: activated
 ownership: owned
 txtPresent: Overall TXT Disabled
 txtIntelVTIssue: NA
 txtIntelVTdIssue: NA
 txtHWIssue: NA
 txtBootIssue: NA
AdapterDataList:
  Slot: MLOM
  PID: UCSC-O-ID10GC
  NoOfInterfaces: 2
  Slot: 1
  PID: UCSC-P-I8D25GF
  NoOfInterfaces: 2
Battery Status
BBUList:
  bbu:
  controller: MRAID
  group: status
  controller-type: RAID
  raid-support: yes
  battery-type: TMM-C SuperCap
  is-capacitor: true
  bbu-health: Good
  bbu-status: Optimal
  battery-present: true
  temperature: 23 degrees C
  temperature-high: false
  retention-time: N/A
  absolute-state-of-charge: N/A
  capacitance: 100 %
  charging-state: N/A
  manufacturer: LSI
  serial-number: 46276
  date: 2023-04-27
  design-voltage: 5.059 V
  voltage: 5.076 V
  current: 0.000 A
  learn-mode: Auto
  learn-cycle-status: Successful
  module-version: 180-4GB
  learn-cycle-requested: false
  next-learn-cycle: 2024-04-25 16:20
  design-capacity: 99 Joules
  relative-state-of-charge: N/A
  full-capacity: N/A
  remaining-capacity: N/A
  pack-energy: 66 Joules
  completed-charge-cycles: N/A
  BBU-temperature: 23 degrees C
  BBU-battery-present: true
  TMM-C-optimal: true
  voltage-low: false
  learn-cycle-active: false
  remaining-capacity-low: false
  no-space: false
  premium-feature-reqd: false
  microcode-upd-reqd: false
  charge-active: false
  discharge-active: false
  learn-cycle-failed: false
  learn-cycle-timeout: false
  BBU-predictive-failure: false
  BBU-replacement-required: false
  BBU-fault: false
  BBU-degraded: false
  deviceName: CVPM05
  transparentLearns: true
  BBU-capacitance: 100 %
  remaining-pool-space: 0 %
  TMM-PCB-Version-Number: 0x
  TMM-Serial-Number: 0x0000
  TMM-Manufacturing-Date: N/A
  TMM-PCB-Assembly-Number:
  TMM-Battery-Version-Number: 0x
  relearn-status: Unknown
  relearn-start-timestamp: 0
  relearn-end-timestamp: 0
  relearn-percent-complete: N/A
Adapter List
controller: MRAID
                raid-support: yes
                protocol: SAS
                typeWithSlotId: SAS-MRAID
                type-with-slotId: SAS-MRAID
                next-exec-time: 2024-03-30 03:40
                exec-freq: 7 days
                next-exec-time: N/A
                exec-freq: N/A
                pci-slot: MRAID
                managed-id: 1
                storage-status: initialized
                controller-status: Optimal
                controller-health: Good
                composite-health: Good
                overall-health: Good
                battery-status: Optimal
                controller-temperature-sensor-present: false
                ROC-temperature-sensor-present: true
                drive-temperature-supported: true
                running-on-hx: false
                controller-temperature: 255
                roc-temperature: 42
                roc-temperature-w-units: 42 degrees C
                tty-log-status: Not Downloaded
                lock-key-assigned: 0
                ctlr-secured-mgmt-type: none
                cache-is-pinned: 0
                patrol-read-operation-status: Unknown
                patrol_read_percent_complete: 0
                patrol_read_start_timestamp: 0
                patrol_read_end_timestamp: 0
                has-foreign-config: false
                foreign-config-pd-count: 0
                has-pinned-cache: false
                lost-all-config: false
                default-stripsize: 7
                default-stripe-size: 64 KB
                default-writePolicy: 0
                default-readPolicy: 0
                default-ioPolicy: 0
                writePolicy-choices: 0,1,2
                vendor: LSI Logic
                product-name: Cisco 12G SAS RAID Controller with 4GB FBWC (16 Drives)
                product-pid: UCSC-RAID-M6T
                serial-number: SKD1610496
                firmware-package-build: 52.20.0-4523
                nvram-size: 128 KB
                memory-size: 4096 MB
                flash-size: 16 MB
                cache-memory-size: 3142 MB
                bbu-status: Optimal
                min-strip-size: 7
                max-strip-size: 11
                supported-strip-sizes: 64KB, 1024KB
                ncq-status: enabled
                auto-cfg-option: unconfigured-good
                raid-transitions: |0,0|0,1|0,5|0,6|1,0|1,1|1,5|1,6|5,0|5,1|5,5|5,6|6,0|6,1|6,5|6,6|
                raid-min-pds: |0,1|1,2|5,3|6,4|
                supported-ctlr-ops: 00000e0073fffffe
                supported-phys-ops: 00000ff2effffffe
                supported-virt-ops: 000000061e7ffffe
                supported-bbu-ops: 0008
                valid-ctlr-attrs: 0000000000003ffe
                supports-cached-io: false
                supports-add-config: false
                supports-clear-config: true
                supports-disallow-force-clear-config: false
                supports-make-epd: true
                supports-trimode: false
                boot-drive: 239
                boot-drive-is-PD: false
                ctlr-treat-R1E-as-R10: false
                ctlr-bios-mode: Headless Mode
                ctlr-coercion-mode: 1GB
                ctlr-flush-time-in-seconds: 4
                ctlr-allowed-device-types: SAS/SATA Mix
                ctlr-SAS-SATA-mix-in-enclosure-allowed: true
                ctlr-SAS-SATA-mix-in-VD-allowed: true
                ctlr-SAS-SATA-SSD-mix-in-VD-allowed: true
                ctlr-SSD-HDD-mix-in-VD-allowed: false
                ctlr-disable-ctlr-R-bios: false
                ctlr-enable-web-bios: false
                ctlr-expose-enclosure-devices: true
                ctlr-maintain-PD-fail-history: false
                ctlr-max-lds-per-array: 64
                ctlr-allow-uncertified-HDDs: Allow
                ctlr-online-controller-reset-enabled: true
                ctlr-disable-cache-bypass: false
                ctlr-JBOD-mode-enabled: false
                ctlr-tty-log-in-flash-enabled: false
                ctlr-auto-enhanced-import-at-boot-enabled: true
                ctlr-use-drive-write-cache-for-rebuild-enabled: false
                ctlr-SSD-write-cache-change-blocked: true
                ctlr-HII-disabled: false
                ctlr-performance-tuner-mode: Best IOPS
                ctlr-512e-drive-support-enabled: true
                ctlr-max-VDs: 0
                ctlr-max-devices-exposed-to-legacy-BIOS: 16
                ctlr-1MB-IO-support-enabled: true
                ctlr-iMR-large-queue-depth-support-enabled: false
                ctlr-transport-ready-enabled: false
                ctlr-supports-more-than-64VDs: true
controller: MSTOR-RAID
                controller-type: M2HWRAID
                raid-support: yes
                protocol: SATA
                typeWithSlotId: SATA-MSTOR-RAID
                type-with-slotId: SATA-MSTOR-RAID
                next-exec-time: N/A
                exec-freq: N/A
                pci-slot: MSTOR-RAID
                managed-id: 2
                battery-status: BBU Not Supported
                ROC-temperature-sensor-present: false
                drive-temperature-supported: false
                controller-temperature: 0
                roc-temperature: Not Supported
                roc-temperature-w-units: Not Supported degrees C
                cache-is-pinned: 0
                default-ioPolicy: 0
                vendor: Marvell
                product-name: Cisco Boot optimized M.2 Raid controller
                product-pid: UCS-M2-HWRAID
                serial-number: FCH27277A6Y
                product-serial-no: FCH27277A6Y
                firmware-package-build: 2.3.17.1014
                nvram-size: 0 KB
                memory-size: 0 MB
                flash-size: 2 MB
                cache-memory-size: 0 MB
                bbu-status: BBU Not Supported
                min-strip-size: 6
                max-strip-size: 7
                supported-strip-sizes: 32KB, 64KB
                ncq-status: enabled
                raid-transitions: |0,0|0,1|1,0|1,1|
                supported-ctlr-ops: 000001e0000000e0
                supported-phys-ops: 0000001204000000
                supported-virt-ops: 0000000400001014
                supported-bbu-ops: 0001
                valid-ctlr-attrs: 0000000000000001
                supports-clear-config: false
                supports-make-epd: false
                boot-drive: 0
FRU Details
        BuiltinFRUDevice(ID0)
                 Chassis Type          : Rack Mount Chassis
                 Chassis Part Number   : 74-125841-01
                 Chassis Serial        : WZP272700PZ
                 Chassis Extra         : Cisco Systems Inc
                 Board Mfg             : Cisco Systems Inc
                 Board Product         : UCSC-C225-M6S
                 Board Serial          : WZP2726Z015
                 Board Part Number     : 74-125843-01
                 Board Extra           : C04V01
                 Board Extra           : 0000000000
                 Product Manufacturer  : Cisco Systems Inc
                 Product Name          : APIC-SERVER-M4
                 Product Part Number   : 74-125841-01
                 Product Version       : A0
                 Product Serial        : WZP272700PZ
                 Product Asset Tag     : Unknown
                 Product Extra         : F0V01
        FRU_FP(ID1)
                 Board Product         : UCSC-FPNL-C225M6S
                 Board Serial          : 325003D1J0A
                 Board Part Number     : FPC225M6
                 Board Extra           : A04V01
        FRU_MB(ID2)
        FRU_TPM(ID3)
                 Board Product         : UCSX-TPM2-002B-C
                 Board Serial          : FCH272870A6
                 Board Part Number     : 73-20115-01
                 Board Extra           : A03V01
        FRU_PSU1(ID4)
                 Board Product         : UCSC-PSU1-1050W
                 Board Serial          : APS271800Q6
                 Board Part Number     : 341-0638-03
                 Board Extra           : A0V03
                 Product Name          : UCSC-PSU1-1050W
                 Product Part Number   : 341-0638-03
                 Product Version       : A
                 Product Serial        : APS271800Q6
                 Product Extra         : A0V03
        FRU_PSU2(ID5)
                 Board Serial          : APS271800P2
                 Board Extra           : A0V03
                 Product Version       : A
                 Product Serial        : APS271800P2
        FRU_VIC_SLOT1(ID6)
                 Device not present (Requested sensor, data, or record not found)
        FRU_VIC_SLOT3(ID7)
        FRU_MLOM(ID8)
        FRU_HD_BP(ID9)
                 Board Product         : UCSC-HDBP-C225M6S
                 Board Serial          : 32300574J0A
                 Board Part Number     : C225SFFBP
        FRU_MINI_STORAGE(ID10)
                 Board Product         : UCS-M2-HWRAID
                 Board Serial          : FCH27277A6Y
                 Board Part Number     : 73-19532-07
                 Board Extra           : A05V02
0xD2A6762E
Robert Burns
UCSC-P-I8D25GF
 Robert
@Robert Burns  ah ok yes I can attach a txt file next time. And OK great! Thanks for looking!
0xD2A6762E
