04-02-2024 12:49 PM
Hello all,
I have a new APIC-M4 (C225-M6 chassis) that I'm installing, and I wanted to upgrade the software on it to the new 6.0.5(M) version, but before doing that I went to upgrade the CIMC version to the recommended version for 6.0.5(M). Per the Cisco Application Policy Infrastructure Controller Release Notes, Release 6.0(5) - Cisco , the CIMC version depends on whether you have a certain SFP connector on your Adapter 1:
4.3.2.230207 CIMC HUU ISO (recommended*) for UCS C220/C240 M5 (APIC-L3/M3) and UCS C225 M6 (APIC-L4/M4)
* We do not recommend this CIMC release if you have the SFP-10G-T-X connector type on the Cisco APIC data link ports (eth2-1 and eth2-2). To see which connector type you have, enter commands as shown in the following example:
C220-WMP2704001H /chassis # scope adapter 1
C220-WMP2704001H /chassis/adapter # show ext-eth-if detail
So I went into my APIC-M4 CIMC to run those commands, and I discovered I don't have an adapter 1 :
apic2-cimc# scope chassis
apic2-cimc /chassis #
apic2-cimc /chassis # scope adapter 1
Error: Managed object does not exist, use show command to list valid targets
apic2-cimc /chassis # show ad
adapter adapter-ie-status
apic2-cimc /chassis # show adapter
Is this a problem to not show an "adapter 1" in my chassis ?
Solved! Go to Solution.
04-03-2024 08:42 AM
Pro-tip - Next time drop the output into a txt file and attach that, so it doesn't blow out the thread
So your adapter is the Intel 10/25G SFP adapter, so you can ignore the HUU warning and proceed. Let the Host Update Utility update everything it can.
UCSC-P-I8D25GF
Robert
04-02-2024 02:32 PM
Provide the output of:
scope chassis
inventory-all
Robert
04-03-2024 07:18 AM
Thanks Robert, please see output below:
apic2-cimc#
apic2-cimc /chassis # inventory-all
sysProductName: APIC-SERVER-M4
sysProductID: APIC-SERVER-M4
sysSerialNum: WZP272700PZ
localTime: Thu Mar 28 21:03:36 2024 UTC +0000 (Local)
CPU
SocketDesignation: CPU1
ProcessorManufacturer: Advanced Micro Devices, Inc.
ProcessorFamily: Zen
ThreadCount: 32
SerialNumber: Unknown
ProcessorVersion: AMD EPYC 7313P 16-Core Processor
CurrentSpeed: 3000
CoreCount: 16
CoreEnabled: 16
Status: Enabled
MaxSpeed: 3725
Signature: Family 19h, Model 1, Stepping 1
SocketDesignation: CPU2
ProcessorManufacturer: N/A
ProcessorFamily: N/A
ThreadCount: N/A
SerialNumber: N/A
ProcessorVersion: N/A
CurrentSpeed: N/A
CoreCount: N/A
CoreEnabled: N/A
Status: Unpopulated
MaxSpeed: N/A
Signature: N/A
Memory
DIMMList:
Capacity: Not Installed
Speed: NA
MemoryType: NA
MemoryTypeDetail: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Capacity: 16384 MB
Speed: 3200
MemoryType: DDR4
MemoryTypeDetail: Synchronous Registered (Buffered)
BankLocator: NODE 0 CHANNEL 0 DIMM 1
Manufacturer: 0xAD00
SerialNumber: E057CCD1
AssetTag: Not Specified
PartNumber: HMA82GR7DJR4N-XN
Visibility: Yes
Operability: Operable
DataWidth: 64 bits
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Capacity: 16384 MB
Speed: 3200
MemoryType: DDR4
BankLocator: NODE 0 CHANNEL 2 DIMM 1
SerialNumber: E057CC6C
Visibility: Yes
DataWidth: 64 bits
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Capacity: 16384 MB
Speed: 3200
MemoryType: DDR4
BankLocator: NODE 0 CHANNEL 3 DIMM 1
SerialNumber: E057CCD2
Visibility: Yes
DataWidth: 64 bits
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Capacity: 16384 MB
Speed: 3200
MemoryType: DDR4
BankLocator: NODE 0 CHANNEL 4 DIMM 1
SerialNumber: E057CC96
Visibility: Yes
DataWidth: 64 bits
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Capacity: 16384 MB
Speed: 3200
MemoryType: DDR4
BankLocator: NODE 0 CHANNEL 6 DIMM 1
SerialNumber: E057CCE6
Visibility: Yes
DataWidth: 64 bits
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Capacity: 16384 MB
Speed: 3200
MemoryType: DDR4
BankLocator: NODE 0 CHANNEL 7 DIMM 1
SerialNumber: E057CCAE
Visibility: Yes
DataWidth: 64 bits
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
Speed: NA
MemoryType: NA
BankLocator: NA
Manufacturer: NA
SerialNumber: NA
AssetTag: NA
PartNumber: NA
Visibility: NA
Operability: NA
DataWidth: NA
HDD
LocalHardDiskList:
Disk: 5
Controller: MRAID
Description: 480GB 2.5in Enterprise performance 6G SATA SSD (3X endurance)
PID: UCS-SD480GM3X-EP
Vendor: ATA
Model: Micron_5300_MTFDDAK480TDT
SerialNumber: 22453E681638
powMin: 6
powMax: 6
Disk: 6
Controller: MRAID
Description: 960GB 2.5in Enterprise performance 6G SATA SSD (3X endurance)
PID: UCS-SD960G63X-EP
Vendor: ATA
Model: INTEL SSDSC2KG960GZK
SerialNumber: BTYJ244601LM960BGN
powMin: 0
powMax: 0
Disk: 253
Controller: MSTOR-RAID
Description: 240GB SATA M.2
PID: UCS-M2-240GB
Vendor: ATA
Model: Micron_5300_MTFDDAV240TDS
SerialNumber: MSY26171HXD
powMin: 6
powMax: 6
PCI
Slot: 1
PID: UCSC-P-I8D25GF
VendorID: 0x8086
DeviceID: 0x159b
SubVendorID: 0x1137
SubDeviceID: 0x02be
OptionROMLoaded: 0
ProductName: Cisco - Intel E810XXVDA2 2x25/10 GbE SFP PCIe NIC
fwVersion: 0x8000AA76-1.826.0
Slot: MRAID
PID: UCSC-RAID-M6T
VendorID: 0x1000
DeviceID: 0x10e2
SubVendorID: 0x1137
SubDeviceID: 0x02a4
OptionROMLoaded: 0
ProductName: Cisco 12G SAS RAID Controller with 4GB FBWC (16 Drives)
fwVersion: 52.20.0-4523
Slot: MLOM
PID: UCSC-O-ID10GC
VendorID: 0x8086
DeviceID: 0x15ff
SubVendorID: 0x1137
SubDeviceID: 0x02d9
OptionROMLoaded: 0
ProductName: Cisco(R) X710T2LG 2x10 GbE RJ45 OCP 3.0 NIC
fwVersion: 0x8000B906-1.826.0
Slot: MSTOR-RAID
PID: UCS-M2-HWRAID
VendorID: 0x1b4b
DeviceID: 0x9230
SubVendorID: 0x1137
SubDeviceID: 0x0251
OptionROMLoaded: 0
ProductName: Cisco Boot optimized M.2 Raid controller
fwVersion: 2.3.17.1014
Power Supplies
deviceID: PSU1
Status: Present
Status2: equipped
InputWatt: 70
Power: on
OutputMaxWatt: N/A
OutputWatt: 54
fwVersion: 10252046
Model: 700-014550-0000
MfgRev: CT
ProductID: UCSC-PSU1-1050W
deviceID: PSU2
Status: Present
Status2: equipped
InputWatt: 66
Power: on
OutputMaxWatt: N/A
OutputWatt: 52
fwVersion: 10252046
MfgRev: CT
Fan status
sensorStatus: Unavailable
reading: N/A
units: RPM
minWarning: N/A
maxWarning: N/A
minFailure: N/A
maxFailure: N/A
minNR: N/A
maxNR: N/A
reading: N/A
units: RPM
minWarning: N/A
maxWarning: N/A
minFailure: N/A
maxFailure: N/A
minNR: N/A
maxNR: N/A
reading: N/A
units: RPM
minWarning: N/A
maxWarning: N/A
minFailure: N/A
maxFailure: N/A
minNR: N/A
maxNR: N/A
reading: N/A
units: RPM
minWarning: N/A
maxWarning: N/A
minFailure: N/A
maxFailure: N/A
minNR: N/A
maxNR: N/A
reading: N/A
units: RPM
minWarning: N/A
maxWarning: N/A
minFailure: N/A
maxFailure: N/A
minNR: N/A
maxNR: N/A
reading: N/A
units: RPM
minWarning: N/A
maxWarning: N/A
minFailure: N/A
maxFailure: N/A
minNR: N/A
maxNR: N/A
reading: N/A
units: RPM
minWarning: N/A
maxWarning: N/A
minFailure: N/A
maxFailure: N/A
minNR: N/A
maxNR: N/A
reading: N/A
units: RPM
minWarning: N/A
maxWarning: N/A
minFailure: N/A
maxFailure: N/A
minNR: N/A
maxNR: N/A
reading: N/A
units: RPM
minWarning: N/A
maxWarning: N/A
minFailure: N/A
maxFailure: N/A
minNR: N/A
maxNR: N/A
reading: N/A
units: RPM
minWarning: N/A
maxWarning: N/A
minFailure: N/A
maxFailure: N/A
minNR: N/A
maxNR: N/A
reading: N/A
units: RPM
minWarning: N/A
maxWarning: N/A
minFailure: N/A
maxFailure: N/A
minNR: N/A
maxNR: N/A
reading: N/A
units: RPM
minWarning: N/A
maxWarning: N/A
minFailure: N/A
maxFailure: N/A
minNR: N/A
maxNR: N/A
reading: N/A
units: RPM
minWarning: N/A
maxWarning: N/A
minFailure: N/A
maxFailure: N/A
minNR: N/A
maxNR: N/A
reading: N/A
units: RPM
minWarning: N/A
maxWarning: N/A
minFailure: N/A
maxFailure: N/A
minNR: N/A
maxNR: N/A
reading: N/A
units: RPM
minWarning: N/A
maxWarning: N/A
minFailure: N/A
maxFailure: N/A
minNR: N/A
maxNR: N/A
reading: N/A
units: RPM
minWarning: N/A
maxWarning: N/A
minFailure: N/A
maxFailure: N/A
minNR: N/A
maxNR: N/A
tpm:
tpmPresence: equipped
enabledStatus: enabled
tpmFirmareVersion: 7.85
tpmRevision: 1
model: UCSX-TPM2-002B-C
vendor: Cisco Systems Inc
serial: FCH272870A6
version: 2.0
activeStatus: activated
ownership: owned
txtPresent: Overall TXT Disabled
txtIntelVTIssue: NA
txtIntelVTdIssue: NA
txtHWIssue: NA
txtBootIssue: NA
AdapterDataList:
Slot: MLOM
PID: UCSC-O-ID10GC
NoOfInterfaces: 2
Slot: 1
PID: UCSC-P-I8D25GF
NoOfInterfaces: 2
Battery Status
BBUList:
bbu:
controller: MRAID
group: status
controller-type: RAID
raid-support: yes
battery-type: TMM-C SuperCap
is-capacitor: true
bbu-health: Good
bbu-status: Optimal
battery-present: true
temperature: 23 degrees C
temperature-high: false
retention-time: N/A
absolute-state-of-charge: N/A
capacitance: 100 %
charging-state: N/A
manufacturer: LSI
serial-number: 46276
date: 2023-04-27
design-voltage: 5.059 V
voltage: 5.076 V
current: 0.000 A
learn-mode: Auto
learn-cycle-status: Successful
module-version: 180-4GB
learn-cycle-requested: false
next-learn-cycle: 2024-04-25 16:20
design-capacity: 99 Joules
relative-state-of-charge: N/A
full-capacity: N/A
remaining-capacity: N/A
pack-energy: 66 Joules
completed-charge-cycles: N/A
BBU-temperature: 23 degrees C
BBU-battery-present: true
TMM-C-optimal: true
voltage-low: false
learn-cycle-active: false
remaining-capacity-low: false
no-space: false
premium-feature-reqd: false
microcode-upd-reqd: false
charge-active: false
discharge-active: false
learn-cycle-failed: false
learn-cycle-timeout: false
BBU-predictive-failure: false
BBU-replacement-required: false
BBU-fault: false
BBU-degraded: false
deviceName: CVPM05
transparentLearns: true
BBU-capacitance: 100 %
remaining-pool-space: 0 %
TMM-PCB-Version-Number: 0x
TMM-Serial-Number: 0x0000
TMM-Manufacturing-Date: N/A
TMM-PCB-Assembly-Number:
TMM-Battery-Version-Number: 0x
relearn-status: Unknown
relearn-start-timestamp: 0
relearn-end-timestamp: 0
relearn-percent-complete: N/A
Adapter List
controller: MRAID
raid-support: yes
protocol: SAS
typeWithSlotId: SAS-MRAID
type-with-slotId: SAS-MRAID
next-exec-time: 2024-03-30 03:40
exec-freq: 7 days
next-exec-time: N/A
exec-freq: N/A
pci-slot: MRAID
managed-id: 1
storage-status: initialized
controller-status: Optimal
controller-health: Good
composite-health: Good
overall-health: Good
battery-status: Optimal
controller-temperature-sensor-present: false
ROC-temperature-sensor-present: true
drive-temperature-supported: true
running-on-hx: false
controller-temperature: 255
roc-temperature: 42
roc-temperature-w-units: 42 degrees C
tty-log-status: Not Downloaded
lock-key-assigned: 0
ctlr-secured-mgmt-type: none
cache-is-pinned: 0
patrol-read-operation-status: Unknown
patrol_read_percent_complete: 0
patrol_read_start_timestamp: 0
patrol_read_end_timestamp: 0
has-foreign-config: false
foreign-config-pd-count: 0
has-pinned-cache: false
lost-all-config: false
default-stripsize: 7
default-stripe-size: 64 KB
default-writePolicy: 0
default-readPolicy: 0
default-ioPolicy: 0
writePolicy-choices: 0,1,2
vendor: LSI Logic
product-name: Cisco 12G SAS RAID Controller with 4GB FBWC (16 Drives)
product-pid: UCSC-RAID-M6T
serial-number: SKD1610496
firmware-package-build: 52.20.0-4523
nvram-size: 128 KB
memory-size: 4096 MB
flash-size: 16 MB
cache-memory-size: 3142 MB
bbu-status: Optimal
min-strip-size: 7
max-strip-size: 11
supported-strip-sizes: 64KB, 1024KB
ncq-status: enabled
auto-cfg-option: unconfigured-good
raid-transitions: |0,0|0,1|0,5|0,6|1,0|1,1|1,5|1,6|5,0|5,1|5,5|5,6|6,0|6,1|6,5|6,6|
raid-min-pds: |0,1|1,2|5,3|6,4|
supported-ctlr-ops: 00000e0073fffffe
supported-phys-ops: 00000ff2effffffe
supported-virt-ops: 000000061e7ffffe
supported-bbu-ops: 0008
valid-ctlr-attrs: 0000000000003ffe
supports-cached-io: false
supports-add-config: false
supports-clear-config: true
supports-disallow-force-clear-config: false
supports-make-epd: true
supports-trimode: false
boot-drive: 239
boot-drive-is-PD: false
ctlr-treat-R1E-as-R10: false
ctlr-bios-mode: Headless Mode
ctlr-coercion-mode: 1GB
ctlr-flush-time-in-seconds: 4
ctlr-allowed-device-types: SAS/SATA Mix
ctlr-SAS-SATA-mix-in-enclosure-allowed: true
ctlr-SAS-SATA-mix-in-VD-allowed: true
ctlr-SAS-SATA-SSD-mix-in-VD-allowed: true
ctlr-SSD-HDD-mix-in-VD-allowed: false
ctlr-disable-ctlr-R-bios: false
ctlr-enable-web-bios: false
ctlr-expose-enclosure-devices: true
ctlr-maintain-PD-fail-history: false
ctlr-max-lds-per-array: 64
ctlr-allow-uncertified-HDDs: Allow
ctlr-online-controller-reset-enabled: true
ctlr-disable-cache-bypass: false
ctlr-JBOD-mode-enabled: false
ctlr-tty-log-in-flash-enabled: false
ctlr-auto-enhanced-import-at-boot-enabled: true
ctlr-use-drive-write-cache-for-rebuild-enabled: false
ctlr-SSD-write-cache-change-blocked: true
ctlr-HII-disabled: false
ctlr-performance-tuner-mode: Best IOPS
ctlr-512e-drive-support-enabled: true
ctlr-max-VDs: 0
ctlr-max-devices-exposed-to-legacy-BIOS: 16
ctlr-1MB-IO-support-enabled: true
ctlr-iMR-large-queue-depth-support-enabled: false
ctlr-transport-ready-enabled: false
ctlr-supports-more-than-64VDs: true
controller: MSTOR-RAID
controller-type: M2HWRAID
raid-support: yes
protocol: SATA
typeWithSlotId: SATA-MSTOR-RAID
type-with-slotId: SATA-MSTOR-RAID
next-exec-time: N/A
exec-freq: N/A
pci-slot: MSTOR-RAID
managed-id: 2
battery-status: BBU Not Supported
ROC-temperature-sensor-present: false
drive-temperature-supported: false
controller-temperature: 0
roc-temperature: Not Supported
roc-temperature-w-units: Not Supported degrees C
cache-is-pinned: 0
default-ioPolicy: 0
vendor: Marvell
product-name: Cisco Boot optimized M.2 Raid controller
product-pid: UCS-M2-HWRAID
serial-number: FCH27277A6Y
product-serial-no: FCH27277A6Y
firmware-package-build: 2.3.17.1014
nvram-size: 0 KB
memory-size: 0 MB
flash-size: 2 MB
cache-memory-size: 0 MB
bbu-status: BBU Not Supported
min-strip-size: 6
max-strip-size: 7
supported-strip-sizes: 32KB, 64KB
ncq-status: enabled
raid-transitions: |0,0|0,1|1,0|1,1|
supported-ctlr-ops: 000001e0000000e0
supported-phys-ops: 0000001204000000
supported-virt-ops: 0000000400001014
supported-bbu-ops: 0001
valid-ctlr-attrs: 0000000000000001
supports-clear-config: false
supports-make-epd: false
boot-drive: 0
FRU Details
BuiltinFRUDevice(ID0)
Chassis Type : Rack Mount Chassis
Chassis Part Number : 74-125841-01
Chassis Serial : WZP272700PZ
Chassis Extra : Cisco Systems Inc
Board Mfg : Cisco Systems Inc
Board Product : UCSC-C225-M6S
Board Serial : WZP2726Z015
Board Part Number : 74-125843-01
Board Extra : C04V01
Board Extra : 0000000000
Product Manufacturer : Cisco Systems Inc
Product Name : APIC-SERVER-M4
Product Part Number : 74-125841-01
Product Version : A0
Product Serial : WZP272700PZ
Product Asset Tag : Unknown
Product Extra : F0V01
FRU_FP(ID1)
Board Product : UCSC-FPNL-C225M6S
Board Serial : 325003D1J0A
Board Part Number : FPC225M6
Board Extra : A04V01
FRU_MB(ID2)
FRU_TPM(ID3)
Board Product : UCSX-TPM2-002B-C
Board Serial : FCH272870A6
Board Part Number : 73-20115-01
Board Extra : A03V01
FRU_PSU1(ID4)
Board Product : UCSC-PSU1-1050W
Board Serial : APS271800Q6
Board Part Number : 341-0638-03
Board Extra : A0V03
Product Name : UCSC-PSU1-1050W
Product Part Number : 341-0638-03
Product Version : A
Product Serial : APS271800Q6
Product Extra : A0V03
FRU_PSU2(ID5)
Board Serial : APS271800P2
Board Extra : A0V03
Product Version : A
Product Serial : APS271800P2
FRU_VIC_SLOT1(ID6)
Device not present (Requested sensor, data, or record not found)
FRU_VIC_SLOT3(ID7)
FRU_MLOM(ID8)
FRU_HD_BP(ID9)
Board Product : UCSC-HDBP-C225M6S
Board Serial : 32300574J0A
Board Part Number : C225SFFBP
FRU_MINI_STORAGE(ID10)
Board Product : UCS-M2-HWRAID
Board Serial : FCH27277A6Y
Board Part Number : 73-19532-07
Board Extra : A05V02
04-03-2024 08:42 AM
UCSC-P-I8D25GF
Robert
04-03-2024 08:55 AM
@Robert Burns ah ok yes I can attach a txt file next time. And OK great! Thanks for looking!
