ACE: Default Inactivity Timers
mullzkBern_2
Hi everyone
We have a Problem with the default inactivity timeout values on our ACE A4.
A Web-Service of ours takes up to 12 Minutes for creating its reports. But after 300 secs, the ACE kills the connection and sends a Reset to Server and Client, due to Inactivity Timeout (see https://supportforums.cisco.com/thread/2140771).
As described in http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/security/guide/tcpipnrm.html, we configured the inactivity timer on a parameter-map, which worked out fine:
parameter-map type connection HTTP_TIMEOUT
  set timeout inactivity 3600
policy-map multi-match CLIENT-VIPs
  class ZONE1.XY.Z_CM
    loadbalance vip inservice
    loadbalance policy ZONE1.XY.Z_PM
    loadbalance vip icmp-reply active
    connection advanced-options HTTP_TIMEOUT
But this works only for Connections with Virtual IPs - Direct (bridged) connections as the previously mentioned service are not affected by this configuration. Is there any way to change the Inactivity Paramter in a global way and not only for VIP-Connections?
Thanks in advance and greetings from Berne, Switzerland
Stefan Mueller
Our configuration:
  system:    Version A4(2.2) [build 3.0(0)A4(2.2) adbuild_15:26:12-2011/10/10_/auto/adbure_nightly4/renumber/rel_a4_2_2_throttle/REL_3_0_0_A4_2_2]
  system image file: (hd0,1)/c4710ace-t1k9-mz.A4_2_2.bin
  Device Manager version 4.2 (0) 20110907:2229
Jorge Bejarano
Level 4
Level 4
Maybe you can take a look of this feature:
Configuring Inactivity Timeout for Connections in Switch Mode
Per CSCtf91257, the new switch-mode timeout command  in configuration mode allows you to configure the inactivity timeout  for TCP or UDP connections in Switch mode. The ACE forwards connections  that do not match any VIP. In Switch mode, these connections have TCP  normalization disabled and the inactivity timeout set to 2 hours and 15  minutes (8,100 seconds). Since UDP connections do not have a close  protocol, this timeout defines their minimum lifetime. Therefore, this  command was introduced to minimize the number of old connections,  particularly UDP.
The syntax for this command is follows:
switch-mode timeout seconds
The seconds argument is the time period  in seconds for idle connections after which the ACE disconnects the  connection. Enter an integer from 1 to 65535. By default, the timeout is  8100 seconds.
For example, to configure a timeout of 10 seconds, enter the following command:
host/Admin(config)# switch-mode timeout 10
To reset the default timeout, enter the following command:
host/Admin(config)# no switch-mode timeout
Here you have the link where you can find extra details:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA4_1_0/configuration/security/guide/tcpipnrm.html
Hope this helps!!!
Jorge
gaursin2
Just a quick hint, create an ACL permiting our desire traffic, call that in a class map, call that class map in policy map and apply parameter map.
Jorge Bejarano
Level 4
Level 4
Hope this helps!!!
Jorge
thanks a lot, this helped
(although it isn't a global command: you have to config this for switch-mode and config advanced option for every VIP. A bit more of a hassle than we hoped for, but it works fine)
We have had to change the http and https timeouts for all traffic and could not do it per VIP as we many times load balance tcp/any.
Had to open a TAC case and I think it was what Gaurav has suggested. This way all http & https traffic got a different inactivity timeout. But in another case that I just now have opened it looks like this is not true for connections that go through the alias IP, i.e. routed mode (more specific in our case One-Arm routed (asymmetric traffic)).
Here is the config we use on all our contexts where we need all HTTP/HTTPs to have 3600 as their inactivity timeout:
parameter-map type connection CONN-TIMEOUT-3600
class-map match-all CONN-TIMEOUT-HTTP
  match port tcp eq http
class-map match-all CONN-TIMEOUT-HTTPS
  match port tcp eq https
policy-map multi-match CONN-TIMEOUT-HTTP-HTTPS
   class CONN-TIMEOUT-HTTP
                connection advanced-options CONN-TIMEOUT-3600
   class CONN-TIMEOUT-HTTPS
service-policy input CONN-TIMEOUT-HTTP-HTTPS
The multi-match policy was assigned globally and is an additional one the the one where we define the VIPs.
