ACE FT GROUP.
ajay chauhan
Level 7
Level 7
What is the standard design for FT group for multiple context. Should we have just two FT group or seperate FT group for each context.
The doubt behind is that -
Suppose i have 4 context A,B,C,D.   Context A& B assigned to FT group 1 and C & D assigned to FT group 2. Just incase if context A have some problem and   failover occur will that failover context B too ?
Ajay
Daniel Arrondo Ostiz
Hi Ajay,
Only one context is allowed per FT group, so you don't have a choice. If you try to configure more than one, the ACE will return an error message.
Daniel
Hi Ajay,
Daniel
