Help in understanding CSS config
darrenriley5
We have two internal css boxes, 1 at each site which we use for redunancy should eith CSS box fail. I'm trying to fully understand the config but I'm having difficulty.
Could someone explain how this config works when a request is sent to one of the VIp addresses. Also how does the failover work if one CSS box fails.
circuit VLAN10
ip address 10.128.144.5 255.255.240.0
ip virtual-router 1 priority 101 preempt
ip virtual-router 3
ip redundant-interface 1 10.128.159.254
ip redundant-interface 3 10.128.159.253
ip redundant-vip 1 10.128.152.16
ip redundant-vip 3 10.128.144.21
CSS2
circuit VLAN10
ip address 10.128.152.5 255.255.240.0
ip virtual-router 1
ip virtual-router 3 priority 101 preempt
ip redundant-vip 1 10.128.152.13
7 Replies 7
sachinga.hcl
Level 4
Level 4
Hi Darren,
Before attempting this configuration, ensure that you meet these requirements:
ï‚§ Both of the CSSs you are using for this redundant configuration must be running the same version of code. Running different versions of code is not supported for redundancy.
ï‚§ Expect the behavior of the CSSs to be active (master)/standby (backup); only the master CSS processes flows.
ï‚§ You must configure a dedicated Fast Ethernet (FE) link between the CSSs for the Virtual Router Redundancy Protocol (VRRP) heartbeat.
ï‚§ Do not use box-to-box if you require the connection of a Layer 2 device between the redundant CSS peers. Use VIP redundancy instead.
CSSs participate in a redundant configuration when a redundancy link has been defined between two CSSs. The protocol used for this redundancy link is VRRP, using multicast address 224.0.0.18. The CSSs use this link to maintain contact and activity status with one another. Only one crossover link between the CSSs is supported. You must use a crossover cable to connect directly to the FE ports on the redundant CSSs. Do not use Layer 2 devices between the two CSSs on the redundant link. Do not install the crossover cable on Gigabit Ethernet (GE) ports; this configuration is not supported.
Note: The CSS box-to-box redundancy protocol is now supported on the CSS 11501, CSS 11503, and CSS 11506 GE ports in software version 7.10.1.02 and 7.20.0.01 and later.
There are two main conditions detected on this redundancy link that drive master and backup states on the two CSSs:
ï‚§ The first condition is maintaining the heartbeat, which is an advertisement every second. The master CSS provides this heartbeat on the redundancy link, and the backup CSS keeps track of the heartbeat every three seconds (default). If the heartbeat times out (for example, heartbeats are not detected in this period), then the backup takes over as master.
The new master CSS begins sending out redundancy protocol messages as well as gratuitous Address Resolution Protocol (ARP) messages to update the ARP tables on neighboring nodes and the forwarding tables of attached bridging devices (for example, Layer 2 switches) with the new master CSS MAC address. The CSS transmits one ARP request packet and one ARP reply packet for every gratuitous ARP invocation.
ï‚§ The second condition is that of a VRRP switch priority change. The CSS advertising the highest priority is negotiated to become master. This is the mechanism used by the uplink services, and some of the special commands (described below) for initiating a failover event.
Note that in the event that the CSSs are misconfigured (for example, two or more CSSs are set up as the IP redundancy master), the CSS with the highest VRRP IP address takes over as the master.
Issue the ip redundancy command to enable CSS-to-CSS redundancy on two CSSs interfaced with a crossover cable. By default, redundancy is disabled on the CSSs until you issue this command on both CSSs.
When you include the master option with this command, you can designate which CSS is the master CSS. Initially, booting two CSSs interfaced with a crossover cable determines which is the master and which is the backup. The CSS that boots first is the master CSS. If the CSSs boot at the same time, the CSS with the numerically higher IP address becomes the master.
When you issue the ip redundancy master command on the CSS, the CSS becomes the master CSS. You can issue this command on either the current master or backup. If you issue the master option on the backup CSS, the CSS becomes the master and the other CSS automatically becomes the backup.
If you designate a master CSS, the CSS regains master status after going down and then comes up again. For example, when the master CSS goes down, the backup CSS becomes master. When the former designated master CSS comes up again, however, the CSS becomes the master again.
Contd page 2.....
page 2....
If you have no requirement to designate a CSS as the master when both CSSs are up, do not include the master option when enabling redundancy on the master CSS.
You can create a service that is associated with a router's IP address. This service enables the master CSS to monitor the router with a keepalive (ICMP). If the keepalive fails, the master relinquishes control and the backup CSS takes control. You can configure more than one service by issuing the type redundancy-up command; the CSSs use all redundancy uplinks when making the failover decision.
If a CSS is active, and loses all uplinks designated as redundancy-up, the CSS relinquishes the active state and becomes the backup. The CSS uses the redundancy protocol to inform the other CSS to become active. If both CSSs have lost their uplinks, a CSS stays in the active state for 45 seconds, waiting for the uplink to come alive. After 45 seconds, if there is still no viable uplink, the CSS goes into backup mode, giving the other switch a try. This allows both CSSs to get a chance to test their uplinks without thrashing back and forth many times each minute.
Note: A CSS goes into failover when there are no longer live uplink services.
Whenever a failover event happens in general usually a G-ARP is sent after a failover to update arp/cam tables.
for an active-active stateful failover scenario where the two Content Services Switches (CSS) are in one-armed mode. The configuration in this document combines three major components:
• Active-active failover means that a minimum of two virtual IP addresses are used. Each CSS is the master for one VIP and the backup for the other one.
• Stateful failover indicates that upon failover there is no traffic interruption. The backup CSS knows from the master CSS which flows it receives in case of failover.
• One-armed mode failover means that the CSS is connected to a single VLAN. This scenario requires additional configuration to make sure that the server response goes through the CSS. In this configuration, client NAT (source group) is used.
Here is the URL for the configuration for the Configuring VIP and Virtual IP Interface Redundancy follow the configuration guide which may help you
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.20_v8.10/configuration/redundancy/guide/VIPRedun.html
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.20_v8.10/configuration/redundancy/guide/ASR.html
Configuring Box to box redundancy:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.20_v8.10/configuration/redundancy/guide/Redndncy.html
CSS 11500 Active-Active Stateful Failover ASR in One-Armed Mode Configuration Example
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_configuration_example09186a00802206a3.shtml
Box-to-Box Redundancy on the CSS 11xxx Configuration Example - Ciscowiki
http://supportwiki.cisco.com/ViewWiki/index.php/Box-to-Box_Redundancy_on_the_CSS_11xxx_Configuration_Example
Kindly find full range of configuration examples on CSS here :
Cisco CSS 11500 Series Content Services Switches
Configuration Examples and TechNotes
http://www.cisco.com/en/US/products/hw/contnetw/ps792/prod_configuration_examples_list.html
http://supportwiki.cisco.com/ViewWiki/index.php/Category:Cisco_CSS_11500_Series_Content_Services_Switches
Kindly see URL given below for my other articles
http://boardreader.com/fp/Cisco_Systems_Networking_Profe_309110/Application_Networking_543840.html#hot_threads
If possible plz rate so that I can be helpful to other people also as it will enhance my credibility.
Sachinga.hcl
Thanks very helpful, beginning to understand it. Could you clarify one point. Am I correct in thinking that when using Active-Active VIP I must ensure that default gateway of the server uses the same CSS box as the redundant VIP?
Yes the CSS requires to see both side of a connection.
So, the response from the server must go through the same CSS.
This can be done by using different servers for each CSS and setting the gateway on the server to their own CSS.
Or you can use client nat with different nated ip for each CSS.
Gilles.
Each service needs to be assigned a redundant-index.
You do this only for the content rules that need to
be replicated from the master CSS to the backup.
Then you have to create circuit VLAN and then needd to add ip virtaul-router , then assign VIP to these Virtaul routers. Then define this virtual routers vip inside content alonf with the redundant-index fo the services.
Inside service create unique redundant-index which should be same on both the CSS's.
This way you can define Active/Active.
LB01
CSS NameLB01
Circuites
VLAN1- Private Front-End Zone
- Interfaces: GigaEthernet 0
- IP Address 10.70.2.x
VLAN2- Public Front-End Zone
- Interfaces: GigaEthernet 1
- IP Address 10.70.5.x
Redundancy
VLAN1- Master for APP VIP VRRP Instance and Slave for COM VIP VRRP Instance
- No Preempt for Master VRRP Instance
- Virtual Interface for each VRRP Instance
- Critical Service: upstream-downstream for both VRRP Instances
VLAN2- Master for APP VIP VRRP Instance and Slave for COM VIP VRRP Instance
- Virtual IP Address for each VRRP Instance
RoutesDefault Route to MFW01 PubFrontEnd IP Address (10.70.5.1)
ServicesIPProtocol/PortKeepaliveType
upstream-downstreamMFW01 PubFrontEnd IP AddressNoneScript "ap-kal-pinglist" to ping listed IPs (MFW01 and L2 Switch IP Address)None
BNKSec_S1APP1 IP AddressTCP/443Type: TCPLocal
BNKSec_S2APP2 IP AddressTCP/443Type: TCPLocal
BNKn_S1APP1 IP AddressTCP/808nType: http
Method: head
Local
BNKn_S2APP2 IP AddressTCP/808nType: http
Method: head
Local
COM1COM1 IP AddressTCP/7777Type: TCPLocal
COM2COM2 IP AddressTCP/7777Type: TCPLocal
Owners and Content RulesVIP/Protocol/PortDomain NameServicesStickiness
BNKSec-HTTPS-RuleAPP VIP/TCP/443NoneBNKSec_S1
BNKSec_S2
None
BNKn-HTTP-RuleAPP VIP/TCP/80BNKn.Domain_NameBNKn_S1
BNK
n_S2
None
COM-RuleCOM VIP/TCP/7777NoneCOM1
COM2
None
LB02
CSS NameLB02
Circuites
- IP Address regarding to IP Addressing Schema
Redundancy
VLAN1- Master for COM VIP VRRP Instance and Slave for APP VIP VRRP Instance
- Preempt for Master VRRP Instance
VLAN2- Master for COM VIP VRRP Instance and Slave for APP VIP VRRP Instance
Method: head
Local
Method: head
Local
BNKSec_S2
None
BNK
n_S2
None
COM2
None
Message was edited by: tabishmirza Is this correct configuration as per above requirement ?. Please verify. CSS-1 Configuration ****************Global********************** ip redundancy ip route 0.0.0.0 0.0.0.0 10.70.5.1 *****************Interface****************** Interface Gi0   bridge 1 Interface Gi1   bridge 2 *****************Circuit******************** circuit VLAN1 ip address 10.70.2.1 255.255.255.0 ip virtual-router 1 priority 101 ip virtual-router 2 ip redundant-interface 1 10.70.2.254  default gateway ip redundant-interface 2 10.70.2.253  default gateway ip critical-service 1 upstream_downstream ip critical-service 2 upstream_downstream circuit VLAN2 ip address 10.70.5.3 255.255.255.0 ip virtual-router 3 priority 101 ip virtual-router 4 ip redundant-vip 3 10.70.5.100 ip redundant-vip 4 10.70.5.101 ip redundant-interface 3 10.70.5.254 ip redundant-interface 4 10.70.5.253 ip critical-service 3 upstream_downstream ip critical-service 4 upstream_downstream *****************Services******************** service upstream_downstream ip address 10.70.5.1 (IP address of MFW01) keepalive type script ap-kal-pinglist “10.70.5.1 ” service BNKSec_S1   protocol tcp   ip address 10.70.2.20   port 443   keepalive type tcp   active service BNKSec_S2   protocol tcp   ip address 10.70.2.21   port 443   keepalive type tcp   active service BNKn_S1   protocol tcp   ip address 10.70.2.20   port 80   keepalive type tcp   active service BNKn_S2   protocol tcp   ip address 10.70.2.21   port 80   keepalive type tcp   active service COM1   protocol tcp   ip address 10.70.2.10   port 7777   keepalive type tcp   active service COM2   protocol tcp   ip address 10.70.2.11   port 7777   keepalive type tcp   active *****************Owner*********************** Owner Sample   Content BNKSec-HTTPS-Rule     protocol tcp     port 443     add BNKSec_S1     add BNKSec_S2     vip 10.70.5.100     active   Content BNKn-HTTP-Rule     protocol tcp     port 80     add BNKn_S1     add BNKn_S2     vip 10.70.5.100     active     Content COM-Rule     protocol tcp     port 7777     add COM1     add COM1     vip 10.70.5.101     active ------------------------------------------------------ CSS-2 Configuration ****************Global********************** ip redundancy ip route 0.0.0.0 0.0.0.0 10.70.5.1 *****************Interface****************** Interface Gi0   bridge 1 Interface Gi1   bridge 2 *****************Circuit******************** circuit VLAN1 ip address 10.70.2.2 255.255.255.0 ip virtual-router 1 ip virtual-router 2 priority 101 ip redundant-interface 1 10.70.2.254 ip redundant-interface 2 10.70.2.253 ip critical-service 1 upstream_downstream ip critical-service 2 upstream_downstream circuit VLAN2 ip address 10.70.5.4 255.255.255.0 ip virtual-router 3 ip virtual-router 4 priority 101 ip redundant-vip 3 10.70.5.100 ip redundant-vip 4 10.70.5.101 ip redundant-interface 3 10.70.5.254 ip redundant-interface 4 10.70.5.253 ip critical-service 3 upstream_downstream ip critical-service 4 upstream_downstream *****************Services******************** service upstream_downstream ip address 10.70.5.1 (IP address of MFW01) keepalive type script ap-kal-pinglist “10.70.5.1 ” service BNKSec_S1   protocol tcp   ip address 10.70.2.20   port 443   keepalive type tcp   active service BNKSec_S2   protocol tcp   ip address 10.70.2.21   port 443   keepalive type tcp   active service BNKn_S1   protocol tcp   ip address 10.70.2.20   port 80   keepalive type tcp   active service BNKn_S2   protocol tcp   ip address 10.70.2.21   port 80   keepalive type tcp   active service COM1   protocol tcp   ip address 10.70.2.10   port 7777   keepalive type tcp   active service COM2   protocol tcp   ip address 10.70.2.11   port 7777   keepalive type tcp   active *****************Owner*********************** Owner Sample   Content BNKSec-HTTPS-Rule     protocol tcp     port 443     add BNKSec_S1     add BNKSec_S2     vip 10.70.5.100     active   Content BNKn-HTTP-Rule     protocol tcp     port 80     add BNKn_S1     add BNKn_S2     vip 10.70.5.100     active     Content COM-Rule     protocol tcp     port 7777     add COM1     add COM1     vip 10.70.5.101     active
Is this correct configuration as per above requirement ? Please verify. Will be appreciated your kind help.  Thanks
CSS-1 Configuration
ip redundancy
Interface Gi0
  bridge 1
Interface Gi1
  bridge 2
circuit VLAN1
ip virtual-router 2
circuit VLAN2
ip virtual-router 4
service BNKSec_S1
  protocol tcp
  port 443
  keepalive type tcp
  active
service BNKSec_S2
  protocol tcp
  port 443
  keepalive type tcp
  active
service BNKn_S1
  protocol tcp
  port 80
  keepalive type tcp
  active
service BNKn_S2
  protocol tcp
  port 80
  keepalive type tcp
  active
service COM1
  protocol tcp
  port 7777
  keepalive type tcp
  active
service COM2
  protocol tcp
  port 7777
  keepalive type tcp
  active
Owner Sample
    protocol tcp
    port 443
    add BNKSec_S1
    add BNKSec_S2
    vip 10.70.5.100
    active
    protocol tcp
    port 80
    add BNKn_S1
    add BNKn_S2
    vip 10.70.5.100
    active
  Content COM-Rule
    protocol tcp
    port 7777
    add COM1
    add COM1
    vip 10.70.5.101
    active
CSS-2 Configuration
ip redundancy
Interface Gi0
  bridge 1
Interface Gi1
  bridge 2
circuit VLAN1
ip virtual-router 1
circuit VLAN2
ip virtual-router 3
service BNKSec_S1
  protocol tcp
  port 443
  keepalive type tcp
  active
service BNKSec_S2
  protocol tcp
  port 443
  keepalive type tcp
  active
service BNKn_S1
  protocol tcp
  port 80
  keepalive type tcp
  active
service BNKn_S2
  protocol tcp
  port 80
  keepalive type tcp
  active
service COM1
  protocol tcp
  port 7777
  keepalive type tcp
  active
service COM2
  protocol tcp
  port 7777
  keepalive type tcp
  active
Owner Sample
    protocol tcp
    port 443
    add BNKSec_S1
    add BNKSec_S2
    vip 10.70.5.100
    active
    protocol tcp
    port 80
    add BNKn_S1
    add BNKn_S2
    vip 10.70.5.100
    active
  Content COM-Rule
    protocol tcp
    port 7777
    add COM1
    add COM1
    vip 10.70.5.101
    active
