Showing results forĀ
Search instead forĀ
Did you mean:Ā
inline and out of path compatibility
svbyrne
hello
I need to install 2 x WAAS appliances
Data Centre  side install is out of path using WCCP V2 for traffic redirect
the Branch office topology does not support WCCP : I plan to install inline
Q is this topology supported ?
thanks
Nicolas Fournier
There is no problem having WCCP on one side of your WAAS setup and Inline on the other as long as both devices are getting all the traffic between those two sites.
This is a totally supported setup.
Nicolas
Nicolas
thank you for this information
regards
Sean Byrne
