Netflow using UDP port 9995
Jan Rockstedt
Hi all,
I need to be able to send and netflow from our's WAE using UDP port 9995.
I this posible, if not in what version will it be?
Regards Jan Rockstedt
Nicolas Fournier
Hi Jan,
As discussed over the Ask The Expert event, there is no way to setup a custom port for WAAS Netflow reporting:
WAVE-474-1(config)#flow monitor tcpstat-v1 host 1.1.1.1 ?
WAVE-474-1(config)#flow monitor tcpstat-v1 enable ?
WAVE-474-1(config)#
Nicolas
