Beginner
TACACS auth using AD on WAAS
We are using AD and Internal User auth to log in to our network devices via TACACS.  I'm having an issue with logging in (ssh) to our WAAS devices where the internal user account works fine, however if I use my AD account my terminal session errors out (see attached.)
The TACACS authentication logs show both accounts passing authentication.
I have also set the attribute for the WAAS device on the ACS server as it states to do in the following link: http://www.cisco.com/c/en/us/support/docs/security/secure-access-control...
Looking to see if anyone has run into an issue like this before, or may possibly know what's going on here.  I've tried different terminal programs as well.  Putty shows the error attached, SecureCRT gives a forbidden error.
Cisco Application Deployment Engine OS Release: 2.2
ADE-OS Build Version: 2.2.3.002
ADE-OS System Architecture: x86_64
Copyright (c) 2005-2015 by Cisco Systems, Inc.
All rights reserved.
Hostname: a05837
Version information of installed applications
Cisco ACS VERSION INFORMATION
Version : 5.8.1.4
Internal Build ID : B.462
Thanks in advance.
Everyone's tags (7)
