Activate auto-answer calls using Cisco Finesse API
pumpmexican
I need to enable automatic call answering on a particular extension using the Cisco Finesse API. I once found on these forums that it was possible, but I can't find the post or answer anymore. Is my assumption correct?
dhiarumu
Could you please clarify: are you using FIPPA service or Finesse desktop?
Generally auto-answer setting can be configured in CCE agent desk settings or CUCM.
Dhina
Hi Dhina,
I'm using Finesse desktop, but in the document of Cisco Finesse API Webservice I remember using a option for activate auto-answer an extension.
Isaac
Hi Isaac,
Apparently there is no such option in Finesse API Webservices.
Alternatively, we can try this - have a workflow created in cfadmin, trigger that when a call arrives, and define action as REST PUT request  to /finesse/api/Dialogs/<dialogId> to answer the call with the extension.
But, this workflow can be assigned only to a team, may not be possible to apply for a specific extension.
Dhina
PTS
If you are open to 3rd party solution then you can check out MARS Auto Answer for your requirement
PFA a short writeup on the solution
For more details you can write to info@parsec-tech.com
