Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
HEllo,According to the UDS documentation, the "max" parameter for a GET to the /users node "[m]ust be less than what is specified in Enterprise Parameters, User Data Services, User Search Limit Setting."In my experience this is incorrect.  If you req...
Hello,I'm trying to generate a ringback tone for a call (the user that made the call should hear this ringing). So when the call receives the Ringback status, I'm callinglineGenerateTone(hCall, LINETONEMODE_RINGBSCK, 0, 0, NULL)The problem is that I ...
In my tests the following foes NOT work:A calls B which answersB conferences C which answersB completes conferenceC conferences D which answersC cannot complete conference, neither through the physical phone nor CTIHowever, this slightly different ca...
Hi,I'm developing barge functionality using JTAPI, and have some questions about this:1. According to the developer's guide, "This feature gets activated when an address TerminalConnection is in the passive state and CallCtlTerminalConnection is in t...
linren0630 by Community Member
  • 1292 Views
  • 2 replies
Hello,I would like to develop an application that could detect calls received on specific extension including caller number and call id. could anyone provide me with SDK or any document that could help me.Regards,Mah
Hello,We have our CTI Application (JTAPI) controlling a CTI Route Point, which plays an announcement and then, when we determine where to route the call, it transfers it to a rep. We try to support redundancy in our CTI application and we are looking...
Hello,so I need to read out a 8KHz, 16-bit G.711 u-law incoming audio format. What is a good algorithm to call EpStreamRead? Is there an event when I need to call this function? Or do I have to set up a timer (and with what period)? Thanks,Istvan
