Call Start Time
razaali20
Community Member
Is it possible to get a start time of a call using jtapi?
(I understand that adding an observer, capturing call connected event, and then recording the time is one way, but is there a stored property somewhere where this is tracked?)
derrickgunter
Level 3
Level 3
I don't think jtapi has any such stored item.  Like you said, I think the only way is observing, which you are probably doing anyway if you are using jtapi.  First events are typically CallActiveEvent and/or ConnCreatedEvent.
mpotluri
Level 9
Level 9
You can probably look into the CDR interfaces if real time info is not needed. Search for Cisco SOAP - CDRonDemand Service on Devnet for API to interface with CDR.
derrickgunter
Level 3
Level 3
