How get CallLegID from CiscoCallEv
In CiscoJtapi01.log I see that coming event
3324: may 22 14:30:30.642 MSD %JTAPI-PROTOCOL-7-UNK:(P1-10.0.3.3) received Event: com.cisco.cti.protocol.CallStateChangedEvent {
  eventSequence                     = 150
  lineCallManagerID                 = 1
  lineID                            = 29530
  callCallManagerID                 = 1
callLegID                         = 30239392
  state                             = 1
  cause                             = 16
  farEndpointSpecified              = true
  farEndpointCallManagerID          = 1
  farEndpointType                   = 2
  fwdDestinationAddress             = null
  reason                            = 1
  callingParty                      = 4403
  callingPartyName                  = Vladimir
  calledParty                       = 5215
  calledPartyName                   = Vladimir
  originalParty                     = 5215
  originalPartyName                 = Vladimir
  lastRedirectingParty              =
  lastRedirectingPartyName          =
  callingPartyDeviceName            = SIP-01
  mediaDeviceName                   =
  mediaResourceId                   = 0
  bRemoteInUse                      = false
  bPrivacy                          = false
  callSelectStatus                  = 0
  unModifiedCallingParty            = 4403
  unModifiedCalledParty             = 5215
  unModifiedOriginalCalledParty     = 5215
  unModifiedLastRedirectingParty    =
  callingPartyPi                    = true
  callingPartyNamePi                = true
  calledPartyPi                     = true
  calledPartyNamePi                 = true
That is, in the event there is a field CallLegID?
How I get CallLegID from CiscoCallEv?
derrickgunter
Level 5
Level 5
CallLegID is actually from the object CiscoConnectionID which is obtained from CiscoConnection.
So, as long as you can get the CiscoConnection from the event you can get the callLegID.
For example, for CallCtlTermConnRingingEv:
void handleRing (CallCtlTermConnRingingEv ev)
  int callLegId = ((CiscoConnection)ev.getTerminalConnection().getConnection()).getConnectionID().intValue();
6 Replies 6
derrickgunter
Level 5
Level 5
Thank you very much!
I have tried so, but I forgot to convert Event
upchaurasia
CiscoCall objCiscoCall = (CiscoCall) eventList[i].getCall();
String strCallId=objCiscoCall.getCallID().toString();
Hope this will help you.
Umesh
No. It GlobalCallID and I have callLegID
objCiscoCall.getCallID().toString() returns what we call GCID of the call. The callLegID high lighted in callstateChangedEv is not GCID.
Why do you need callLegID?
I need to get a called number and calling number from CallLegID for recording system.
Because the method provider.getcall(int CallLegID) works unstable in my CUCM https://communities.cisco.com/thread/52725
My CUCM version is 7.1
