JTAPI Whisper Coaching
Hi Team,
I have successfully achieved silent monitoring supervisor functionality with JTAPI & CUCM but I'm stuck on updating this feature into a whisper coaching
                        srcAdd = makecall.provider.getAddress("2030"); // Agent DN to be monitored
                        CiscoCall aCall =   (CiscoCall) makecall.provider.createCall();
                        try {
                            wait (2000);
                            aCall.startMonitor(makecall.provider.getTerminal("faisalqa1"),makecall.provider.getAddress("2091"),
                                    srcAdd.getConnections()[0].getTerminalConnections()[0],
                                    CiscoCall.WHISPER_MONITOR   // updated this for whisper coaching feature to be enabled
,CiscoCall.PLAYTONE_LOCALONLY);
                           } catch (Exception e) {
                            e.printStackTrace();
I have updated the monitorType in startMonitor call to WHISPER_MONITOR but it doens't work. Is there something missing ?
ayush.shyam
Again!
Use "updateMonitorType" method and then you will be able to do that. I hope you got the answer what you are looking for! Thanks
