12-07-2016 09:33 PM
Hi Team
We want to play announce before ringing the phone. Does someone provide me working tcl script and configuration.
Call Flow
ISP--> SIP-VG-[TCL scrip should play announce file stored on VG] -SIP- CUCM-- Directory Number.
On this time, Tcl scrip working for pots dial-peer for following scnerio.
PSTN/PRI- -VG- CUCM- DN
"flash0:c2951-universalk9-mz.SPA.152-4.M6a.bin"
This is a new deployment.
CUCM version:10.0.1.12900-2
We have two CUCM server (Pub /Sub)
Application config;
File name:kisa2.au
application
service seskayit app_fax_detect.2.1.2.2.tcl
param mode listen-first
param prompt flash:kisa2.au
Solved! Go to Solution.
12-08-2016 04:00 AM
I delete other service and removed param mode but still failure.
service play2connect flash:play_message_2_calling_then_connect.tcl
param prompt-1 flash:kisa2.au
incoming dial-peer
dial-peer voice 74001 voip
session protocol sipv2
incoming called-number 08507227400$
voice-class sip bind control source-interface GigabitEthernet0/0
voice-class sip bind media source-interface GigabitEthernet0/0
dtmf-relay rtp-nte
codec g711ulaw
670343: Dec 8 16:57:39.100: //-1//SERV:/AFW_Service_CCInterface: Received Event 26 for service Default modulehandle NULL
1670344: Dec 8 16:57:39.100: //-1//SERV:/AFW_Service_GetExecEnv: Script Name = Default
1670345: Dec 8 16:57:39.100: //-1//SERV:/AFW_Service_GetExecEnv: Using Cached ExecEnv
1670346: Dec 8 16:57:39.100: //-1//AFW_:EE14E517DC000:/AFW_ExecEnv_SetRoot: Execenv = 0x14E517DC
1670347: Dec 8 16:57:39.100: //-1//AFW_:/AFW_M_TclModule_NewDup:
1670348: Dec 8 16:57:39.100: //-1//AFW_:HN750D2580:/AFW_M_TclModule_Free: MOD[TclModule_0x14E53660_2_1963790444] ( )
1670349: Dec 8 16:57:39.100: //-1//AFW_:/AFW_Process_Lock: pProcess(0xB5541BC)=1
1670350: Dec 8 16:57:39.100: //-1//AFW_:LP:EE14E517DC000:HN750DC9D4:/AFW_M_Object_SetExecEnv: ObjCount: 1, CmdPending 0
1670351: Dec 8 16:57:39.100: //-1//AFW_:EE14E517DC000:/AFW_ExecEnv_RestoreDataBackup: Restore DataArea from Script
1670352: Dec 8 16:57:39.100: //-1//AFW_:EE14E517DC000:/AFW_ExecEnv_RestoreDataBackup: Restore TokenTable from Script
1670353: Dec 8 16:57:39.100: //-1//AFW_:EE14E517DC000:/AFW_ExecEnv_Initiate: Execenv = 0x14E517DC
1670354: Dec 8 16:57:39.100: //-1//AFW_:EE14E517DC000:/AFW_ExecEnv_SetCallCorID:
1670355: Dec 8 16:57:39.100: CallCorID is ^]acV<^E^Qf6^_B^XYGHL
1670356: Dec 8 16:57:39.100: //-1//AFW_:/AFW_Leg_New:
1670357: Dec 8 16:57:39.100: //788201//AFW_:/AFW_M_Leg_SetExecEnv:
1670358: Dec 8 16:57:39.100: //-1//AFW_:EE14E517DC000:/AFW_ExecEnv_IncrPendingCmd: PendingCmdCount: 1
1670359: Dec 8 16:57:39.100: //-1//AFW_:LP:EE14E517DC000:LG788201:/AFW_M_Object_SetExecEnv: ObjCount: 2, CmdPending 1
1670360: Dec 8 16:57:39.100: //788201//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
1670361: Dec 8 16:57:39.100: //788201//AFW_:/AFW_M_Leg_GetHandle: Leg handle: LEG_788201
1670362: Dec 8 16:57:39.100: //-1//AFW_:EE14E517DC000:/AFW_ExecEnv_AssignCall: Execenv = 0x14E517DC, Leg = 788201, Peer_Tag = 7490
1670363: Dec 8 16:57:39.100: //788201//AFW_:/AFW_ExecEnv_SetCallCorID:
1670364: Dec 8 16:57:39.100: CallCorID is ^]acV<^E^Qf6^_B^XYGHL
1670365: Dec 8 16:57:39.100: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
1670366: Dec 8 16:57:39.100: //788201//AFW_:/AFW_Process_GetCcqEvent: Received
1670367: Dec 8 16:57:39.100: //-1//AFW_:/AFW_Process_GetCcqEvent: Event[CC_EV_CALL_SETUP_IND(34)] {
1670368: Dec 8 16:57:39.100: //-1//AFW_:/AFW_Process_GetCcqEvent: EXECENV[0x14E517DC][Default]
1670369: Dec 8 16:57:39.100: //-1//AFW_:/AFW_Process_GetCcqEvent: LEG[788201][LEG_INIT(0)][Cause(0)]
1670370: Dec 8 16:57:39.100: //-1//AFW_:/AFW_Process_GetCcqEvent: }
1670371: Dec 8 16:57:39.100: //788201//SSIN:/AFW_SS_MapEvent:
1670372: Dec 8 16:57:39.100: //788201//AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 3
1670373: Dec 8 16:57:39.100: //-1//SSIN:/AFW_SS_Telephony_MapEvent:
1670374: Dec 8 16:57:39.100: //-1//AFW_:/AFW_Util_SaveRawMsg:
1670375: Dec 8 16:57:39.100: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 14958 type 0
1670376: Dec 8 16:57:39.100: //788201/1D61E3D6B61F/AFW_:/incrementIncomingDialPeerCallStats: Incrementing call-stat to [-68] for dial-peer [7490]
1670377: Dec 8 16:57:39.100: //788201/1D61E3D6B61F/AFW_:/AFW_Object_WalkListeners:
1670378: Dec 8 16:57:39.100: //788201/1D61E3D6B61F/AFW_:/AFW_M_Object_ShowListeners: START
1670379: Dec 8 16:57:39.100: //-1//AFW_:/AFW_M_Object_ShowListeners:
1670380: Dec 8 16:57:39.100: //788201//AFW_:/AFW_M_Module_GetHandle: Module handle: TclModule_0xBFD64C8_2_1963837908MOD[TclModule_0xBFD64C8_2_1963837908] (
1670381: Dec 8 16:57:39.100: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCINIT(1)][Cause(0)]
1670382: Dec 8 16:57:39.100: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670383: Dec 8 16:57:39.100: //788201/1D61E3D6B61F/AFW_:/AFW_M_Object_ShowListeners: END
1670384: Dec 8 16:57:39.100: //788201/1D61E3D6B61F/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
1670385: Dec 8 16:57:39.100: //788201//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0xBFD64C8_2_1963837908 ---> TclModule_0xBFD64C8_2_1963837908
1670386: Dec 8 16:57:39.100: //788201//AFW_:/AFW_M_TclModule_Action:
1670387: Dec 8 16:57:39.100: //788201//AFW_:/AFW_TclModule_DefaultEvHandling:
1670388: Dec 8 16:57:39.100: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_CheckIncomingCallBlock:
1670389: Dec 8 16:57:39.100: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_SettlementValidateCall: target=, tokenp=0x0
1670390: Dec 8 16:57:39.100: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_IncomingTranslate:
1670391: Dec 8 16:57:39.100: //-1//AFW_:/AFW_Leg_IncomingTranslate: Tag(7490) calling[] redirect[] called[]
1670392: Dec 8 16:57:39.100: //-1//AFW_:/C_ServiceSession_Event_Handler:
1670393: Dec 8 16:57:39.100: //788201//XCCS:/C_PackageXCCSession_AcceptCallCheck: No AcceptCall; XCC application is unregistered
1670394: Dec 8 16:57:39.100: //-1//AFW_:/AFW_Session_New:
1670395: Dec 8 16:57:39.100: //-1//AFW_:/AFW_FSM_New:
1670396: Dec 8 16:57:39.100: //-1//AFW_:HN750DC9D4:/AFW_M_Session_SetExecEnv:
1670397: Dec 8 16:57:39.100: //-1//AFW_:LP:EE14E517DC000:HN750DC9D4:/AFW_M_Object_SetExecEnv: ObjCount: 3, CmdPending 1
1670398: Dec 8 16:57:39.100: //788201//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
1670399: Dec 8 16:57:39.100: //788201//AFW_:/AFW_M_Module_GetHandle: Module handle: Session_0x15B336A8_2_1963837908
1670400: Dec 8 16:57:39.100: //788201//AFW_:/C_PackageSession_NewCall: Session module listened by TclModule_0xBFD64C8_2_1963837908
1670401: Dec 8 16:57:39.100: //788201//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0xBFD64C8_2_1963837908 ---> Session_0x15B336A8_2_1963837908
1670402: Dec 8 16:57:39.100: //788201//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_OPEN[1],ev_setup_indication[34])---[C_Action]------
1670403: Dec 8 16:57:39.100: //788201//AFW_:/Open_SetupIndication: Calling #(), Calling Name (), Called #(), peer_tag(7490)
1670404: Dec 8 16:57:39.100: //-1//AFW_:/AFW_Util_GetCalledNumber: calledNumber =
1670405: Dec 8 16:57:39.100: //788201/1D61E3D6B61F/AFW_:/AFW_Object_AddListener: adding Module Session as listener
1670406: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 3
1670407: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_GenerateTone: ccTone 8 cptone 4
1670408: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_GetCodec:
1670409: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_GetCodec: Telephony leg. Default codec is assumed
1670410: Dec 8 16:57:39.104: //788201//Digi:/C_DigitCollect_Start: Leg=788201, Dialplan=True, Diaplanterm=False, DigitReport=False, DigitConsume=False IgnoreInitialKey=False, IgnoreDTMFacceptINFO=True, Abortkey=^@, Terminationkey=#, Numpatterns=0, Maxdigits=0, Mindigits=0, Interruptprompt=False, InterTimeout=-1000, Initialtimeout=-1000, Mask=0 Hotword=0
1670411: Dec 8 16:57:39.104: //-1//Digi:/AFW_DigitCollect_New:
1670412: Dec 8 16:57:39.104: //-1//Digi:HN750DC9D8:/AFW_DigitCollect_New: DialPlan=TRUE AbortKey=^@ TermKey=# NumPatts=0
Enable=FALSE Consume=FALSE InterruptPrompt=FALSE minDigits=0 maxDigits=0 DialPlanTerm=FALSE hotword=0
1670413: Dec 8 16:57:39.104: //-1//AFW_:LP:EE14E517DC000:HN750DC9D8:/AFW_M_Object_SetExecEnv: ObjCount: 4, CmdPending 1
1670414: Dec 8 16:57:39.104: //788201//AFW_:/AFW_Object_AddListener: adding Module Session as listener
1670415: Dec 8 16:57:39.104: //788201//AFW_:/AFW_M_Module_GetHandle: Module handle: DigitCollect_0x14B6A748_2_1963837912
1670416: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_Object_AddListener: adding Module DigitCollect as listener
1670417: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/Digi:/DigitCollectStart_UpdateStats:
1670418: Dec 8 16:57:39.104: //788201//Digi:/DigitCollect_MLPPTuning:
1670419: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_PrecedenceDcValid:
1670420: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 3
1670421: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_PrecedenceDcValid: No Voice MLPP Info
1670422: Dec 8 16:57:39.104: //788201//Digi:/DigitCollect_MLPPTuning: Precednece Digit Collect not enabled
1670423: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_TypeAheadGet: no chars in buffer.
1670424: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 3
1670425: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_DigitReportEnable: Current: 0x0 Input: 0x2
1670426: Dec 8 16:57:39.104: //788201//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_GETTINGDEST[4])---------------
1670427: Dec 8 16:57:39.104: //788201//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x15B336A8_2_1963837908 ---> TclModule_0xBFD64C8_2_1963837908
1670428: Dec 8 16:57:39.104: //788201//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0xBFD64C8_2_1963837908 ---> TclModule_0xBFD64C8_2_1963837908
1670429: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_M_Event_Free:
1670430: Dec 8 16:57:39.104: //788201//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
1670431: Dec 8 16:57:39.104: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
1670432: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_Process_GetCcqEvent: Received
1670433: Dec 8 16:57:39.104: //-1//AFW_:/AFW_Process_GetCcqEvent: Event[CC_EV_CALL_REPORT_DIGITS_DONE(68)] {
1670434: Dec 8 16:57:39.104: //-1//AFW_:/AFW_Process_GetCcqEvent: EXECENV[0x14E517DC][Default]
1670435: Dec 8 16:57:39.104: //-1//AFW_:/AFW_Process_GetCcqEvent: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670436: Dec 8 16:57:39.104: //-1//AFW_:/AFW_Process_GetCcqEvent: }
1670437: Dec 8 16:57:39.104: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
1670438: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_Object_WalkListeners:
1670439: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_M_Object_ShowListeners: START
1670440: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[DigitCollect_0x14B6A748_2_1963837912] (
1670441: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670442: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670443: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[Session_0x15B336A8_2_1963837908] (
1670444: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[DigitCollect_0x14B6A748_2_1963837912] (
1670445: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670446: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670447: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670448: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670449: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[TclModule_0xBFD64C8_2_1963837908] (
1670450: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670451: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[Session_0x15B336A8_2_1963837908] (
1670452: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[DigitCollect_0x14B6A748_2_1963837912] (
1670453: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670454: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670455: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670456: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670457: Dec 8 16:57:39.104: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670458: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_M_Object_ShowListeners: END
1670459: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
1670460: Dec 8 16:57:39.104: //788201//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_0x14B6A748_2_1963837912
1670461: Dec 8 16:57:39.104: //788201//Digi:/AFW_M_DigitCollect_Action:
1670462: Dec 8 16:57:39.104: //788201//Digi:/act_DCRunning_RDone: id=788201 Enable succeeded.enable=0 matchDialplan=1 numPatterns=0matchDialplanTerm=0
1670463: Dec 8 16:57:39.104: //788201//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_0x14B6A748_2_1963837912 ---> NULL
1670464: Dec 8 16:57:39.104: //788201/1D61E3D6B61F/AFW_:/AFW_M_Event_Free:
1670465: Dec 8 16:57:39.104: //788201//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
1670466: Dec 8 16:57:39.700: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
1670467: Dec 8 16:57:39.700: //788201/1D61E3D6B61F/AFW_:/AFW_Process_GetCcqEvent: Received
1670468: Dec 8 16:57:39.700: //-1//AFW_:/AFW_Process_GetCcqEvent: Event[CC_EV_CALL_DIGIT_BEGIN(19)] {
1670469: Dec 8 16:57:39.700: //-1//AFW_:/AFW_Process_GetCcqEvent: EXECENV[0x14E517DC][Default]
1670470: Dec 8 16:57:39.700: //-1//AFW_:/AFW_Process_GetCcqEvent: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670471: Dec 8 16:57:39.700: //-1//AFW_:/AFW_Process_GetCcqEvent: }
1670472: Dec 8 16:57:39.700: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
1670473: Dec 8 16:57:39.700: //788201/1D61E3D6B61F/AFW_:/AFW_M_Event_Free:
1670474: Dec 8 16:57:39.700: //788201//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
1670475: Dec 8 16:57:39.792: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
1670476: Dec 8 16:57:39.792: //788201/1D61E3D6B61F/AFW_:/AFW_Process_GetCcqEvent: Received
1670477: Dec 8 16:57:39.792: //-1//AFW_:/AFW_Process_GetCcqEvent: Event[CC_EV_CALL_DIGIT_END(18)] {
1670478: Dec 8 16:57:39.792: //-1//AFW_:/AFW_Process_GetCcqEvent: EXECENV[0x14E517DC][Default]
1670479: Dec 8 16:57:39.792: //-1//AFW_:/AFW_Process_GetCcqEvent: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670480: Dec 8 16:57:39.792: //-1//AFW_:/AFW_Process_GetCcqEvent: }
1670481: Dec 8 16:57:39.792: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
1670482: Dec 8 16:57:39.792: //788201/1D61E3D6B61F/AFW_:/AFW_M_Leg_EventPreProcess: Passing, not enabled.---
1670483: Dec 8 16:57:39.792: //788201/1D61E3D6B61F/AFW_:/AFW_Object_WalkListeners:
1670484: Dec 8 16:57:39.792: //788201/1D61E3D6B61F/AFW_:/AFW_M_Object_ShowListeners: START
1670485: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[DigitCollect_0x14B6A748_2_1963837912] (
1670486: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670487: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670488: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[Session_0x15B336A8_2_1963837908] (
1670489: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[DigitCollect_0x14B6A748_2_1963837912] (
1670490: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670491: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670492: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670493: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670494: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[TclModule_0xBFD64C8_2_1963837908] (
1670495: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670496: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[Session_0x15B336A8_2_1963837908] (
1670497: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[DigitCollect_0x14B6A748_2_1963837912] (
1670498: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670499: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670500: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670501: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670502: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670503: Dec 8 16:57:39.792: //788201/1D61E3D6B61F/AFW_:/AFW_M_Object_ShowListeners: END
1670504: Dec 8 16:57:39.792: //788201/1D61E3D6B61F/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
1670505: Dec 8 16:57:39.792: //788201//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_0x14B6A748_2_1963837912
1670506: Dec 8 16:57:39.792: //788201//Digi:/AFW_M_DigitCollect_Action:
1670507: Dec 8 16:57:39.792: //788201//Digi:/act_DCRunning_Digit: : pLeg 788201 Digit 3 Tone Mode 0
1670508: Dec 8 16:57:39.792: //788201//Digi:/DigitCollect_TreatDigit:
1670509: Dec 8 16:57:39.792: //788201//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=3
1670510: Dec 8 16:57:39.792: //788201//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
1670511: Dec 8 16:57:39.792: //788201//Digi:/DigitCollect_DialPlanMatch: Match single infotype
1670512: Dec 8 16:57:39.792: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_DigitReportDisable: Current: 0x2 Input: 0x1
1670513: Dec 8 16:57:39.792: //788201//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_0x14B6A748_2_1963837912 ---> NULL
1670514: Dec 8 16:57:39.792: //788201/1D61E3D6B61F/AFW_:/AFW_M_Event_Free:
1670515: Dec 8 16:57:39.792: //788201//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
1670516: Dec 8 16:57:39.792: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
1670517: Dec 8 16:57:39.792: //788201/1D61E3D6B61F/AFW_:/AFW_Process_GetCcqEvent: Received
1670518: Dec 8 16:57:39.792: //-1//AFW_:/AFW_Process_GetCcqEvent: Event[CC_EV_CALL_REPORT_DIGITS_DONE(68)] {
1670519: Dec 8 16:57:39.792: //-1//AFW_:/AFW_Process_GetCcqEvent: EXECENV[0x14E517DC][Default]
1670520: Dec 8 16:57:39.792: //-1//AFW_:/AFW_Process_GetCcqEvent: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670521: Dec 8 16:57:39.792: //-1//AFW_:/AFW_Process_GetCcqEvent: }
1670522: Dec 8 16:57:39.792: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
1670523: Dec 8 16:57:39.792: //788201/1D61E3D6B61F/AFW_:/AFW_Object_WalkListeners:
1670524: Dec 8 16:57:39.792: //788201/1D61E3D6B61F/AFW_:/AFW_M_Object_ShowListeners: START
1670525: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[DigitCollect_0x14B6A748_2_1963837912] (
1670526: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670527: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670528: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[Session_0x15B336A8_2_1963837908] (
1670529: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[DigitCollect_0x14B6A748_2_1963837912] (
1670530: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670531: Dec 8 16:57:39.792: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670532: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670533: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670534: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[TclModule_0xBFD64C8_2_1963837908] (
1670535: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670536: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[Session_0x15B336A8_2_1963837908] (
1670537: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[DigitCollect_0x14B6A748_2_1963837912] (
1670538: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670539: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670540: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670541: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670542: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670543: Dec 8 16:57:39.796: //788201/1D61E3D6B61F/AFW_:/AFW_M_Object_ShowListeners: END
1670544: Dec 8 16:57:39.796: //788201/1D61E3D6B61F/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
1670545: Dec 8 16:57:39.796: //788201//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_0x14B6A748_2_1963837912
1670546: Dec 8 16:57:39.796: //788201//Digi:/AFW_M_DigitCollect_Action:
1670547: Dec 8 16:57:39.796: //788201//Digi:/act_DCRunning_RDone: id=788201 Reporting disabled.
1670548: Dec 8 16:57:39.796: //-1//Digi:/DigitCollect_Complete: DC_INVALID_NUMBER. Digits=3
1670549: Dec 8 16:57:39.796: //788201//Digi:/DigitCollect_MLPPPostAdjust: Non MLPP call
1670550: Dec 8 16:57:39.796: //-1//AFW_:/AFW_Event_New: Event ID: ev_collectdigits_done(246)
1670551: Dec 8 16:57:39.796: //788201//AFW_:/AFW_Module_ReturnArgEv:
1670552: Dec 8 16:57:39.796: //788201//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[788201 ][LEG_INCACKED(2)][Cause(0)]}
1670553: Dec 8 16:57:39.796: //788201/1D61E3D6B61F/AFW_:/AFW_Object_RemoveListener:
1670554: Dec 8 16:57:39.796: //788201//AFW_:/AFW_Module_UnListen: NumObjects: 0
1670555: Dec 8 16:57:39.796: //788201//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_0x14B6A748_2_1963837912 ---> NULL
1670556: Dec 8 16:57:39.796: //788201/1D61E3D6B61F/AFW_:/AFW_M_Event_Free:
1670557: Dec 8 16:57:39.796: //788201//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
1670558: Dec 8 16:57:39.796: //788201//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
1670559: Dec 8 16:57:39.796: //788201//AFW_:/AFW_Process_GetPriorityQEvent: Received
1670560: Dec 8 16:57:39.796: //-1//AFW_:/AFW_Process_GetPriorityQEvent: Event[APP_EV_DIGITCOLLECT_DONE(246)] {
1670561: Dec 8 16:57:39.796: //-1//AFW_:/AFW_Process_GetPriorityQEvent: EXECENV[0x14E517DC][Default]
1670562: Dec 8 16:57:39.796: //-1//AFW_:/AFW_Process_GetPriorityQEvent: MOD[DigitCollect_0x14B6A748_2_1963837912] (
1670563: Dec 8 16:57:39.796: //-1//AFW_:/AFW_Process_GetPriorityQEvent: )
1670564: Dec 8 16:57:39.796: //-1//AFW_:/AFW_Process_GetPriorityQEvent: }
1670565: Dec 8 16:57:39.796: //788201//Digi:/AFW_M_DigitCollect_EventPreProcess:
1670566: Dec 8 16:57:39.796: //788201//Digi:/DigitCollectEnd_UpdateStats:
1670567: Dec 8 16:57:39.796: //788201//AFW_:/AFW_Object_WalkListeners:
1670568: Dec 8 16:57:39.796: //788201//AFW_:/AFW_M_Object_ShowListeners: START
1670569: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[Session_0x15B336A8_2_1963837908] (
1670570: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[DigitCollect_0x14B6A748_2_1963837912] (
1670571: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670572: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[788201][LEG_INCACKED(2)][Cause(0)]
1670573: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Object_ShowListeners: )
1670574: Dec 8 16:57:39.796: //788201//AFW_:/AFW_M_Object_ShowListeners: END
1670575: Dec 8 16:57:39.796: //788201//AFW_:/AFW_Object_WalkListeners: Entering Module : Session
1670576: Dec 8 16:57:39.796: //788201/1D61E3D6B61F/AFW_:/AFW_Object_AddListener: adding Module Session as listener
1670577: Dec 8 16:57:39.796: //788201//AFW_:/AFW_Object_RemoveListener:
1670578: Dec 8 16:57:39.796: //788201//AFW_:/AFW_Module_UnListen: NumObjects: 1
1670579: Dec 8 16:57:39.796: //788201//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x15B336A8_2_1963837908
1670580: Dec 8 16:57:39.796: //788201//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_GETTINGDEST[4],ev_collectdigits_done[246])---[C_Action]------
1670581: Dec 8 16:57:39.796: //788201//AFW_:/GettingDest_DigitCollectDone: status(6) discCause(28) ovrlp(TRUE)
1670582: Dec 8 16:57:39.796: //788201//AFW_:/GettingDest_DigitCollectDone: Digit collection status = 6.
1670583: Dec 8 16:57:39.796: //788201//AFW_:/Session_Close: lastFailureCause 28
1670584: Dec 8 16:57:39.796: //788201//AFW_:/AFW_Module_Terminate: Terminating Module: Session_0x15B336A8_2_1963837908
1670585: Dec 8 16:57:39.796: //788201//AFW_:/AFW_M_Session_Terminate:
1670586: Dec 8 16:57:39.796: //788201//AFW_:/AFW_M_Session_Terminate: lastFailureCause 28
1670587: Dec 8 16:57:39.796: //788201//AFW_:/Session_Cleaner:
1670588: Dec 8 16:57:39.796: //788201//AFW_:/Session_Cleaner: lastFailureCause 28
1670589: Dec 8 16:57:39.796: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_Disconnect: Disconnecting Leg: LEG_788201
1670590: Dec 8 16:57:39.796: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_Disconnect: Disconnecting Leg: LEG_788201, Cause 28
1670591: Dec 8 16:57:39.796: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 3
1670592: Dec 8 16:57:39.796: //788201/1D61E3D6B61F/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 14958 type 2
1670593: Dec 8 16:57:39.796: //788201//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_CLOSING[20])---------------
1670594: Dec 8 16:57:39.796: //788201//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x15B336A8_2_1963837908 ---> NULL
1670595: Dec 8 16:57:39.796: //788201//AFW_:/AFW_Object_WalkListeners:
1670596: Dec 8 16:57:39.796: //788201//AFW_:/AFW_M_Object_ShowListeners: START
1670597: Dec 8 16:57:39.796: //788201//AFW_:/AFW_M_Object_ShowListeners: END
1670598: Dec 8 16:57:39.796: //788201//AFW_:/AFW_M_Event_Free:
1670599: Dec 8 16:57:39.796: //788201//AFW_:/AFW_M_Event_Free: MODULEDONEEVENT for a Module: DigitCollect_0x14B6A748_2_1963837912
1670600: Dec 8 16:57:39.796: //788201//AFW_:/AFW_Object_RemoveAllListener:
1670601: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 3, CmdPending 1
1670602: Dec 8 16:57:39.796: //-1//AFW_:HN750DC9D8:/AFW_M_Event_Free: ExecEnv objCount: 3
1670603: Dec 8 16:57:39.796: //788201//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
1670604: Dec 8 16:57:39.796: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
1670605: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Event_Free:
1670606: Dec 8 16:57:39.796: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
12-08-2016 06:42 PM
What is the failure here, I don't see script logs. Could you please explain more detail.
Raghavendra
12-08-2016 11:08 PM
Its worked as well. It was signaling issue.
My config summary:
incoming dial-peer;
dial-peer voice 74205 voip
incoming called-number 223223344$
voice-class codec 1
dtmf-relay rtp-nte
Many thanks,
12-08-2016 03:38 AM
Sorry for confusing,
I will move my call sip trunk tought ISP instead of pstn.
Its working now
when my calls routed via ip i will use play2connect.
