03-23-2017 08:19 AM
If no argument is given to the command "infotag get leg_state" there no error from TCL/IVR, but align errors. Also the router can crash but could not reproduce, if I can will post more info here.
Can be reproduced with the minimum script
proc actHandoff {} {puts [infotag get leg_state]}
set fsm(INIT,ev_handoff) {actHandoff same_state}
fsm define fsm INIT
Mar 23 16:13:25: %ALIGN-3-SPURIOUS: Spurious memory access made at 0x334830B0z reading 0x4
*Mar 23 16:13:25: %ALIGN-3-TRACE: -Traceback= 0x334830B0z 0x36135EF0z 0x361227A0z 0x3613A530z 0x3613944Cz 0x33461B04z 0x334656ECz 0x33441864z
*Mar 23 16:13:25: %ALIGN-3-TRACE: -Traceback= 0x334830BCz 0x36135EF0z 0x361227A0z 0x3613A530z 0x3613944Cz 0x33461B04z 0x334656ECz 0x33441864z
*Mar 23 16:13:25: %ALIGN-3-TRACE: -Traceback= 0x334830C0z 0x36135EF0z 0x361227A0z 0x3613A530z 0x3613944Cz 0x33461B04z 0x334656ECz 0x33441864z
*Mar 23 16:13:25: %ALIGN-3-TRACE: -Traceback= 0x334830CCz 0x36135EF0z 0x361227A0z 0x3613A530z 0x3613944Cz 0x33461B04z 0x334656ECz 0x33441864z
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.6(3)M, RELEASE SOFTWARE (fc1)
03-23-2017 09:23 PM
Did you try to pass legId, do you have any issues.
set legState [infotag get leg_state $legID]
Raghavendra
03-24-2017 12:33 AM
Please understand the point I'm trying to make:
Incorrect usage of TCL/IVR statements (missing mandatory parameter in this case), normally causes an error from the subsystem. Not tracebacks and certainly not crashes.
03-24-2017 01:30 AM
I understand your issue, thanks for the info. I will forward it to Dev Team.
Raghavendra
03-24-2017 03:25 AM
