Good day all, We have 3rd party sip phone register on callmanger,but when some cisco extension call it,it will display the extension number@ipaddress of callmanger,so anyone know which message header can i remove for hiddening this ipaddress of c...
Hi,let say that I am not a developer expert.I am trying to change Callforward settings of a user.I am using FF Poster to test. The URL is https://{host}:8443/cucm-uds/user/{userId}If I do a GET it succesfully retrieves the user xml page.The issue is ...
Hi All,I need to modify this script to change this header. Can any one pls help me on this. Remote-Party-ID "London Test" ;party=calling;screen=yes;privacy=offToRemote-Party-ID "London Test" ;party=calling;screen=yes;privacy=fullThe script isM = {}fu...
Hello,I really need your help about the integration capabilities of Cisco Unified IP Phones.In fact, I already checked the sdk, but my I m not a Cisco Professional so my understanding is not perfect.I'm a developer, and I try to extend my cisco phone...
Hi,One of our customer has deployment of 30000+ phones. Though we believe this should be multi-cluster deployment but as per information we have it’s a single cluster deployment. Our question is, if it’s a single cluster deployment then will there be...
Hi All,We are using JTAPI SendData API to send small alert messages to IP Phones. If specific phone is not connected in network the application gets timeout response. Can you please let us know , after how much time (after calling SendData method) ap...
The attached log shows a call to a hunt group (broadcast mode). Many of the events have FeatReason:12. What is the meaning of this code and where is the constant defined? I checked the usual CallCtlEv.java and CiscoCallEv.java etc but see no 12 def...
Hi Developers,I am developing a java application that get contacts’ information from UDS using Unmarshaller. My application needs a tomcat certificate in cucm server. It works well if the certificate is a self-signed cert; however, when I use CA cert...
Hello!I'm using JTAPI.I have a trouble with events from CUCM: sometimes there are different connections in CiscoCall, and sometimes there are no connections.Usually they are not in order.My task is to get device's name, which has hook off?.Best regar...
I need to write a tcl ivr application to validate a received redirecting number against a list of 1000 valid RNIEs provisioned. I have found a few examples I can study, but I just found how to display on a 2431 the list of built-in scripts below fro...
Hi Friends,What does FeatReason:33 in JTAPI events mean? I can't find this defined in the Cisco JTAPI docs. Like this:2136: Nov 03 16:49:21.536 ADT %JTAPI-JTAPI-7-UNK:(P1-devuser1) 1184538/1 ConnCreatedEv 6017::1 [#126] Cause:100 CallCtlCause:0 Cisc...
The JTAPI developers guide indicates that CiscoRemoteTerminal getRegistrationType() returns either EXTEND_MEDIA_REGISTRATION or NO_EXTEND_MEDIA_REGISTRATION. The guide later states:EXTEND_MEDIA_REGISTRATION = 8This registration type applies to CUCSF...
Hi All, do anybody know, if there is chance to monitoring calls for SIP phone on SRST (CME in SRST mode) gateway?I need to receive information about ringing and connected call - calling and called numbers.I tried:- CME CTI - this API doesn't support...
Hello,Is there a Sandbox where I can experiment with CME CTI APIs?Yazan
| Subject | Author | Posted |
| 07-22-2026 03:11 PM | ||
| 12-14-2025 04:02 AM | ||
| 10-17-2025 12:27 AM | ||
| 07-22-2025 11:48 PM | ||
| 07-10-2025 11:24 PM |
