Backup Issue
Hello all ,
I have a new issue when trying to take the backup from the DNA Center . taken this ( Cisco DNA Center (without Assurance data)) but i can't take all data
How to solve it
Dear all
the full backup (with assurance data) is taken successfully after restarting the NFS service on the server and removing the external server via the GUI, waiting about 15 minutes, and then adding the configuration again
thanks for support
edust
It failed in the elasticsearch portion so most likely you have an issue with elasticsearch touching the server directory. This can be caused by several different issues in the Cisco DNA Center containers/pods/services. You may be able to quickly fix the problem by removing the external server via the GUI, waiting about 15 minutes, and then adding the configuration back. If that does not work you will need to open a TAC case to look into why elasticsearch is failing.
This (re-adding the NFS/remote config in GUI) helped after also a chown to nobody:nogroup on the NFS share the directory;
$ sudo chown nobody:nogroup /var/nfsshare
https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/2-1-2/admin_guide/b_cisco_dna_center_admin_guide_2_1_2/b_cisco_dna_center_admin_guide_2_1_1_chapter_0110.html#task_jbm_mnf_pdb
Dear all
thanks for support
