05-14-2024 05:03 AM
Hello dear
I need your support to know if i can to bridge L2 VLAN with L2 Sub-interface in the same device C9500-48Y4C
to pass the service through this VLAN
05-14-2024 05:15 AM
what is the use case here, can you give some example what you looking achieve? (there may be other way around to fix the issue depends on the requirement)
check the guide lines and limitation of bridging :
check some new added on 17.13 :
05-14-2024 05:22 AM - edited 05-14-2024 05:22 AM
my device B is connected to Customer Devices A and C ... B connected with A through portswitch port type ( trunk )
B connected with C through no switchport port type (Sub-interfaces)
now how can i pass any VLAN from A to C through B ?
05-14-2024 06:02 AM
You will need to convert the routed port to a switched port. I don't believe that there is any (sensible) way to achieve L2 bridging through a L3 interface.
