Built in variables and Jinja templates
rasmus.elmholt
Level 7
Level 7
I have made an onboarding template with the following Jinja code:
{% set ifrange = 'gi1/0/1-24' %}
{% if '9300L' in __device.family %}
{% set ifrange = 'gi1/0/1-12' %}
{% endif %}
interface range {{ ifrange }}
 description *** Client access port ***
 switchport mode access
 switchport access vlan {{ VLAN }}
 ip dhcp snooping limit rate 100
 storm-control broadcast level 01.00 00.90
 storm-control multicast level 01.00 00.90
 spanning-tree bpduguard enable
 spanning-tree portfast
When I simulate this template on a device I get the following output:
!###### Access interface #####
interface range gi1/0/1-24
 switchport access vlan 99
And everything is fine.
But when I try to claim a switch with the same template the GUI stops working and I see a message in the log of the onboarding service:
2021-08-30 18:09:46,324 |  DEBUG | qtp1807648168-9146        |  | c.c.p.a.s.impl.TemplateServiceImpl | response object recieved: {"templateId":"e7cf432f-1e81-48d4-beef-12bd81c9d922","cliPreview":null,"deviceId":null,"validationErrors":[{"type":"RUNTIME","lineNumber":76,"message":"Cannot resolve property 'family' in ''"}]} |
Any help is appreciated.
Preston Chilcote
I'm going to keep thinking about this and ask around, but my initial reaction is that we don't support built in variables during PnP.  The reason is that these variables all tie into inventory related databases, and since the device doesn't go into inventory until PnP is complete, you will get NULL responses when querying and field.
The best workaround I can think of so far is to create a Multi-select drop down to have the user tell you which product family it is.
It's worth mentioning though, that the best practice I recommend is to not put these interface configs into the onboarding template.  That might be why I haven't seen this topic come up before.   If you use day-N instead (by adding a provisioning step after the PnP) then if/when you need to make changes you can still use the same template.  The onboarding template should be just enough to keep connectivity to DNA center (usually to change the dhcp address to a static one on a management or uplink interface.
10 Replies 10
Preston Chilcote
Hi Preston
Thank you for the reply.
It makes sense that the information is not available before the device is added to the inventory.
It would be great if the GUI showed that these variable was not available during onboarding.
Is there any documentation describing this?
I am not sure I am convinced the variables are a good idea to use at all. It seems like there is a lot of strange things happening with them.
And then again. Doing a simulation of the following code:
{% for server in __ntpserver %}
ntp server {{ server }}
{% endfor %}
Gives me this result:
ntp server 10.10.8.1
But when deploying the template to a switch the generated config is:
ntp server
That is curious behavior, but you actually don't need those variables at all.  When you do a day-N provision, then all of the Design settings for the site are automatically provisioned for you.  It is redundant to put them in your template.  This is what the "Network Settings" section of the Summary step of the Provision Devices workflow is trying to communicate... it just doesn't tell you the exact commands that Cisco DNA will provision.
One thing I noticed though was that my ip name-server was not configured from my design. It is configured in my design for the site. And I tried to reprovision the device from inventory but that did not push the name-servers.
To confirm my sanity I tested provisioning of ip name-server with this helpful eem applet so I can see what Cisco DNA is doing:
vent manager applet catchall
event cli pattern ".*" sync no skip no
action 1 syslog msg "$_cli_msg"
I can confirm that ip name-server is applied during provision as I set it up in design settings.
*Sep 17 18:08:56.224: %HA_EM-6-LOG: catchall: no ip domain name
*Sep 17 18:08:56.230: %HA_EM-6-LOG: catchall: ip domain-lookup
*Sep 17 18:08:56.239: %HA_EM-6-LOG: catchall: ip name-server 4.4.4.4
This was also reflected in the configuration preview that you can select when you "Deploy" the provisioning task.
However, on a subsequent provision of the same switch, unless I change the name server in design settings, there is no name-server config applied.
Hi Preston,
I had to check as well after you post.
It seems like the ip domain name and ip name server are not pushed during Day0 but only if you provision the switch manually afterwards.
I am running DNAC 2.2.2.3 and this is the template I am pushing:
{% include "NDK-Imports/NDK-Ports" %}
!####### Template til Switch ######
!###### Hostname/Domain By-Lokation-UnderKrydsfelt-TypeNummer ######
ip domain name mgmt.net
!###### Temp debugging #####
event manager applet catchall
logging Buffered 4000000
logging persistent url flash:/PERSISTENTLOGS size 104857600 filesize 5242880
!###### Clock&Timezone&NTP ######
clock timezone CET 1
clock summer-time CEST recurring last Sun Mar 2:00 last Sun Oct 3:00
service timestamps log datetime show-timezone localtime
!###### SNMP ######
snmp-server location SJ2
snmp-server contact MyName
snmp-server view ViewDefault iso included
snmp-server group GrpMonitoring v3 priv read ViewDefault
snmp-server user UserJustMe GrpMonitoring v3 auth sha AuthPass1 priv aes 128 PrivPass2
!###### Error checks and recovery ######
errdisable recovery cause all
errdisable recovery interval 120
udld aggressive
Spanning-tree loopguard default
!###### Spanning-tree Non-root ######
spanning-tree mode rapid-pvst
spanning-tree vlan 1-4094 priority 36864
!###### Management ######
lldp run
cdp run
line con 0
 exec-timeout 15 0
 logging synchronous
line vty 0 4
 exec-timeout 15 0
 logging synchronous
 transport input ssh
 transport preferred none
 access-class 23 in
line vty 5 15
 exec-timeout 15 0
 logging synchronous
 transport input ssh
 access-class 23 in
no ip http server
ip http secure-server
access-list 23 permit 10.110.0.0 0.0.255.31
access-list 23 permit any
access-list 23 deny any log
{% set vlans = vlset %}
{% for vlan in vlans %}
{% set vlanInfo = vlan.split(';') %}
vlan {{ vlanInfo[0] }}
 name {{ vlanInfo[1] }}
{% endfor %}
!Do not provision until DayN
###### Uplink port ######
default int ra te 1/1/1-4
Interface ra te1/1/1-2
{{ uplink_trunk() }}
!###### Downlink port ######
Interface range te1/1/3-4
{{ downlink_trunk() }}
!###### MGMT Interface ######
interface vlan 1
 shutdown
interface GigabitEthernet0/0
 shutdown
{% set MGMTVLAN = "101" %}
{% set MGMTIPSTRING = "10.254.0.233 255.255.255.0" %}
interface vlan{{ MGMTVLAN }}
 ip address {{ MGMTIPSTRING }}
 no shutdown
ip route 0.0.0.0 0.0.0.0 10.254.0.1
!###### VTP ######
vtp mode transparent
!###### Source interface ######
ip ssh source-interface vlan {{ MGMTVLAN }}
ip tacacs source-interface vlan {{ MGMTVLAN }}
ip radius source-interface vlan {{ MGMTVLAN }}
ip http client source-interface vlan {{ MGMTVLAN }}
ntp source vlan {{ MGMTVLAN }}
!###### DHCP Snooping ######
ip dhcp snooping
ip dhcp snooping vlan 1-4094
!###### AAA ######
aaa new-model
aaa authentication attempts login 3
netconf-yang
!###### Logging #####
logging Buffered notifications
!####### Cleanup from PnP progress
!no pnp profile pnp-zero-touch
 transport https ipv4 10.10.8.10 port 443
During the push this will generate the following in the template CLI Preview:
!###### SNMP ######
snmp-server xxxxxxxx
udld aggressive
lldp run
cdp run
line con 0
 exec-timeout 15 0
 logging synchronous
line vty 0 4
 exec-timeout 15 0
 logging synchronous
 transport input ssh
 access-class 23 in
line vty 5 15
 exec-timeout 15 0
 logging synchronous
 transport input ssh
 access-class 23 in
no ip http server
vlan 10
 name data
vlan 20
 name voice
vlan 30
 name elev
vlan 101
 name adm
vlan 102
 name test
 description *** Uplink to ****
 switchport mode trunk
 switchport nonegotiate
 switchport trunk native vlan 1
 switchport trunk allowed vlan 1-3002
 storm-control broadcast level 10.00 5.00
 storm-control multicast level 10.00 5.00
 ip dhcp snooping trust
 description *** Downlink to XXXXX ****
interface vlan 1
 shutdown
 shutdown
interface vlan101
 ip address 10.254.0.233 255.255.255.0
 no shutdown
!###### VTP ######
ip ssh source-interface vlan 101
ip tacacs source-interface vlan 101
ip radius source-interface vlan 101
ip http client source-interface vlan 101
ntp source vlan 101
ip dhcp snooping
!###### AAA ######
aaa new-model
netconf-yang
And the following in Day-0 Template.
archive
 log config
  logging enable
  logging size 500
  hidekeys
service password-encryption
service sequence-numbers
! Disable external HTTP(S) access
! Disable external Telnet access
! Enable external SSHv2 access
no ip http server
no ip http secure-server
crypto key generate rsa label dnac-sda modulus 2048
ip ssh version 2
ip scp server enable
line vty 0 15
 ! maybe redundant
login xxxxxx
 transport input ssh
 ! maybe redundant
! Set VTP mode to transparent (no auto VLAN propagation)
! Set STP mode to Rapid PVST+ (prefer for non-Fabric compatibility)
! Enable extended STP system ID
! Set Fabric Node to be STP Root for all local VLANs
! Enable STP Root Guard to prevent non-Fabric nodes from becoming Root
! Confirm whether vtp mode transparent below is needed
! spanning-tree bridge priority 0
! spanning-tree rootguard
! spanning-tree portfast bpduguard default
no udld enable
errdisable recovery interval 300
! Enable SNMP and RW access based on ACL
username xxxxxx
enable algorithm-type scrypt secret Linux1234
hostname DK-SJ2-TEMP
The configuration beeing applied on the switch:
No startup-config, starting autoinstall/pnp/ztp...
Autoinstall will terminate if any input is detected on console
Autoinstall trying DHCPv4 on GigabitEthernet0/0
Autoinstall trying DHCPv6 on GigabitEthernet0/0
         --- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
Acquired IPv4 address 10.254.0.53 on Interface GigabitEthernet0/0
Received following DHCPv4 options:
        domain-name     : dna.das-i.dk
        vendor          : 5A1N;B2;K4;I10.10.8.10;J80
        dns-server-ip   : 10.255.1.20
        si-addr         : 10.255.1.20
Press RETURN to get started!
*Sep 16 01:05:59.705: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: TP-self-signed-3594917619 created succesfully
*Sep 16 01:06:00.168: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-3594917619 has been generated or imported by crypto-engine
*Sep 16 01:06:00.170: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Sep 16 01:06:00.230: %PKI-4-NOCONFIGAUTOSAVE: Configuration was modified.  Issue "write memory" to save new IOS PKI configuration
*Sep 16 01:06:00.232: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*Sep 16 01:06:00.368: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: SLA-TrustPoint created succesfully
*Sep 16 01:06:00.371: %PKI-4-NOCONFIGAUTOSAVE: Configuration was modified.  Issue "write memory" to save new IOS PKI configuration
*Sep 16 01:06:00.379: %CALL_HOME-6-CALL_HOME_ENABLED: Call-home is enabled by Smart Agent for Licensing.
*Sep 16 01:06:01.702: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
*Sep 16 01:06:01.780: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-3594917619.server has been generated or imported by crypto-engine
*Sep 16 01:06:02.174: %SMART_LIC-6-REPORTING_REQUIRED: A Usage report acknowledgement will be required in 90 days.
*Sep 16 01:06:02.248: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*Sep 16 01:06:02.248: %PNP-6-PNP_SAVING_TECH_SUMMARY: Saving PnP tech summary (/pnp-tech/pnp-tech-discovery-summary)... Please wait. Do not interrupt.
*Sep 16 01:06:02.365: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*Sep 16 01:06:03.058: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*Sep 16 01:06:03.450: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*Sep 16 01:06:03.576: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
OK to enter CLI now...
pnp-discovery can be monitored without entering enable mode
Entering enable mode will stop pnp-discovery
*Sep 16 01:06:05.431: %IOXN_APP-6-PRE_INIT_DAY0_GS_INFO: Day0 Guestshell de-initilization API is being invoked
*Sep 16 01:06:05.431: AUTOINSTALL: script execution not successful for Gi0/0.
*Sep 16 01:06:05.495: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*Sep 16 01:06:05.596: %PNP-6-PNP_TECH_SUMMARY_SAVED_OK: PnP tech summary (/pnp-tech/pnp-tech-discovery-summary) saved successfully (elapsed time: 3 seconds).
*Sep 16 01:06:05.596: %PNP-6-PNP_DISCOVERY_DONE: PnP Discovery done successfully (PnP-DHCP-IPv4)
*Sep 16 01:06:28.451: %IM-6-IOX_ENABLEMENT: Switch 1 R0/0: ioxman: IOX is ready.Guestshell destroyed successfully
*Sep 16 01:06:31.323: %IOXN_APP-6-PRE_INIT_DAY0_GS_INFO: Day0 Guestshell destroyed
*Sep 16 01:06:31.842: %UICFGEXP-6-SERVER_NOTIFIED_STOP: Switch 1 R0/0: psd: Server iox has been notified to stop
*Sep 16 01:06:59.293: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/23, changed state to down
*Sep 16 01:06:59.923: %PNP-6-HTTP_CONNECTED: PnP Discovery connected to PnP server (profile=pnp-zero-touch, ip=10.10.8.10, port=80)
*Sep 16 01:07:00.295: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/0/23, changed state to down
*Sep 16 01:07:09.824: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/0/23, changed state to up
*Sep 16 01:07:10.823: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/23, changed state to up
*Sep 16 01:07:13.000: %SYS-6-CLOCKUPDATE: System clock has been updated from 01:07:11 UTC Thu Sep 16 2021 to 01:07:13 UTC Thu Sep 16 2021, configured from console by vty0.
Sep 16 01:07:13.000: %PKI-6-AUTHORITATIVE_CLOCK: The system clock has been set.
Sep 16 01:07:13.006: %SYS-5-CONFIG_P: Configured programmatically by process XEP_pnp-zero-touch from console as vty0
Sep 16 01:07:13.013: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: pnplabel created succesfully
Sep 16 01:07:13.017: %PKI-4-NOCONFIGAUTOSAVE: Configuration was modified.  Issue "write memory" to save new IOS PKI configuration
Sep 16 01:07:13.018: %PNP-6-PNP_TRUSTPOINT_INSTALLED: Trustpoint (pnplabel) installed from (/pnp-info/pnp-xsvc-cert) by (pid=305, pname=XEP_pnp-zero-touch, time=01:07:13 UTC Thu Sep 16 2021)
Sep 16 01:07:14.201: %SYS-5-CONFIG_P: Configured programmatically by process PnP reconnect profile from console as vty0
Sep 16 01:07:24.873: %SYS-5-CONFIG_P: Configured programmatically by process XEP_pnp-zero-touch from console as vty0
Sep 16 01:08:47.171: %SYS-5-CONFIG_P: Configured programmatically by process XEP_pnp-zero-touch from console as vty0
Sep 16 01:08:47.629: %SYS-5-CONFIG_P: Configured programmatically by process XEP_pnp-zero-touch from console as vty0
Sep 16 01:08:51.630: %SYS-5-CONFIG_P: Configured programmatically by process XEP_pnp-zero-touch from console as vty0
Sep 16 01:08:51.631: %PNP-6-PNP_CONFIG_ARCHIVE: Config (flash:pnp-archive-Sep-16-01-08-47.264-0) archive (1/3) by (pid=505, pname=XEP_pnp-zero-touch, time=01:08:51 UTC Thu Sep 16 2021)
000129: Sep 16 01:08:55.455: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named dnac-sda has been generated or imported by crypto-engine
000130: Sep 16 01:08:55.625: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging: level debugging, xml disabled, filtering disabled, size (4000000)
000131: Sep 16 01:08:55.629: %SYS-5-LOG_CONFIG_CHANGE: Persistent logging: enabled, url flash:/PERSISTENTLOGS, disk space 104857600 bytes, file size 5242880 bytes, batch size 4096 bytes
000132: Sep 16 01:08:55.630: %SYS-6-CLOCKUPDATE: System clock has been updated from 01:08:55 UTC Thu Sep 16 2021 to 02:08:55 CET Thu Sep 16 2021, configured from console by dnac on vty1.
000133: Sep 16 01:08:55.631: %SYS-6-CLOCKUPDATE: System clock has been updated from 02:08:55 CET Thu Sep 16 2021 to 03:08:55 CEST Thu Sep 16 2021, configured from console by dnac on vty1.
000134: Sep 16 01:08:55.670: %HA_EM-6-LOG: catchall: logging buffered 4000000
000135: Sep 16 01:08:55.671: %HA_EM-6-LOG: catchall: logging persistent url flash:/PERSISTENTLOGS size 104857600 filesize 5242880
000136: Sep 16 01:08:55.671: %HA_EM-6-LOG: catchall: clock timezone CET 1
000137: Sep 16 01:08:55.672: %HA_EM-6-LOG: catchall: clock summer-time CEST recurring last Sun  Mar  2:00  last Sun  Oct  3:00
000138: Sep 16 01:08:55.673: %HA_EM-6-LOG: catchall: service timestamps log datetime show-timezone localtime
000139: Sep 16 01:08:55.676: %HA_EM-6-LOG: catchall: ntp server 10.10.8.1
000140: Sep 16 01:08:55.677: %HA_EM-6-LOG: catchall: snmp-server location SJ2
000141: Sep 16 01:08:55.678: %HA_EM-6-LOG: catchall: snmp-server contact MyName
000142: Sep 16 01:08:55.678: %HA_EM-6-LOG: catchall: snmp-server view ViewDefault iso included
000143: Sep 16 01:08:55.679: %HA_EM-6-LOG: catchall: snmp-server group GrpMonitoring v3 priv read ViewDefault
000144: Sep 16 01:08:55.681: %HA_EM-6-LOG: catchall: snmp-server user UserJustMe GrpMonitoring v3 auth sha AuthPass1 priv aes 128 PrivPass2
000145: Sep 16 01:08:55.717: Configuring snmpv3 USM user, persisting snmpEngineBoots. Please Wait...
000146: Sep 16 01:08:55.802: %HA_EM-6-LOG: catchall: errdisable recovery cause all
000147: Sep 16 01:08:55.804: %HA_EM-6-LOG: catchall: errdisable recovery interval 120
000148: Sep 16 01:08:55.804: %HA_EM-6-LOG: catchall: udld aggressive
000149: Sep 16 01:08:55.805: %HA_EM-6-LOG: catchall: spanning-tree loopguard default
000150: Sep 16 01:08:55.806: %HA_EM-6-LOG: catchall: spanning-tree mode rapid-pvst
000151: Sep 16 01:08:55.808: %HA_EM-6-LOG: catchall: spanning-tree vlan 1-4094 priority 36864
000152: Sep 16 01:08:55.883: %HA_EM-6-LOG: catchall: lldp run
000153: Sep 16 01:08:55.884: %HA_EM-6-LOG: catchall: cdp run
000154: Sep 16 01:08:55.885: %HA_EM-6-LOG: catchall: line con 0
000155: Sep 16 01:08:55.886: %HA_EM-6-LOG: catchall: exec-timeout 15 0
000156: Sep 16 01:08:55.886: %HA_EM-6-LOG: catchall: logging synchronous
000157: Sep 16 01:08:55.889: %HA_EM-6-LOG: catchall: line vty 0 4
000158: Sep 16 01:08:55.890: %HA_EM-6-LOG: catchall: exec-timeout 15 0
000159: Sep 16 01:08:55.891: %HA_EM-6-LOG: catchall: logging synchronous
000160: Sep 16 01:08:55.892: %HA_EM-6-LOG: catchall: transport input ssh
000161: Sep 16 01:08:55.892: %HA_EM-6-LOG: catchall: transport preferred none
000162: Sep 16 01:08:55.895: %HA_EM-6-LOG: catchall: access-class 23 in
000163: Sep 16 01:08:55.896: %HA_EM-6-LOG: catchall: line vty 5 15
000164: Sep 16 01:08:55.897: %HA_EM-6-LOG: catchall: exec-timeout 15 0
000165: Sep 16 01:08:55.898: %HA_EM-6-LOG: catchall: logging synchronous
000166: Sep 16 01:08:55.898: %HA_EM-6-LOG: catchall: transport input ssh
000167: Sep 16 01:08:55.905: %HA_EM-6-LOG: catchall: transport preferred none
000168: Sep 16 01:08:55.906: %HA_EM-6-LOG: catchall: access-class 23 in
000169: Sep 16 01:08:55.906: %HA_EM-6-LOG: catchall: no ip http server
000170: Sep 16 01:08:55.907: %HA_EM-6-LOG: catchall: ip http secure-server
000171: Sep 16 01:08:55.943: %HA_EM-6-LOG: catchall: access-list 23 permit 10.110.0.0 0.0.255.31
000172: Sep 16 01:08:55.944: %HA_EM-6-LOG: catchall: access-list
000128: Sep 16 01:08:55.432: %SMART_LIC-3-COMM_FAILED: Communications failure with the Cisco Smart License Utility (CSLU) : Unable to resolve server hostname/domain name  23 permit any
000173: Sep 16 01:08:55.945: %HA_EM-6-LOG: catchall: access-list 23 deny any log
000174: Sep 16 01:08:55.945: %HA_EM-6-LOG: catchall: vlan 10
000175: Sep 16 01:08:55.946: %HA_EM-6-LOG: catchall: name data
000176: Sep 16 01:08:55.949: %HA_EM-6-LOG: catchall: vlan 20
000177: Sep 16 01:08:55.950: %HA_EM-6-LOG: catchall: name voice
000178: Sep 16 01:08:55.950: %HA_EM-6-LOG: catchall: vlan 30
000179: Sep 16 01:08:55.951: %HA_EM-6-LOG: catchall: name elev
000180: Sep 16 01:08:55.952: %HA_EM-6-LOG: catchall: vlan 101
000181: Sep 16 01:08:55.955: %HA_EM-6-LOG: catchall: name adm
000182: Sep 16 01:08:55.955: %HA_EM-6-LOG: catchall: vlan 102
000183: Sep 16 01:08:55.956: %HA_EM-6-LOG: catchall: name test
000184: Sep 16 01:08:55.957: %HA_EM-6-LOG: catchall: default interface range TenGigabitEthernet1/1/1 - 4
000185: Sep 16 03:08:55 CEST: %SYS-5-CONFIG_P: Configured programmatically by process XEP_pnp-zero-touch from console as dnac on vty1
000186: Sep 16 03:08:55 CEST: %SYS-5-CONFIG_P: Configured programmatically by process XEP_pnp-zero-touch from console as dnac on vty1
000187: Sep 16 03:08:55 CEST: %SYS-5-CONFIG_P: Configured programmatically by process XEP_pnp-zero-touch from console as dnac on vty1
000188: Sep 16 01:08:55.981: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/1
000189: Sep 16 01:08:55.982: %HA_EM-6-LOG: catchall: end
000190: Sep 16 01:08:55.982: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/2
000191: Sep 16 01:08:55.983: %HA_EM-6-LOG: catchall: end
000192: Sep 16 01:08:55.984: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/3
000193: Sep 16 01:08:55.986: %HA_EM-6-LOG: catchall: end
000194: Sep 16 03:08:55 CEST: %SYS-5-CONFIG_P: Configured programmatically by process XEP_pnp-zero-touch from console as dnac on vty1
000195: Sep 16 01:08:56.046: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/4
000196: Sep 16 01:08:56.047: %HA_EM-6-LOG: catchall: end
000197: Sep 16 01:08:56.048: %HA_EM-6-LOG: catchall: interface range TenGigabitEthernet1/1/1 - 2
000198: Sep 16 01:08:56.049: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/2
000199: Sep 16 01:08:56.049: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/1
000200: Sep 16 01:08:56.052: %HA_EM-6-LOG: catchall: description *** Uplink to ****
000201: Sep 16 01:08:56.053: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/2
000202: Sep 16 01:08:56.054: %HA_EM-6-LOG: catchall: description *** Uplink to ****
000203: Sep 16 01:08:56.055: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/1
000204: Sep 16 01:08:56.055: %HA_EM-6-LOG: catchall: switchport mode trunk
000205: Sep 16 01:08:56.058: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/2
000206: Sep 16 01:08:56.059: %HA_EM-6-LOG: catchall: switchport mode trunk
000207: Sep 16 01:08:56.060: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/1
000208: Sep 16 01:08:56.061: %HA_EM-6-LOG: catchall: switchport nonegotiate
000209: Sep 16 01:08:56.061: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/2
000210: Sep 16 01:08:56.066: %HA_EM-6-LOG: catchall: switchport nonegotiate
000211: Sep 16 01:08:56.067: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/1
000212: Sep 16 01:08:56.068: %HA_EM-6-LOG: catchall: switchport trunk native vlan 1
000213: Sep 16 01:08:56.068: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/2
000214: Sep 16 01:08:56.069: %HA_EM-6-LOG: catchall: switchport trunk native vlan 1
000215: Sep 16 01:08:56.072: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/1
000216: Sep 16 01:08:56.073: %HA_EM-6-LOG: catchall: switchport trunk allowed vlan 1-3002
000217: Sep 16 01:08:56.074: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/2
000218: Sep 16 01:08:56.075: %HA_EM-6-LOG: catchall: switchport trunk allowed vlan 1-3002
000219: Sep 16 01:08:56.075: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/1
000220: Sep 16 01:08:56.078: %HA_EM-6-LOG: catchall: storm-control broadcast level 10.00  5.00
000221: Sep 16 01:08:56.079: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/2
000222: Sep 16 01:08:56.080: %HA_EM-6-LOG: catchall: storm-control broadcast level 10.00  5.00
000223: Sep 16 01:08:56.080: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/1
000224: Sep 16 01:08:56.081: %HA_EM-6-LOG: catchall: storm-control multicast level 10.00  5.00
000225: Sep 16 01:08:56.084: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/2
000226: Sep 16 01:08:56.085: %HA_EM-6-LOG: catchall: storm-control multicast level 10.00  5.00
000227: Sep 16 01:08:56.086: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/1
000228: Sep 16 01:08:56.086: %HA_EM-6-LOG: catchall: ip dhcp snooping trust
000229: Sep 16 01:08:56.087: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/2
000230: Sep 16 01:08:56.143: %HA_EM-6-LOG: catchall: ip dhcp snooping trust
000231: Sep 16 01:08:56.144: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/1
000232: Sep 16 01:08:56.145: %HA_EM-6-LOG: catchall: interface range TenGigabitEthernet1/1/3 - 4
000233: Sep 16 01:08:56.145: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/4
000234: Sep 16 01:08:56.146: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/3
000235: Sep 16 01:08:56.149: %HA_EM-6-LOG: catchall: description *** Downlink to XXXXX ****
000236: Sep 16 01:08:56.150: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/4
000237: Sep 16 01:08:56.151: %HA_EM-6-LOG: catchall: description *** Downlink to XXXXX ****
000238: Sep 16 01:08:56.151: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/3
000239: Sep 16 01:08:56.152: %HA_EM-6-LOG: catchall: switchport mode trunk
000240: Sep 16 01:08:56.155: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/4
000241: Sep 16 01:08:56.156: %HA_EM-6-LOG: catchall: switchport mode trunk
000242: Sep 16 01:08:56.157: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/3
000243: Sep 16 01:08:56.157: %HA_EM-6-LOG: catchall: switchport nonegotiate
000244: Sep 16 01:08:56.158: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/4
000245: Sep 16 01:08:56.161: %HA_EM-6-LOG: catchall: switchport nonegotiate
000246: Sep 16 01:08:56.162: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/3
000247: Sep 16 01:08:56.162: %HA_EM-6-LOG: catchall: switchport trunk native vlan 1
000248: Sep 16 01:08:56.163: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/4
000249: Sep 16 01:08:56.164: %HA_EM-6-LOG: catchall: switchport trunk native vlan 1
000250: Sep 16 01:08:56.167: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/3
000251: Sep 16 01:08:56.168: %HA_EM-6-LOG: catchall: switchport trunk allowed vlan 1-3002
000252: Sep 16 01:08:56.168: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/4
000253: Sep 16 01:08:56.169: %HA_EM-6-LOG: catchall: switchport trunk allowed vlan 1-3002
000254: Sep 16 01:08:56.170: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/3
000255: Sep 16 01:08:56.173: %HA_EM-6-LOG: catchall: storm-control broadcast level 10.00  5.00
000256: Sep 16 01:08:56.174: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/4
000257: Sep 16 01:08:56.174: %HA_EM-6-LOG: catchall: storm-control broadcast level 10.00  5.00
000258: Sep 16 01:08:56.176: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/3
000259: Sep 16 01:08:56.176: %HA_EM-6-LOG: catchall: storm-control multicast level 10.00  5.00
000260: Sep 16 01:08:56.179: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/4
000261: Sep 16 01:08:56.180: %HA_EM-6-LOG: catchall: storm-control multicast level 10.00  5.00
000262: Sep 16 01:08:56.181: %HA_EM-6-LOG: catchall: interface TenGigabitEthernet1/1/3
000263: Sep 16 01:08:56.182: %HA_EM-6-LOG: catchall: interface Vlan1
000264: Sep 16 01:08:56.182: %HA_EM-6-LOG: catchall: shutdown
000265: Sep 16 01:08:56.185: %HA_EM-6-LOG: catchall: interface GigabitEthernet0/0
000266: Sep 16 01:08:56.185: %HA_EM-6-LOG: catchall: shutdown
000267: Sep 16 01:09:00.522: %HA_EM-6-LOG: catchall: interface Vlan101
000268: Sep 16 01:09:00.522: %HA_EM-6-LOG: catchall: ip address 10.254.0.233 255.255.255.0
000269: Sep 16 01:09:00.523: %HA_EM-6-LOG: catchall: no shutdown
000270: Sep 16 01:09:00.524: %HA_EM-6-LOG: catchall: ip route 0.0.0.0 0.0.0.0 10.254.0.1
000271: Sep 16 01:09:00.524: %HA_EM-6-LOG: catchall: vtp mode transparent
000272: Sep 16 01:09:00.527: %HA_EM-6-LOG: catchall: ip ssh source-interface Vlan101
000273: Sep 16 01:09:00.528: %HA_EM-6-LOG: catchall: ip tacacs source-interface Vlan101
000274: Sep 16 01:09:00.529: %HA_EM-6-LOG: catchall: ip radius source-interface Vlan101
000275: Sep 16 01:09:00.529: %HA_EM-6-LOG: catchall: ip http client source-interface Vlan101
000276: Sep 16 01:09:00.530: %HA_EM-6-LOG: catchall: ntp source Vlan101
000277: Sep 16 01:09:00.533: %HA_EM-6-LOG: catchall: ip dhcp snooping
000278: Sep 16 01:09:00.533: %HA_EM-6-LOG: catchall: ip dhcp snooping vlan 1-4094
000279: Sep 16 03:09:00 CEST: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging: level notifications, xml disabled, filtering disabled, size (102400)
000280: Sep 16 03:09:00 CEST: %SYS-5-CONFIG_P: Configured programmatically by process XEP_pnp-zero-touch from console as vty1
000281: Sep 16 03:09:00 CEST: %PARSER-4-BADCFG: Unexpected end of configuration file.
-Traceback= 1#cb55fc0d6ad0d81f0cf86eb1353e884b  :55BB9B398000+8120F7B :55BB9B398000+8130F4D :55BB9B398000+81312BC :55BB9B398000+88DF002 :55BB9B398000+88D4628 :55BB9B398000+88C8473 :55BB9B398000+88D870C :55BB9B398000+88D766B :55BB9B398000+9F1B0A3 :55BB9B398000+9F35AAB :55BB9B398000+9F36B92 :55BB9B398000+AAC575A :55BB9B398000+9F55BA8 :55BB9B398000+AA7FE10
000282: Sep 16 01:09:00.596: %HA_EM-6-LOG: catchall: aaa new-model
000283: Sep 16 01:09:00.614: %HA_EM-6-LOG: catchall: aaa authentication attempts login 3
000284: Sep 16 01:09:00.614: %HA_EM-6-LOG: catchall: netconf-yang
000285: Sep 16 01:09:00.616: %HA_EM-6-LOG: catchall: logging buffered 4000000
000286: Sep 16 01:09:00.617: %HA_EM-6-LOG: catchall: logging buffered notifications
000287: Sep 16 01:09:00.619: %HA_EM-6-LOG: catchall: pnp profile pnp-zero-touch
000288: Sep 16 01:09:00.620: %HA_EM-6-LOG: catchall: transport https ipv4 10.10.8.10 port 443
000289: Sep 16 03:09:00 CEST: %PSD_MOD-5-DMI_NOTIFY_NETCONF_START: Switch 1 R0/0: psd: PSD/DMI: netconf-yang server has been notified to start
000290: Sep 16 03:09:01 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan101, changed state to down
000291: Sep 16 03:09:02 CEST: %LINK-5-CHANGED: Interface GigabitEthernet0/0, changed state to administratively down
000292: Sep 16 03:09:03 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
000293: Sep 16 03:09:04 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan101, changed state to up
000294: Sep 16 03:09:10 CEST: %HMANRP-6-EMP_ELECTION_INFO: EMP active switch 1 elected: EMP_RELAY: Mgmt port status DOWN, reelecting EMP active switch
The name-server is missing but if I provision the device after the initial Day0 provisioning, the name-server is pushed according to my design.
This should be fixed by CSCvz08038 - "Cisco DNA Center - Template System Variables don't work without brackets" in the next release, but there is a workaround using __dnsserver[0].primaryIPAddress.
If this is just a bug then that makes sense. Thanks Preston.
