C2960S provisioning /DNA Center
MohssineBen
Hello evrybody ,
i want provisioning  a switch C2960S but i get an error message :
"File transfer using HTTPS and SCP failed
Expected : Device need to have https/scp reachability to Controller
Action : Verify HTTPS/SCP configurations, DNAC certificates on device and protocol reachability"
10 Replies 10
Diana Karolina Rojas
Did you verify if the https service is available in your device? you need to have this command in your switch: ip http secure-server
Please do not forget to rate useful post.
Best Regards,
hi,
Can you please configure below command in switch and then try.
(config)#ip scp server enable
Hello ,
I wrote it but it still doesn't work
Best Regards,
I hadn't see the image attached until now. Do you create the Loopback 0 in your device (this is mandatory)? which SDM profile are you using in the switch?
Please don't forget to rate useful post.
Best Regards,
i don't have a loopback interface on my device , it use a default SDM profile
Hello ,
i have checked, i already have this command in my switch : ip http secure-server
Best Regards,
Hello ,
Best Regards,
AndiBuchmann157
ammahend
I don't think that device is supported for provisioning through DNAC.
what you can do is discover this device or add it manually, which i believe you have already done, then assign it to a site and you can get assurance data on this device and look at device 360.
this might give you some valuable information about the device like overall health score, CPU, memory, physical neighbor topology, path trace, uptime etc.
-hope this helps-
nitekum5
Cisco 2960-S is not supported by DNAC. Please refer the attached DNAC supported device list.
