C9800 not initializing PnP
littleyoda
I have option 43 configured on a Meraki Z3 router with a single VLAN 1 on it. It has reachability to the DNAC. I have cleared all crypto, nvram, and vlan data from the WLC and I still can't get the PnP process to start on the C9800-L-C. I followed this video to the T and it still doesn't work. Any ideas?
I am running DNAC 2.1.2. Issue is with 9800-L-C  Zero Touch Provisioning that are running 16.12.4a. DHCP fails off the management interfaces. You have to use the service port. This fixed the issue. The fix is in 17.3.
5 Replies 5
__Babygirl__09
I need to know how does it works
Dan Rowe
What version of code is running on the 9800 and what interface on the 9800 do you have plugged into the Meraki router?
balaji.bandi
what is the version of DNAC? i believe 2.1.2 onwards support this feature and also 9800 should be the latest version to support
worth look this thread :
https://community.cisco.com/t5/cisco-digital-network/9800-pnp/td-p/4081538
BB
rasmus.elmholt
Level 7
Level 7
I agree wit BB, make sure to use the latest DNAC and WLC code. this is a fairly new feature.
Follow the tshoot steps in this flowchart for Lan automation some of the are the same for PnP:
