08-07-2024 02:32 AM
we have installed catalyst center in air gap mode and wish to verify it. I thought that only air gap installations have an "eula..."file and can verify it this way. But maybe there are better solutions.
Kind regards,
Daniel
Solved! Go to Solution.
08-10-2024 12:45 PM
Hi Daniel, can you provide the output for maglev catalog settings display. If offline mode is set to TRUE then the Catalyst Center is registered as an airgap deployment.
08-10-2024 12:45 PM
08-11-2024 11:38 PM
Thank you, that was what I needed!
